Adding brake controller on 2015 Nissan Frontier - Fiberglass RV
Old 01-08-2016, 02:51 PM   #1
DougOlson's Avatar
Anyone out there using a 2015 Nissan Frontier with brake controller?
My Frontier has the factory installed hitch & tow package with 7-wire connector for the trailer. It is supposed to be wired for a brake controller and I have the short 2 plug wiring adapter and Tekonsha P3 controller. However, looking under the dash there are no loose connectors for the Tekonsha adapter to connect to. I do notice, however that there are two switches with connectors attached to the brake pedal and perhaps I should just plug into one of those.
Thanks.
DougOlson is offline   Reply With Quote
Old 01-08-2016, 03:12 PM   #2
If it were me, I would either contact the Nissan dealer or Tekonsha directly. Both should be able to give you everything you need to know.
Old 01-08-2016, 03:15 PM   #3
Dennis mn's Avatar
My Frontier is a 2014, but I understand that there were no significant changes from on year to the next. The dealer installed my Prodogy controller with the same pigtail you have. The pigtail goes between the controller to a plug at the right side of the steering column, near the bottom edge of the instrument panel. It was a simple plug and play!
2019 Airstream 19 Foot, pulled by a 2014 Nissan Frontier Pro4-X Crew Cab.
Dennis mn is offline   Reply With Quote
Old 01-08-2016, 03:17 PM   #4
Or etrailer.
In fact I think etrailer gets it right more often than the car dealers do.
Old 01-09-2016, 10:58 AM   #5
The MANUAL....
Old 01-09-2016, 01:11 PM   #6
Trailer: Winnebago
on my 2011 xterra the brake controller wiring harness goes in the vicinity of the center console - had to remove a panel as I recall.
it is plug and play. you will probably have to get the new harness at a nissan dealer.
DanoFL is offline   Reply With Quote
Old 01-09-2016, 01:13 PM   #7
Trailer: Winnebago
if you send me an email address, I can send you instructions for an older nissan
Old 01-09-2016, 01:15 PM   #8
Trailer: Winnebago
or read: https://www.etrailer.com/vm/Nissan/Frontier/bc
Old 01-09-2016, 02:40 PM   #9
DeanCHS1980's Avatar
Kentucky
Doug,
I just installed a Prodigy P3 on our '09 Kia Borrego. I could not find the pigtail. After about three times looking, I removed the left-hand kick panel in the general location of where it was supposed to be. Sure enough, it was tucked in behind panel. Once I got it out, it was "plug n play".
Wish ya the best,
Dean
Laura & Dean | '05 Casita 17' FD | '09 Kia Borrego Limited V8 2WD
DeanCHS1980 is offline   Reply With Quote
Old 01-09-2016, 02:47 PM   #10
On my Frontier the connection was just above the gas pedal under the dash. Its a small white square plastic plug in connection. Mine had lots of extra cable that was all wrapped up and zipped tied to another item to sitting fairly high up under the dash.
Once you find it, the install is a very simple plug and play.
Old 01-09-2016, 03:28 PM   #11
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
I had same issue with my 2015 tacoma... Had to remove the panel on left side by brake pedal and poke around before i found it... Sort of have to be a contortionist
alan H is online now   Reply With Quote
Old 01-09-2016, 05:16 PM   #12
Raz
Raz's Avatar
Vermont
Should be there. As I recall mine was wrapped in green tape. You'll find it. Raz
Old 01-10-2016, 06:53 PM   #13
DougOlson's Avatar
Thanks for the info. I found it just where you other Nissan folks said, right of the steering wheel tucked up fairly high. I could not see it from underneath the dash but was easy to find after removing the lower panel below the steering wheel. The Tekonsha instructions, supposed to be for Nissan, showed the connector on the left side "near the emergency brake pedal", and was dated 2004.
Sent from my SM-T310 using Fiberglass RV mobile app
Old 01-10-2016, 06:58 PM   #14
Kentucky
Hi Doug,
Glad you found it. I think finding the vechicle's brake controller pigtail is a rite of passage for many of us!
Dean
My ParkLiner's (New to me) 2010 Nissan Frontier deryk Towing, Hitching, Axles and Running Gear 29 01-10-2014 06:50 AM
Nissan Frontier Wired and Hitched Raz Towing, Hitching, Axles and Running Gear 19 05-09-2013 04:05 AM
Anyone towing a 16' with Nissan Frontier? Michael D Towing, Hitching, Axles and Running Gear 5 11-16-2009 11:20 AM
Nissan Frontier 4Cyl - Camper Options Darral T. Towing, Hitching, Axles and Running Gear 30 09-15-2009 08:20 PM
Will Nissan Frontier Short Bed tow 5th wheel Scamp?? Betty L. Towing, Hitching, Axles and Running Gear 6 02-03-2007 05:22 PM
