A cheap and easy way to better towing! - Fiberglass RV
Old 06-30-2010, 08:34 PM   #1
Trailer: Trillium 4500
The interface between my 2" receiver and her male counterpart was pretty sloppy, making for a jerky, clanky tow. I wrapped the male end with duct tape till' nice and snug. HUGE! difference! Towed 2'400 mi. still good (might try to add a little more to account for wear/compaction). Everyone should try this.
Scott H is offline   Reply With Quote
Old 06-30-2010, 08:51 PM   #2
Interesting. The one on my tug fits snug. In fact the first time I added the hitch into the receiver I thought I was going to need to grease the dang thing to get it into the hole. But if your solution works for you, and others... GREAT!
Old 06-30-2010, 10:48 PM   #3
Trailer: Fiber Stream
Post
I'll have to try that. My Weight Distribution Hitch Ball/Spring Arm Mount is cast steel, and the part that fits in the Receiver is shaped like a tapered I-beam. It's quite sloppy now.
Old 06-30-2010, 11:11 PM   #4
Raya's Avatar
I've been wondering about this, Donna. My 1-1/4" tow bars (I have three) fit quite snugly in the receiver; yet I have a friend with a new truck and a 2" receiver and the fit is really sloppy. I would find that super annoying!
Old 07-01-2010, 05:00 AM   #5
The Hobo's Avatar
Trailer: 1976 Triple E Surfside
I,ve done that also,
it works good.
1976 Surfside Tripple-E
The Hobo is offline   Reply With Quote
Old 07-01-2010, 09:24 AM   #6
Good Tempoary fix. I do suggest that you try to get a metal sleave that is just big enough. A good Auto parts store should have them in many different thickness and sizes. You will need to cut and drill.
James V is offline   Reply With Quote
Old 07-01-2010, 09:53 AM   #7
IllAnnoy
I found electrical tape also made a nice durable anti-rattle fix too.
Another solution...
I use my MIG to weld a flat bead across the bar right where it is fully inserted into the receiver, then grind it to a custom fit...works great.
Old 07-01-2010, 10:00 AM   #8
DonDeutsch's Avatar
For those people whith the "snug" fit: Remove and grease these frequently or they will likely rust forever in place.
DonDeutsch is offline   Reply With Quote
Old 07-01-2010, 10:27 AM   #9
Raya's Avatar
I take mine out when I'm not towing and store it in a compartment in the car (the two others, which I use with less frequency, live in the shed). I get tired of running into it with my shins otherwise
Old 07-01-2010, 10:31 AM   #10
DonDeutsch's Avatar
Hi Raya, that of course is another good reason. I think leaving the hitch adapter in place is most often done by those with pickup trucks.
Old 07-01-2010, 10:36 AM   #11
Raya's Avatar
Good point, Don. And being from Minnesota myself, I understand about rust (all too well).
Just don't run into the one left installed on the pickup
Raya
Old 07-01-2010, 11:30 AM   #12
Marinab's Avatar
Trailer: 1978 Biggar / 2007 Toyota Tundra V8 2wd
I've only run into it once. Now, I'm VERY careful.
Life would be a million times better if there were Pinatas strategically placed throughout the day.
Marinab is offline   Reply With Quote
Old 07-01-2010, 01:02 PM   #13
IllAnnoy
My bar didn't rust into place , but my lock rusted internally so bad that I had to cut it off.
One more thing in need of lube.
The weld bead is only at the opening of the receiver which means it is only tightened for less than a 1/4" then loose for extraction.
of course even the "loose ones can rust-up if left long enough.
Old 07-01-2010, 10:06 PM   #14
Otto's Avatar
Trailer: 89 Scamp 16 ft
Another thing you can use to take up the slop are the wooden window shims. They sell at hardware stores for installing windows. Makes good kindling, too.
Caution Brick towing Egg.
Otto is offline   Reply With Quote
Flooring trim solution.. cheap and easy! Gina D. Modifications, Alterations and Updates 15 08-24-2009 11:54 PM
Over easy ronsmith100 General Chat 10 08-20-2009 09:24 PM
Easy BBQ chicken Christi V. Camp Cooking, Food & Recipes 2 10-03-2006 11:08 AM
Easy Bread Tom Trostel Camp Cooking, Food & Recipes 24 06-12-2006 04:37 PM
Hey folks...easy on me. Legacy Posts General Chat 9 08-16-2003 10:42 AM
