80's Scamp Axle & Refrig Questions - Fiberglass RV
Old 05-14-2010, 09:30 AM   #1
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
I'm relatively new to this site and just recently purchased our first trailer an older 13 ft scamp (early 80's). I've been searching for info and may have missed it, this is such a great site with super people and advice.
First can someone post me pictures of what the axle position should like like. I'm trying to determine if my axle needs replacing. When i look at the trailer from the side, the curve of the wheel well cover approx the top 1/3 of the tire(unfortunately my digital camera has died or I would add some pics) also is there a simple test of they axle as well. When I'm towing the empty trailer using a jeep wrangler there seems to be some bouncing is this an indication of a problem ?
Secondly i have a domestic 211 refrig that i can't seem to get running on 12 v 120 or gas......any ideas other than pulling it out and turning it upside down ? voltage checks out and pilot stays lighted.
Lastly if these subjects have been covered and I've overlooked the obvious i apologize I'm trying desperately to get ready for our first camping season. I was hoping to be ready to attend the lake San Antonio ralley but our plans got changed
alan H is online now   Reply With Quote
Old 05-14-2010, 09:38 AM   #2
While i am unable to post pics of my trailer axle & wheel the photos of this scamp show the same look as my trailer wheel well......does this appear to be normal ?????
SCAMP lightweight trailer $1800 (Tunnel Hill Ga)
Old 05-14-2010, 12:23 PM   #3
Please help.......I'm sure somebody has had to check out their axle or has some ideas.....so far i've haven't had much luck doing a search....i really need some solid advice
Old 05-14-2010, 01:49 PM   #4
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Hi Alan, I'm no expert, and hopefully the real knowledgeble will jump in here soon---but from the example pic you posted---that is NOT a good sign. Camper is riding too low and axle is probably shot.
From what I've read on here, that seems to be a common problem as these little gems age.
Vickie
1988 Perris Pacer
2010 Honda Ridgeline
2013 Winnebago Minnie 2101FBS
Vickie B. is offline   Reply With Quote
Old 05-14-2010, 02:40 PM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
If it looks like this
the axle is SHOT. The trailing arm on the axle should point down.NOT up or level. As for the frig. make sure the trailer is level.
GOOD LUCK
Old 05-14-2010, 03:35 PM   #6
Mike Bromley's Avatar
Trailer: 1973 Boler 1300 (Glass-Fab
The Dometic 211 fridge is a warhorse. It should be level as possible, that is, by checking the bottom of the freezer compartment with a bullseye level. If you want to troubleshoot, the 211 manual is found here:
http://www.fiberglassrv.com/files/Dometic_..._RM211_1980.pdf
They are very slow to cool, so you might leave it running for eight hours and feel inside the freezer on the coils, they should develop frost after about six hours.
As for axles, they are replaceable. One needs to find out whether it's a leading or trailing arm, and what its initial arm position was. Some positions aren't made any more, so spacers need to be installed. Yours looks like it is probably a leading-arm type, because of the amount of sag....it's a low-rider! If you have it replaced, have it bolted on...this will facilitate later maintenance, or the addition of more lift if desired.
Axle replacement is recommended...because all the bouncing will lead to collateral damage...frame cracks, fibreglass cracks, stuff shaken loose, etc. It's the best thing you can do to improve your trailer's handling and future condition.
Mike Bromley is offline   Reply With Quote
Old 05-14-2010, 03:47 PM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This is my 13' Scamp with a new axle.(2 years ago)
Old 05-14-2010, 04:25 PM   #8
Vickie B.'s Avatar
Nebraska
Nice pic, Kevin. So-----where does one get a new axle????
1988 Perris Pacer
Old 05-14-2010, 07:27 PM   #9
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
Obviously your axle's suspension is shot. Kevin, you got a real nice Scamp. Mike gave you a good advice, I just got mine replaced on my Boler a week ago, I went to a specialized RV suspension shop (they were reffered to me by a regular RV shop, the suspension shop are used to deal with big motorized monster and other big things, but they did an unbeliveable work on my thinny thing.
Here is a hint, look in your area after vulcanized/vulcanization, .../ shop, ..., they deal with RV suspension (mostly air cushionned), but they do know how to deal with small RVs as well. They knew right away about Dexter and Flexride axles.
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 05-14-2010, 07:49 PM   #10
Sorry I am not much help at trouble on the fridge other than I have to plug mine in the night before I go anywhere. When you first plug it in it is really hard to tell if it is actually working. If you assuming that its not working as nothing happens right away I would put a thermometer in it and wait at least 4 hours to see if it is cooling off at all. I also always keep a milk jug with water frozen in it in my home freezer which I put in the trailer fridge when I forgot to plug in the night before. It seems to help it cool down a lot faster.
Old 05-14-2010, 08:35 PM   #11
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I did mine my self. Just order one at http://www.dexteraxle.com/from
Old 05-14-2010, 09:34 PM   #12
Vickie B.'s Avatar
Nebraska
Thanks for all the info---I live in fear of the day my axle needs replaced----we know NOTHING about that stuff!
1988 Perris Pacer
Old 05-15-2010, 11:11 AM   #13
As I suspected I got some great advice from other members......i was able to get my refrig working on house voltage.( I'm currently freezing a small plastic cup of water )...but am still concerned with any potential axle issues. Any ideas on what a replacement axle and installation should run ?
I was hoping someone might post a picture of there axle for a reference
Old 05-16-2010, 07:00 PM   #14
If you look under the Care and Feeding someone posted a topic on May 7th about what an axle should not look like. Number of photos of not so good and one of the cross section of a new one.
Old 05-17-2010, 05:05 PM   #15
FRANK MOLIS's Avatar
Trailer: 1980 (Circa) 13 ft Scamp (A WORK IN PROGRESS)
Alan....I just replaced my axle on my 1982 Scamp, the Dexter Torflex 2200 lb axle was $309.14 with shipping and tax. I paid a friend $100.00 to do the bracket welding. Attached are some pictures which should give you a sense of what a good and bad axle looks like. The blue painted metal is a piece of 1-1/2 x 3 steel tube that I added, because I ordered the wrong orientation on my mounting brackets, and without the added steel tube I did not have clearance with the axle on the drop down box under the camper. It all worked out, just added more work to the project.
Frank
FRANK MOLIS is offline   Reply With Quote
axle, scamp
Axle Upgrade Questions - '81 Scamp 13ft Jon W Towing, Hitching, Axles and Running Gear 6 08-05-2010 07:53 PM
More axle questions: compact junior Kent I Towing, Hitching, Axles and Running Gear 4 01-01-2010 09:38 PM
Questions regarding Axle from Jonathan Donna D. Towing, Hitching, Axles and Running Gear 10 03-10-2008 07:48 PM
Burro axle sag questions Steve Hilby Towing, Hitching, Axles and Running Gear 1 01-27-2008 01:55 PM
2 way Refrig Jim Paskett Problem Solving | Owners Helping Owners 13 01-29-2006 04:58 PM
