Advisibility of using weight distribution hitch: pros and cons - Fiberglass RV
Old 01-08-2013, 04:11 PM   #1
[NOTE: Posts below re: WDH digressed from original thread subject in which they appeared. "Post #24" contained mention of WDH only and was retained in original thread. New Thread title chosen by moderator. 01-10-2013]
Per post #24
What's a "Weight Reduction Hitch" and how does it work?
I wanna get one of those so I can pull a larger trailer with my Honda.
Old 01-08-2013, 04:15 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Bob Miller View Post
Per post #24
Old 01-08-2013, 04:24 PM   #3
deryk's Avatar
New Jersey
Per post #24
Well a weight distribution hitch will spread the tongue weight between the 2 axles. My Rav4 has a soft rear end meant to lure In the minivan moms lol. So the wdh will stop the rear end of my Rav4 from squatting. I am well within my tow capacity...if you look at my album you will see the picture with me hooked up with my drivers door open....the load would spread evenly and maybe drop it an inch not like 3 or 4.
deryk
Old 01-08-2013, 05:05 PM   #4
Trailer: 77 Scamp 13
Weight reduction may have meant weight distribution hitch which uses spring bars to transfer some of the hitch weight to the frame and thus the front wheels of the TV. Helps control the tendancy of the trailer to lift the TV front tires when braking.
Does not really increase towing capacity as much as it improves handling of the rated tow capacity.
Decent explanation bottom of this page:
Trailer Hitch & Towing Guide
Old 01-08-2013, 05:25 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Thomas G. View Post
Thassssssss right!
Francesca
Old 01-08-2013, 09:38 PM   #6
Bob, if before buying the Weight Distribution Hitch you might want to check your Honda's manual first. Some vehicle manufactures dont support the use of them on some models.
Old 01-08-2013, 10:55 PM   #7
Brian B-P's Avatar
Originally Posted by RogerDat View Post
Weight reduction may have meant weight distribution hitch which uses spring bars to transfer some of the hitch weight to the frame and thus the front wheels of the TV...
... and to the trailer axle. The proportion of load transferred to the tug front axle versus the trailer rear axle is determined solely by the ratio of the tug's wheelbase to the distance from rear axle to trailer axle.
The Class 3 and higher hitch class limits are all wrong in this page. The description of other features are questionable as well. The limits are not an opinion item: the classes are defined by VESC V-5 and SAE J684... but that's not why this link was provided.
The description on this page incorrectly omits load transfer to the trailer axle (as above). I think it's a poor description, but this is not the thread for a hitch discussion anyway.
Old 01-09-2013, 08:37 AM   #8
Hmmmm... I guess Francesca and I were the only ones that got the punch line about a "weight reduction" hitch. LOL (maybe?)
BTW: We use a Weight Distribution hitch with the Coleman 171 when it is connected to the Yukon TV, but not on the others trailers or TV's.
Old 01-09-2013, 08:43 AM   #9
deryk's Avatar
New Jersey
Sorry for the confusion... weight distribution hitch... although I am thinking of trying airbags... alot of ppl on the rav4 forum say it works fine for them and for $85 dollars or so its not so pricey... but then again an Anti sway bar would still be handy...
deryk
Old 01-09-2013, 09:16 AM   #10
totally missed that! Funny part is I actually took a second look at your profile as I thought it a bit odd of a question coming from you, based on trailer ownership.
Old 01-09-2013, 09:23 AM   #11
No problem Deryk, we were just havin' a little fun along the way....
Old 01-09-2013, 09:40 AM   #12
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
[OT] The air bags will do fine to stiffen the suspension, Deryk. Good savings; no risk to frame. [OT]
jack
Old 01-09-2013, 09:51 AM   #13
Was not trying to provide in depth info on selecting a hitch, just some clairification on WD hitch without making poster read really long article on the subject. Plus page had the cute image of trailer and TV with and without WDH!
Was intended to clarify that WDH allows for better control but does not really "increase tow capacity" by a significant amount as it is not a weight reduction hitch as originally called.
Left out the need to factor in the weight behind TV rear axle from cargo or passengers as part of the equation also. Or potential for anti-sway enhancement that it appears OP is aware of.
Old 01-09-2013, 11:25 AM   #14
David Tilston's Avatar
In regards to a weight distribution hitch, I was surprised by some corispondance I had with Tom Young, the owner of TrilliumRV. He in very clear terms told me not to use one. The frame of the trailer is not designed for it. As Brian B-P pointed out the weight is also distributed to the axle on the trailer and this puts quite a strain on the tongue of the trailer.
Air bags on your rear suspension make much more sense. That way when not towing, the air can be released and the mini van moms still enjoy the ride to soccer. It should be noted that air bags do not increase the towing capacity of your vehicle.
Weight distribution mod for hitch ostojo Towing, Hitching, Axles and Running Gear 42 11-11-2012 11:59 PM
For Sale: e2 Weight Distribution Hitch for sale Keith Williams Parts: Buy | Sell | Trade 0 05-26-2012 05:59 PM
Weight distribution hitch Gene Masse Towing, Hitching, Axles and Running Gear 9 05-14-2012 07:05 PM
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
