Advisibility of using weight distribution hitch: pros and cons - Page 14 - Fiberglass RV
Old 01-15-2013, 09:40 PM   #183
deryk's Avatar
New Jersey
Originally Posted by Glenn Baglo View Post
Why not start by shortening up that stinger?
stinger?
Old 01-15-2013, 09:42 PM   #184
This is the best I can come up with to illustrate my hitch set up.
The WDH was installed so that the trailer with its high-lift axle would ride level. You can see ( I hope ) how close the ball is to the bumper.
Old 01-15-2013, 09:49 PM   #185
deryk's Avatar
New Jersey
I got a new hitch, naturally they didnt have the right sized ball so I will have to remove the old one and put it on... its about 5" closer to the receiver then the other one.
Although this 1 would get it even closer...http://www.etrailer.com/Ball-Mounts/...tch/80213.html
Old 01-16-2013, 07:24 AM   #186
deryk's Avatar
New Jersey
Called etrailer today and asked eta for delivery and after a lengthy hold was told its on a 3 week manuf backorder... called 3 other places from google searches that their merchandise ships from the manuf warehouses, till I found someone on ebay who checked they have 4 on their shelf.
Order placed!
deryk
Old 01-16-2013, 09:53 AM   #187
deryk's Avatar
New Jersey
Also ordered a shorter ball hitch Curt 2" Receiver Heavy Duty Trailer Hitch Ball Mount 8" Drop 6 3 4" Rise | eBay
Hopefully the shorter ball hitch and the airbags will remove the squat
deryk
Old 01-16-2013, 10:33 AM   #188
MC1
MC1's Avatar
deryk
Much Better!
Old 01-16-2013, 10:39 AM   #189
deryk's Avatar
New Jersey
Thanks! It was the shortest one with a good rise height on it. Even if with airbags my rav4 stays at the 9.75" from ground to the bottom of the receiver I need some extra height with the center style tongue jack sitting lower cause my ParkLine will be traveling off road with me alot and dont want the jack to bottom out lol
deryk
Old 01-16-2013, 11:47 AM   #190
cpaharley2008's Avatar
If the jack is the problem then you can fix that easily. Go to ETrailer and look at their tongue jacks and the specifications. I had one that was too low and I replaced it with a shorter one problem solved. You want your trailer to be level, if it scrapes then change the jack but do not raise the trailer tongue to compensate for an incorrect jack. Parkliner's stock jack may be set up for a truck and may be too low for your vehicle and needs to be changed.
Old 01-16-2013, 11:57 AM   #191
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Um....Jim?
Since Deryk's problem is related to sag when he's hooked up to the tow vehicle, I'm not thinking a new tongue jack is going to help...unless it's got a highway tire on the foot!
Francesca
Old 01-16-2013, 12:00 PM   #192
deryk's Avatar
New Jersey
Well part of my problem is the sag, but I agree with Jim, it is possible that the jack was picked based on a vehicle whose rear is taller then my rav4's is.
deryk
Old 01-16-2013, 12:25 PM   #193
I think he has 2 issues, both sag and low jack
Old 01-16-2013, 12:48 PM   #194
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
The dang coupler can only be at one hgt from ground on relatively level ground with no major discontinuties ( like a pungee pit where the jack foot is located) to produce a level frame and trailer. Admittedly, parked on a big slope with the trailer headed downslope, it is possible to run out elevation on the jack before the coupler is above the ball, necessitating the trick of maxing the tongue jack, placing screw jacks on the frame to hold the hgt., retracting the tongue jack and blocking under the foot to give the jack sufficient lift. Most tongue jacks leave a couple of inches under the frame where the tilting foot or dolly wheel is x-pinned. I'm burning a cell or two over this jack biz but I still think the RAV constitutes the problem.
jack
Old 01-16-2013, 12:53 PM   #195
Jack,
A quick check at Etrailer's tongue jack page shows 5 jacks with the retracted height anywhere from 11" to 5", so that is a big range. Once Deryk gets his trailer level and no squat, then he may want to change the jack if it is too close to the ground. I must have 3 jacks in my garage from trailers that were to low when properly hooked up.
But I must say, the picture shows a very high mounting location. I'm surprised that Parkliner is at 16.5 . The Escape 19 is 21" high or 3.5" difference.
Old 01-16-2013, 01:05 PM   #196
I get it...I think...
Are these all A-frame jacks? If so, and access to tailgate/back tug door is also a problem, I highly recommend replacement with a side-mount swivel jack, available in various heights/throws.
I love being able to open the back hatch on my Kia all the way!
Francesca
Weight distribution mod for hitch ostojo Towing, Hitching, Axles and Running Gear 42 11-11-2012 11:59 PM
For Sale: e2 Weight Distribution Hitch for sale Keith Williams Parts: Buy | Sell | Trade 0 05-26-2012 05:59 PM
Weight distribution hitch Gene Masse Towing, Hitching, Axles and Running Gear 9 05-14-2012 07:05 PM
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
