A "no drop" ball mount? - Page 2 - Fiberglass RV
Old 05-15-2016, 05:14 AM   #21
Trailer: The BIG "O"
New Hampshire
Originally Posted by Jim G. - Ohio View Post
Years ago, I read in my Coleman pop-up manual that it is better to have the rear end low rather than high. The adverse handling and sway is increased with the tail high. On this forum, some say the opposite. Question: Does any FGRV manual state that the tongue should be low if not level? Think about this: more weight on the hitch is less on the steering! What manual says what?
Here is an article by popular mechanics that covers a lot, scroll to #4 for this specific topic
The Right Way to Tow a Trailer
RandyNH is offline   Reply With Quote
Old 05-15-2016, 08:38 AM   #22
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Originally Posted by Mike Magee View Post
Did you look at the one I linked to, at Harbor Freight? Seems like it would work fine with your sway control bracket. You may need a ball with a longer shank, that's all.
My bad. Looking back at that mount, I see what you mean... the ball is welded to the tube! Shucks. I didn't realize that.
Well, gosh. All you really would need is the 2" tube, and drill holes for your ball shank to fit into, right? Seems like it would be easy to make or modify one.
Old 05-15-2016, 09:21 AM   #23
Timber Wolf's Avatar
North Florida
I have the no rise mount and welded a "tab" on the side, sourced from my local hitch shop, for my sway bar. This is not that tough, people have been towing for years and have already blazed all these trails.
Old 05-15-2016, 01:21 PM   #24
Originally Posted by ZachO View Post
I don't think any of those would work with my anti-sway bar. It has one of these coming off my mount, so a ball permanently mounted on the hitch isn't going to work. I need to be able to mount that between the ball and ball mount.
The mount I have is 2" drop, 1" rise (or 3/4" depending on what description you look at...) so I need something more flat than that.
Jon, do you know where you got yours? I think I saw something like what I want but it was for a 2 1/2" hitch I think...
Try WalMart's RV section. Or, a trailer shop. Or a Farm & Home store. they have a good selection of hitches and balls. Ya pays your money and takes your pick!
Old 05-15-2016, 02:04 PM   #25
ZachO's Avatar
Trailer: Sasquatch
Montana
Alright, thanks everyone. Looks like I have some options. I haven't checked local shops yet only because I feel like if there were an already manufactured mount like what I'm looking for, it would be on etrailer or the internet in general. Since I don't see one, I have trouble believing a local shop would have one. But a local shop could definitely fabricate one. That's a good suggestion.
I'll bet my 1" (or 3/4") rise mount will be perfect once I put 15" wheels on the trailer. But my current tires are brand new so that'll be a little while.
Carol, the adjustable mount you mentioned would probably work. For some reason I don't like those...but I should probably just get over it
For the back of the trailer being high vs low, I can say that low isn't good. My experience with towing the trailer home when I first bought it is that with the weight to the back of the trailer, it kind of "drifts" a lot. It bounces around on it's own, pulls back against the truck, and is generally less stable. It's kind of just floating there on it's own, almost at times pulling up on the ball/truck.
When leaning forward, it's not just floating on its own suspension. It's also leaning on the ball so there's another point of contact, and more stability. Like people mentioned, too much of that and it's starting to lift the front of the tow vehicle and that isn't good either.
So in my mind and limited experience, the advice to tow flat or leaning slightly forward makes the most sense.
Old 05-15-2016, 06:32 PM   #26
Mike Magee's Avatar
Oh, I know what you need: a bit more rear-end sag on the truck! Just load a couple of sand bags back there and the trailer will be level!
Old 05-15-2016, 07:39 PM   #27
ZachO's Avatar
Trailer: Sasquatch
Montana
Yep Actually if I just took out my rear air bags I'd be all set...But no thanks.
Old 05-15-2016, 08:06 PM   #28
Trailer: 2016 13Ft Scamp
2016 13 ft SCAMP
Scamp says that for a Scamp13 the height should be 18" to the top of the ball.
Mine is 14 inch to the top of the ball to be level.
I found a lot of what is in scamp video is wrong.
EugeneFlorida is offline   Reply With Quote
Drop bar ball mount for Triple e SurfsideEd Towing, Hitching, Axles and Running Gear 14 04-06-2014 05:44 PM
21" to top of ball ? FlyboyTJ Towing, Hitching, Axles and Running Gear 14 06-17-2012 06:52 PM
Ball Mount For a Bike Rack Steve L. Problem Solving | Owners Helping Owners 7 12-10-2008 10:31 PM
For Sale - Extra Long Ball Mount Jim in MI Classified Archives 0 08-19-2007 07:49 AM
want to buy drop in stove or top Maggie O. Classified Archives 2 04-07-2006 12:33 PM
