Abnormal tire wear. - Page 2 - Fiberglass RV
Old 02-02-2016, 12:44 PM   #15
madjack's Avatar
Trailer: 2015 Casita 17FD
Rapides Parish La.
It has been long while since that was conventional wisdom. radials now use normal rotation methods.
...could well be BUT I'm an old fart and find tried and true is, well, tried and true...back when I was younger and poorer, I often bought used tires and many times had a steel belt break and blow out the tire...in talking with tire guys at the time, I was told the left/right, front/back thing and never had a belt break on a properly(to the tire guys) installed tire...I'll keep on keepin' on...YMMV and happy camping to us all...............
madjack
madjack is offline   Reply With Quote
Old 02-02-2016, 01:14 PM   #16
BillE's Avatar
Trailer: 2016 Scamp 13 Deluxe Birch w/front dinette
Wisconsin
Listen to Floyd
That is correct sir
A three egg family..
(2) Big Green Eggs for cooking..(1) Egg for camping
BillE is offline   Reply With Quote
Old 02-02-2016, 02:03 PM   #17
Trailer: 2008 Casita 17 SD
If you are getting scuffed tread on the inside of one wheel and the outside of the other, I'd bet dollars to donuts that your axle itself is fine. They just did a crummy job of attaching it to the trailer frame. I'll bet that the side that is scuffing the outside tread is closer to the trailer ball than the one scuffing on the inside tread. Your axle wasn't properly aligned and mounted perfectly perpendicular to the trailer center line at the factory.
abnormal tire wear on Scamp 16 beardrum Towing, Hitching, Axles and Running Gear 31 07-13-2015 01:00 PM
tire wear gregshannon Towing, Hitching, Axles and Running Gear 15 08-13-2007 01:29 PM
tire wear Chris Z Towing, Hitching, Axles and Running Gear 6 06-27-2006 02:21 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 27 04-16-2003 10:02 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 1 04-14-2003 11:32 PM
