A Magnet Mystery - Fiberglass RV
Old 07-06-2012, 11:22 AM   #1
Raz
Raz's Avatar
Vermont
A Magnet Mystery
A couple weeks ago I wired our new tow vehicle. When I plugged it in to test things out I found I had a brake problem. When energized only one side would hum. I disconnected the tow vehicle and using the breakaway switch I tested each side by jacking up the wheel and spinning it. I discovered the passenger side brake was not working. I disassembled the brake and found the wires entering the magnet were sheared. I replaced the magnet and the brake once again is working but I can't figure out how the wires could have been cut. Any thoughts? Raz
Old 07-06-2012, 12:31 PM   #2
Trailer: 1984 Scamp 13'
Maryland
Cut brake line? Has anyone taken out a life insurance policy on you recently?
-Jesse
Old 07-06-2012, 01:38 PM   #3
Raz
Raz's Avatar
Vermont
Now there's a thought. Nah, she can't back up the trailer.
Old 07-06-2012, 03:59 PM   #4
The easy way to test:
Hold a compass next to the hub while someone else steps on the brakes and if the coil (Magnet) is energized the compass needle will move then do the same for the other wheel(s).
Old 07-06-2012, 04:05 PM   #5
The magnet when energized pulls to the hub and rubs on it and then moves in the direction the wheel is turning thus applying the brakes. When you de-energize the springs in the brake assembly pull the magnet back to it's normal position so I expect the back and forth movement simply wore the connection to the breaking point.
Old 10-20-2012, 06:31 AM   #6
Raz
Raz's Avatar
Vermont
The other side failed in the same manner. This time I looked things over carefully before I diassembled anything and noticed the retainer clip that holds the magnet to the brake arm was missing. What I thing happened is the clip rusted off allowing the magnet to flop around resulting in broken wires right where they enter the magnet. In the future I will check the condition of the clips at every grease interval. Raz
Old 10-20-2012, 07:07 AM   #7
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: P. Raz... Sounds like "The weakest link" theory at work here!!!
Old 10-20-2012, 07:14 AM   #8
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You didn't solder those wires on did you?
Old 10-20-2012, 07:52 AM   #9
Raz
Raz's Avatar
Vermont
Yup. Don't tell anyone , I used lead tin solder too.
Brake magnet thunter Towing, Hitching, Axles and Running Gear 6 04-27-2012 05:06 PM
Mystery Hole KarenP Problem Solving | Owners Helping Owners 3 08-01-2011 12:06 AM
New Mystery Picture Tom U General Chat 15 05-11-2009 10:25 AM
Tekonsha 10" magnet kit in CANADA?? Francis McDermott Care and Feeding of Molded Fiberglass Trailers 6 03-23-2009 03:58 PM
A Mystery Darwin Maring General Chat 4 10-01-2008 09:50 AM
