Adding brakes - Page 2 - Fiberglass RV
Old 06-06-2007, 11:49 AM   #15
Pete Dumbleton's Avatar
Joy, I think you meant drums and hubs, not spindles. The new hubs are an integral part of the brake drums (which are the most expensive part of adding brakes) and the old hubs are discarded.
The spindles are an integral part of the axle, to which the brake flanges are welded before the liquid nitrogen assembly process, so spindle replacement on a torsion axle means entire axle replacement.
I am sure of this because I had to replace my axle because one spindle was damaged by a bad bearing (my fault for not lubing).
Old 06-07-2007, 02:52 PM   #16
Brian B-P's Avatar
Sure, while some axles have bolt-on spindles, the typical Torflex is a welded unit as Pete describes, so separately replacing the spindles in that case is nonsensical. If "Scamp" always implies "Torflex", then Joy must not have separately replaceable spindles.
My only problem with this interpretation is that a pair of Dexter drum/hubs would need to be gold-plated to be worth US$212, so I was guessing there were more parts in this case. Maybe it's just that the bearings were bundled with the drums?
Old 06-12-2007, 02:14 PM   #17
Brian, my drum-hubs, from Scamp, did include the bearings with the appropriate parts already pressed in, lubed and ready to slip onto a clean spindle. For some reason, likely quantity, the 7" brakes used on 13' trailers cost more than the 10" brakes used on larger trailers and they are not inexpensive (for some reason, Scamp no longer lists the drum-hubs in their price list).
brakes
adding battery April Wilcox Problem Solving | Owners Helping Owners 5 09-26-2008 11:39 PM
Adding brakes? Dorothy Rissel Towing, Hitching, Axles and Running Gear 14 10-24-2007 05:59 PM
adding a pop-top? Doug Herr Problem Solving | Owners Helping Owners 3 07-16-2007 10:04 PM
Adding electric brakes? Carol A. Care and Feeding of Molded Fiberglass Trailers 19 06-14-2006 11:03 PM
Adding brakes to Scamp Quint Care and Feeding of Molded Fiberglass Trailers 27 01-26-2006 07:07 AM
