"Adjustable" axle? - Info requested - Fiberglass RV
Old 05-18-2010, 01:31 PM   #1
KarenH's Avatar
Trailer: 1975 Boler 1300 TV 2009 Mazda Tribute, 4 cyl, 5 spd trans.
Thumbs up
Am buying a new axle for my (new to me) 1975 Boler 1300. The Montreal based axle company says I don't need to specify angle, or 'up/down', as the axle is adjustable. The axle has 9 different settings, with starting angles ranging from 10 degrees up from horizontal to 45 degrees down from horizontal.
It will be bolted onto the frame with reinforced brackets.
What do you know about 'adjustable' axles?
Does this description make sense?
And, if I wanted the Boler to be a bit higher off the ground, should I ask that something be done at same time as axle is changed?
Thanks for help here.
KarenH is offline   Reply With Quote
Old 05-18-2010, 02:02 PM   #2
Trailer: 2 American Bolers
Connecticut
Post
Hi Karen
Is this a Flexride axle ?
If so , They're works very well.
JEAN-L is online now   Reply With Quote
Old 05-18-2010, 02:11 PM   #3
KarenH's Avatar
Hi Karen
Yes, it's a flexride they're recommending. Evidently that's similar to what was on it, which was likely a Dexter. I could get a Dexter, but it would take 2 weeks to get it here, and the Flexiride is made in Montreal, near to me.
Did you change your old axle for a flexride, or did it come that way?
Old 05-18-2010, 04:10 PM   #4
Connecticut
Post
Hi Karen
Yes ,we did and we went from leading arms suspension to trailing arms witch
raise our camper by 2 3/8 " ride much better and easier Jean-L
Old 05-18-2010, 05:10 PM   #5
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
jean L.....a boler in CT...cool, never seen one here
Bruce Thomas is offline   Reply With Quote
Old 05-19-2010, 07:58 AM   #6
Michel, Bouchard's Avatar
Trailer: Boler 1300 1973
Quebec
Hi KarenH, I had mine replaced 2 weeks ago with Flexride, it worked pretty well. I did put some information under the following topic: Boler 1300 axle replacement.
Boler 1300 1973
Jeep Wrangler 2dr 2012
Michel, Bouchard is offline   Reply With Quote
Old 05-19-2010, 08:07 AM   #7
KarenH's Avatar
Bonjour Michel -
is your new axle 'adjustable'? did you have to chose between 'leading edge' and trailing edge'?
thank you,
Karen
Old 05-19-2010, 09:09 AM   #8
Quebec
Salut, , yes Flexride axles are adjustable. They installed it in a leading configuration like the previous Dexter. The previous one was welded, they did some modification and re-enforcement to the frame to have it bolted on this time.
They made the installation with a 24 degree down angle (it is adjustable in 6 degrees increaments/decreaments). Previously when levelled, the bumper at the rear of the Boler was at 6 1/2 inches from the ground, now it's at 13 inches. This is how I wanted it.
Just make sure that they take into account, at the installation, that the arms of the Flexride are a little bit shorter than the Dexter ones, so to have the wheels centered, the axle is installed a little more close to the front in leading arm configuration.
I had electrical brakes installed at the same time.
I didn't knew that they were assembled in Montreal, that is why they got it 2 days later only !
Boler 1300 1973
Old 05-19-2010, 09:49 AM   #9
KarenH's Avatar
Thanks Michel -
More info found at http://www.ucfamerica.com/Flexiride%20Tech...20Questions.pdf
p. 8 and 9 especially helpful.
It seems to say that you can order a certain starting angle from the manufacturer, then adjust later.
Does this make sense to people with axle experience?
Michel, you had yours installed at the 24 down; so yours should ride horizontal when fully loaded, right? does it? Does that mean that it would ride higher when empty?
(And, the Montreal manufacturer is entreprise Robert Thibert. 1-877-510 3222)
Old 05-19-2010, 02:34 PM   #10
Quebec
When empty, it leans a little bit towards the front (may be front to rear of the Boler by 1 inch), when loaded it is almost horizontal, still leaning a little bit towards the front, but very little, which is perfect. Mind you I put almost everything under the front bunk, I put almost anything under the rear bunks, and my battery over the tongue must weight about 60 pounds.
