After-market light bar, visible brake light above rear window - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Towing, Hitching, Axles and Running Gear
Click Here to Login
Old 08-16-2015, 03:44 PM   #1
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
I've read here that most rear-enders on FGRV's have to do with the brake lights being so far down and not visible to drivers in larger vehicles (like 18-wheelers). Some of you have mentioned installing a brake light above the rear trailer window.
Can someone recommend one of these to me?
Thanks,
Ellpea
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 08-17-2015, 08:56 AM   #2
Trailer: 2015 17' Casita Independence, 2010 Escape 19’
Following.
TappyGee is offline   Reply With Quote
Old 08-17-2015, 09:05 AM   #3
Trailer: (Former) Casita 17 SD
Sounds like a necessary mod.
Elly G is offline   Reply With Quote
Old 08-17-2015, 09:42 AM   #4
Johnny M's Avatar
Deep South
Search the forums someone recently posted doing this with pictures, I believe it was Jay
Old 08-17-2015, 09:56 AM   #5
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I drilled a hole in the bottom of the trailer to access my tail light wires inside the back of my trailer. Then made a bracket to mount the 2 LED light bars. (No holes in outside fiberglass body.)
Old 08-17-2015, 10:32 AM   #6
Originally Posted by Johnny M View Post
Search the forums ....
http://www.fiberglassrv.com/forums/f...bar-70982.html
http://www.fiberglassrv.com/forums/f...rks-70675.html
http://www.fiberglassrv.com/forums/f...amp-67997.html
Old 08-17-2015, 10:39 AM   #7
Thanks,
Ellpea
How many rear end accidents have there been involving FGRVs?
Old 08-17-2015, 11:15 AM   #8
That statistic (fiberglass trailer specific) is not available so you will only get incidental reports. However you are welcome to read this report which states in part:
Rear-end crashes are the most frequently occurring type of collision, accounting for approximately 29 percent of all crashes and resulting in a substantial number of injuries and fatalities each year.
Better brake / tail light visibility will help in only a few cases, but enough that I ordered the optional second set of lights on my Scamp.
Old 08-17-2015, 11:28 AM   #9
Two mentioned on this forum that I know of. There is currently a ongoing thread on the rebuild of a Uhaul that had been rear ended. I'm working on a plan for high mount lights on our Uhaul. Did the Casita.
Old 08-17-2015, 11:54 AM   #10
Trailer:
I would question whether it really helps, other than the driver's peace of mind. It's not like any fiberglass trailer is too small to see and I would question if brake lights really have that much effect on a following driver that isn't paying attention.
High-level brake lights in autos got some good test results - but then they were a real novelty at the time, which was probably a bigger effect than the lights being more visible.
Old 08-17-2015, 12:16 PM   #11
Bruce H's Avatar
Trailer: Bigfoot 21 ft Front Bedroom
The brighter the brake lights the safer the vehicle.
Old 08-17-2015, 12:49 PM   #12
Originally Posted by Andrew Gibbens View Post
I would question whether it really helps, other than the driver's peace of mind. It's not like any fiberglass trailer is too small to see and I would question if brake lights really have that much effect on a following driver that isn't paying attention...
That is exactly my point.. most rear-enders are caused by drivers following too close, going too fast, being distracted, etc.
The best thing you can do is leave enough space so YOU don't get surprised and have to make a quick or panic stop... if you can decelerate at a slower rate that gives the guy behind you more time to react. But if you make a quick stop, that guy 10 feet behind you, going 60 MPG while texting, will hit you.
One time that having higher brake lights will help is when that same SOB following you too close is blocking the view of your low brake lights. That s the start of the chain reaction rear end collisions that often involve multiple vehicles.
(BTW, the tractor trailer is MORE likely to see your lower lights)
light
After Market "Boler" Parts for Sale kickerintogear Classified Archives 0 07-04-2011 09:47 AM
Pictures of your after market wheels iplumb Modifications, Alterations and Updates 15 05-27-2011 09:56 AM
Factory receivers vs after market Jim Witte Towing, Hitching, Axles and Running Gear 5 09-17-2010 11:43 AM
after market brakes 93 casita 16 liberty tracy.c Towing, Hitching, Axles and Running Gear 3 07-23-2007 06:23 PM
After market AC in Scamp Legacy Posts Problem Solving | Owners Helping Owners 5 06-13-2003 11:33 AM
» Trailer Showcase
Burro
Avey
Scamp
judy7212
