Aftermarket Tow Hitch - 08 Highlander Hybrid? - Fiberglass RV
Old 04-24-2014, 06:58 PM   #1
Trailer: In the market
Hi,
I'm looking to buy a used 2008 Toyota Highlander Hybrid that has an aftermarket tow hitch installed. I'll be hauling a 13' casita with it. The woman said she talked with her dealer about it when it was installed and they said it would work fine, but she was only hauling wood once or twice a year.
Does anyone know if this is going to be ok or will have to do more to the car if I buy it?
Thanks,
Anne
Anne in NW is offline   Reply With Quote
Old 04-24-2014, 08:34 PM   #2
A web site should be of interest to you Here. and here's some more information found by google search "towing capacity of toyota highlander hybrid".
3,500 pounds
The Toyota Highlander is rated at 1,500 pounds towing capacity. To Achieve the 3,500 pound capacity you have to have the factory installed tow package, largest engine and AWD. You cannot buy a Highlander without the factory tow package and make your vehicle rated to 3,500 pounds towing capacity.
Old 04-24-2014, 08:56 PM   #3
Mike Magee's Avatar
Trailer: Li'l Hauley
I bought my '08 (non-hybrid) HL over 6 years ago, so my memory of what all was included in the factory tow package is somewhat hazy. But I think the biggest thing was heavy duty cooling. If you look into adding an auxiliary transmission cooler (probably $200 or so), you should be good for towing most FG eggs. The cooler is a small radiator-looking thing that is mounted near the existing radiator and has flexible lines running to the tranny for the fluid to pass through and get cooled before returning.
I do recall clearly that the hitch receiver was not included in the tow package! Aftermarket hitch is just as good as a Toyota brand hitch, although the latter would have been mounted a bit higher to the bumper.
How to prepare Tofu
Step 2: grill some meat
Old 04-25-2014, 07:09 AM   #4
MC1
MC1's Avatar
You are looking at a very desirable vehicle which is highly rated.
This link below shows it has lots of power (270 HP) and a 3,500lb tow rating. A Toyota dealer should be able to verify by reviewing the VIN number. What information do you have on the aftermarket hitch that is installed. Class 1, 2, or 3?
2008 Toyota Highlander Hybrid Base 4dr SUV 3.3L V6 Hybrid AWD CVT Automatic Features and Specs
Aftermarket Wheels.. "Let's See Em " Phil Underwood Modifications, Alterations and Updates 73 07-16-2013 09:12 PM
Hitch requirements, Highlander Hybrid Deeanne E. Towing, Hitching, Axles and Running Gear 20 06-30-2013 11:51 PM
Hybrid Highlander for lightweight towing Ben Kadas Towing, Hitching, Axles and Running Gear 8 07-23-2010 03:20 PM
Dealer or aftermarket towing package? Ron Stewart Towing, Hitching, Axles and Running Gear 9 03-22-2009 10:40 PM
Highlander Hybrid Brake Controller ... Tim Garriock Problem Solving | Owners Helping Owners 5 07-28-2007 10:52 PM
