abnormal tire wear on Scamp 16 - Page 3 - Fiberglass RV
Old 07-11-2015, 05:04 PM   #29
I believe that is normal "Camber" built into the axle by the MFG. It's common in all of the ridged trailer axles I have ever worked with. Think about what the back wheels of an old VW Beetle looks like.
Check with the mfg and ask how much "Space" should be in the middle of the straight edge.
Old 07-11-2015, 09:45 PM   #30
CampyTime's Avatar
Trailer: Scamp 13' Standard
I've been reading this thread with great interest and have to ask a few questions out of sheer curiosity. First off, I was under the impression that it is normal for the torsion axle (like my Dexter 2200 lb) to be sort of bowed in the middle? I don't know why?
Second, I've read here about alignment. Is aligning a trailer the same as one gets for a vehicle? That is to have the proper camber and tow? Then is getting a trailer aligned something one does when it is observed that it's dog legging or not towing right, or in this case, eating tires? Or is this a periodic maintenance thing one should just "do." I also am not sure if some stickies have torsion axles...doubt if many RV shops around here would have any experience at all with a FG trailer.
One gets a vehicle aligned here in NY more often than desired due to horrific winters and the aftermath of pot holes (ouch) fallen into in spring. Vehicle starts pulling one way or another...yuck.
Another question: does/should one rotate tires on a trailer after so many miles (like one does with a vehicle, every couple of oil changes or so)?
Thank you very much for the post and the opportunity for learning that it brings, but I am sorry for your tire troubles. I hope it's nothing too serious or expensive and that all will be well soon.
Wendy
Old 07-11-2015, 11:44 PM   #31
Borrego Dave's Avatar
Trailer: Casita SD17 2006
A lot of trailers have torsion axles. If your trailer is dog legging the axle has moved out of alignment on the frame on one side from square to the tongue. As far as camber and tow, it can be knocked out by hitting a curb or a good hole, bummer.
Old 07-13-2015, 01:00 PM   #32
CampyTime's Avatar
Thank you Dave. So, if there were no axle issues, such as in dog legging, if you simply had an issue of camber or tow in/out, might the trailer tow in a certain way to alert you that something is amiss?
Also, if one goes to an rv shop, do they correct camber or tow to Scamp's specs, or the specs called for by the Dexter axle?
Scamp tire wear Myron Leski Towing, Hitching, Axles and Running Gear 61 03-22-2018 12:01 AM
tire wear gregshannon Towing, Hitching, Axles and Running Gear 15 08-13-2007 01:29 PM
tire wear Chris Z Towing, Hitching, Axles and Running Gear 6 06-27-2006 02:21 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 27 04-16-2003 10:02 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 1 04-14-2003 11:32 PM