My 2006 Suzuki GV is not a tall 4x4, but with the Boler setup like this, it makes a perfect ride.
Some people like the old low riding look of the Boler, it is not any more, it looks almost ready to go 4x4 also, which is again perfect for us, since we go often in the ZECs to go fishing, and these roads are often not easy.
Regards
Boler 1300 1973
Old 05-19-2010, 03:48 PM   #11
Trailer:
Installing a torsion axle in a leading arm orientation seems to be dislikled or doubted by many folks ("it will spontaneously burst into flames", etc, etc), but clearly there are many eggs that have worked fine for decades with axles that way round, and Dexter confirmed to me recently that they don't mind leading arm orientation being used. Their one concern is that users know to swap brakes from one side to the other (on a new axle) so that they are rotating the correct way.
However.... I believe that combining a leading arm orientation and a down static/start angle (ie, that lifts the trailer) may be undesirable. The problem is that if the axle gets a shock load that is backwards and upwards - for example, when driving over a kerb (oops, 'curb') - the axle will be locked almost solid and the shock will be carried straight to the frame/body.
In all the old trailers with leading arms, they always seem to use an up start angle (ie, a low-riding trailer) and that angle provided the suspension compliance, so that's why they worked OK.
I can't say that combining leading arm and down angle won't work - just that it might not work. You pays yer money and you takes yer choice....
Andrew
Old 05-19-2010, 04:24 PM   #12
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Yes, Michel makes an important point. The Flexride arms are sometimes shorter than the Dexter, as I found out last year when I was replacing my axle, so if you are replacing a bolt-on axle the wheels may not be in the centre of the wheel well at the bolt holes. If you are going to weld it on, then it can be put anywhere. Also, the torsion bar on the Flexride axle turned out to be too big to fit behind the drop floor on my 74 Boler, which meant that the holes for bolting on did not line up as the torsion bar was jammed up against the back of the dropped floor underneath the trailer. I would suggest that you make sure that the people building your axle know about these issues and can deal with them.
Good luck,
Rick G.
Rick G is offline   Reply With Quote
Old 05-19-2010, 04:59 PM   #13
Quebec
You are right that this configuration is not optimal, I fully agree with you. And to top it off, Dexter told the company who installed mine that they didn't mind also, but that the warranty would be voided if installed in leading arm configuration
That is the reason why they suggested me to go with the Flexride axle, that the company will honor the 5 years warranty in that particular configuration, but to not exceed that 24 degree start angle with 175/80-R13 tires. This may be due to the fact that the arms are shorter than the Dexter ones and more close to the center of the wheel ? God knows, I'm not a mechanical engineer that studied these things.
But with the third world bad roads that we have here, I can say that it is working fine, and I must say that you are most probably right that the stress will be greater and will probably shorten the life of the axle, still with the 5 years warranty I don't worry much.
Good food for thought, thanks Andrew.
Regards
Boler 1300 1973
Old 05-19-2010, 05:25 PM   #14
Quebec
Rick, I'm glad you talked about
, you are absolutely right, and didn't express myself correctly, you cannot fully recover this, I knew and told the installer, but they knew as well and prevented me about it. Even if they modified my Boler's frame to have the new axle bolted on, there was no way to prevent this, unless you go with trailing arms setup, as you said the axle is against the sub-floor frame.
Before the installation they showed me where the wheels would stand. The difference wasn't big enough for me to worry and the wheels are still far enough from the wheel well to hit it.
Also it didn't really changed the center of gravity as I have only 5 lbs more on the tongue.
As a reference here is a picture.
Boler 1300 1973
axle
SOLD - 1970 Boler on "Ebay" 10 hours/ 20 Minutes left Dave Baston Classified Archives 5 04-12-2009 10:45 AM
INFO RE Fiberglass "Travel Lite" Trailers of Early 60s Don Cordier General Chat 4 07-23-2008 11:18 AM
OK viewers... it's time to play "Guess That Axle" Kevin Woods Towing, Hitching, Axles and Running Gear 16 07-08-2007 05:28 PM
"The Egg" info? JimB General Chat 15 03-22-2006 06:24 PM
