Advisibility of using weight distribution hitch: pros and cons - Page 7 - Fiberglass RV
Old 01-12-2013, 04:12 PM   #85
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I concede the distinction between bumper pull and bumper hitch, Francesca. The chunk of iron protruding from Deryk's receiver is comparable to the analogous piece of a WDH, namely the chunk of iron which sticks out of the receiver and to which the trunnion head is thru bolted but it is NOT a WHD. The triangular welded gusset is what makes this stinger/rowboat anchor look so beefy. There are no spring rods and no chain levers or other lift mech. on the tongue members. Hey, I know, we could ask Deryk!
jack
Old 01-12-2013, 04:19 PM   #86
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
O.K.!
HEY DERYK!!!!!
In case you think I wasn't asking you about your hitch setup, would you mind going back and looking at post number 83 I where mention my confusion about your hitch setup and hope for a closer look but without asking you a direct question?
THANKS!
Francesca
Old 01-12-2013, 05:08 PM   #87
Originally Posted by David Tilston View Post
I'd say the squatting has something to do with that long "stinger".
Or it could be that Toyota has just put to soft a back end in the RAV4 for some mystical reason.
A couple of summers ago I traveled down the coast to the Bandon meet with a nice couple from Quebec who had just picked up a brand new Escape. He told me that he had air bags added to his then new RAV4, prior to picking up the trailer having read on a number of forums that RAV4's tended to squat more than one might expect based on tow capacity. He was very happy with the way the tug and trailer handled, if thats of any help to Deryk in regards to whether or not he has made the right choose to go with air bags.
Old 01-12-2013, 05:11 PM   #88
rabbit's Avatar
Delaware
Or it could be that Honda has just put to soft a back end in the RAV4 for some mystical reason.
Didn't know the Toys had Honda suspensions. Live and Learn
jack
Old 01-12-2013, 05:12 PM   #89
Industrial sabotage, eh?
Well, that explains it...wonder how they got in to the Toyota factory?
Francesca
Old 01-12-2013, 05:23 PM   #90
jack
sorry my error! Edited to correct. Got distracted re makes, as I was just looking at a letter in regards to a Honda parked in my driveway that apparently needs soom attention.
Old 01-12-2013, 05:25 PM   #91
That Honda prolly belongs to a bunch of saboteurs hiding from the Toyota Security Team ...
Francesca
Old 01-12-2013, 05:47 PM   #92
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Which confirms my suspicions. A wd hitch is meant to help a vehicle with a front/rear suspension already designed to adequately take the weight, but isn't balanced front/rear. (*Most* anything with a trailer is going to squat some.) If a rear suspension is too soft, then a wd hitch is only going to put excess load on the front of the tow vehicle and the trailer axle, making them support weight that the rear should be carrying. Air bags to help support the weight
Old 01-12-2013, 05:53 PM   #93
I've always had a tough time with this concept...
Can someone explain to me how, exactly, airbags "support weight" ??? Are they a substitute for what perhaps should have been a beefier suspension to begin with???
Thanks!
Francesca
Old 01-12-2013, 06:18 PM   #94
rabbit's Avatar
Delaware
Yes.
jack
Old 01-12-2013, 08:48 PM   #95
deryk's Avatar
New Jersey
Well just getting home from removeing my parents old garage door opener and installing the new one I bought for them for christmas...took a few hours longer then I expected... oh well
Ok, so the hitch Im useing is this one 8-in-1 Adjustable Ball Mount Hitch
I have it right about in the middle, I had a 2" drop upside down to give me a 2" rise because the trailer I built was sitting pretty low, and I take it off roading to a spot I camp at a lot up a dirt gravel road up the side of a mountain... beautifal spot but the hitch Im useing now, adjusted about halfway up gives it sufficient lift and I doubt its sticking that much further out then a 4" rise type. I dont want it too close that its gonna hit my tire cover (which I dont plan on removeing) and its nice to be able to raise it up higher or lower as the situation warrants.
The safety chains on my parkliner are attached behind the jack... I'd prefer it in front of it, specially with the frame mounted tow hitch, the spot to connect the chains to is kinda underneath a bit so I do need to measure it and replace the chains...
The airbags should alleviate the problem of the rear springs, that plus once I get some weight on the other side of the axle, There was 2- 20lb propane tanks mostly full and the rest of the trailer was empty.
When they comein and I can install the airbags, I will have to take a ride down to my friends house where my ParkLiner is at but probably wont be able to get down there for at least 3 weeks do to me donateing my time for our school's play (helpin build the sets) ad cooking for a firemans charity dinner... I usually try to keep busy jan-early april or I sit and play on the computer too much lol
deryk
Old 01-12-2013, 09:14 PM   #96
rabbit's Avatar
Delaware
Thanks for putting a name to it, Deryk. And you're a good son.
jack
Old 01-12-2013, 09:29 PM   #97
deryk's Avatar
New Jersey
Thanks Jack, yeah Im sensing my own mortality seeing my parents getting older...I just wont do the sit at home and watch reruns all day...I want to seek out some adventure and good times!
From looking at the measurements I might be able to get the ball a little closer with a 4" rise type hitch but Im not spending a penney untill I get the airbags installed and get to hook it up and measure it. Most rav4 owners do go with the airbags... and for larger trailers add a wdh... we shall see, we shall see
deryk
Old 01-12-2013, 10:11 PM   #98
hotfishtacos's Avatar
Trailer: 2012 Escape 19' /2010 Honda Pilot 4WD TV
Escondido, California
Originally Posted by Jim Bennett View Post
That said, I tow my Escape 19 with my Pilot, and do not use a WDH. Only on rough gravel uphills have I ever had a bit of an issue with slippage, though nothing that worried me at all. The later model Pilot ('09 and up) come equipped to tow with the hitch being standard, and nice stiff rear ends. I have the touring model that was just plug n' play.
I pull my 19' Escape with a 2010 4WD Honda Pilot and use a WDH because I wanted to be able to tow my trailer off-road or anywhere under any condition and not worry about traction. My front wheel drive (normally) Pilot pulls the trailer like it isn't there and the WDH keeps the whole package level and very stable. It is an Equal-I-Zer hitch and is very heavy but I really like my setup and have no sway issues either.
"No Generators"
hotfishtacos is offline   Reply With Quote
Weight distribution mod for hitch ostojo Towing, Hitching, Axles and Running Gear 42 11-11-2012 11:59 PM
For Sale: e2 Weight Distribution Hitch for sale Keith Williams Parts: Buy | Sell | Trade 0 05-26-2012 05:59 PM
Weight distribution hitch Gene Masse Towing, Hitching, Axles and Running Gear 9 05-14-2012 07:05 PM
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
