7-way cable assembly length - Fiberglass RV
Old 05-13-2014, 09:59 AM   #1
Trailer: Boler 1978
Well, it's that time of year and this will find me beavering away getting the Boler ready for another season.
One of the things I need to do this year is replace the 7-way cable assembly. Several prior owners performed botched splicing jobs on the cable assembly and it looks like something cooked up by Chef Boy-ar-Dee. This cable assembly has to be replaced and was wondering how long the replacement cable assembly should be.
The cable assembly goes from the terminal block inside of our 1978 13 ft Boler, located at the kitchen cabinet, to the connector on the Tow vehicle.
How much extra length will I need from the A-frame coupler to the vehicle end connector socket to prevent damaging the cable assembly during turns and not have it too long?
I have searched the forums and can't find any specifics.
Thanks in advance and appreciate any advice you may have.
Winfield456 is offline   Reply With Quote
Old 05-13-2014, 10:40 AM   #2
It can never be too long and can always be too short!
frankcfx is offline   Reply With Quote
Old 05-13-2014, 10:43 AM   #3
Trailer: 1999 Casita 17' SD
Ohio
I have a Casita and found most available cables are 6 foot long. That was not enough to replace it all from inside the trailer to the 7 pin connector on my TV.
I found a 8' Bergman cable online and cut off a foot and in addition the Bergman has contacts on both sides of each connections unlike the Hopins extensions available from Wal-Mart and others.
Etrailer has Bergman and Hopkins and 8-10 foot ones and the Better Bergman ones are priced more but worth it.
Old 05-13-2014, 11:10 AM   #4
David Tilston's Avatar
Princess auto sells a 7 conductor 12 gauge trailer cable by the foot. I guessed at 10'. I can cut off the excess.
Old 05-13-2014, 12:05 PM   #5
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I would guess 15' and buy 20'. I just moved my battery to the tongue from under the bed (way in the back) in our ParkLiner, which is not much longer than your Boler, if at all. I measured outside with a measuring tape, and figured 15' would do it. It did, but just barely. It would never have worked for the 7 pin plug. So if it was me, I would do What Dave suggests, but it buy the foot, and get 20'. Then you can't avoid a nice clean factory look!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 05-13-2014, 12:34 PM   #6
I am expecting to just go from the junction box on the front road side of the trailer, through the bottom of the trailer, to the plug. Since the distance is no more then 6' to the ball from that point, the extra 4' should cover the stripped length at the JB, and provide enough to reach the tow vehicle. The wire to the battery on the tongue is connected in the same JB.
Old 05-14-2014, 05:33 AM   #7
Trailer: Boler 1978
Thanks everyone for the input. To be exact, I could back the TV to the A-frame coupler at the angle simulating a hard right turn until the steering gear hits the wheel stops. The TV electrical connector is at the left side of the trailer hitch then add a few inches to the length of the cable assembly just to prevent unintended disconnection.
Soon as I do this, I will stumble across a "rule-of-thumb" from the web the RV technicians use to judge these things.
Old 05-14-2014, 07:14 AM   #8
Go with some extra length. If, by chance, your plug drops out and the cord is damaged, you will wind up having to replace the entire cord rather than just cutting off the damaged part. Mfg.s tend to make them as short as possible because it saves $$$$
I have almost 2 extra feet on mine and I can just loop it around the jack or the propane tank.
Old 05-14-2014, 07:31 AM   #9
Ice-breaker's Avatar
ditto!
Ice-breaker is offline   Reply With Quote
Old 05-14-2014, 11:14 AM   #10
If the new cables are too short you can put in a new junction box for the 7 pin, splicing the old cable with the new. If you have a place to put it inside close to the front it can make future work easier. Usually its the outside connector and exposed wiring going bad where the wiring inside is still very nice.
Wiring Junction Box Accessories and Parts | etrailer.com
Old 05-14-2014, 11:18 AM   #11
frank_a's Avatar
Excellent idea!
Frank
2012 ParkLiner #006
Old 05-15-2014, 11:16 AM   #12
For Canadians, Princess Auto also carries a similar box:
7:6 Trailer Wiring Junction Box | Princess Auto
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
electrical - 4 way vs 7 way - questions DaleT Problem Solving | Owners Helping Owners 3 05-14-2009 07:08 PM
Way Way up North Al V Rallies, Get-togethers, Molded Meets (Archive) 23 06-23-2006 02:30 PM
