Aluminum Rims in Canada? - Fiberglass RV
Old 08-31-2009, 09:41 PM   #1
Trailer: Bigfoot 17 ft (15B17G)
Thumbs up
Hi again,
Axle swap is coming along nicely and now its time for new 15" rims. I'd like to go with a decent set of aluminum rims such as those found at Ricks Tire, however those are in the US.
Are there any Canadian places to get nice aluminum rims that DON'T cost an arm & leg ? I tried locally and the want $260/rim for the same $85rims at Ricks?
Where are Candajuns buying their rims?
Thanks, D
Dave_L is offline   Reply With Quote
Old 08-31-2009, 09:57 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
d'ya mean like these?
Old 08-31-2009, 10:25 PM   #3
yep, right along those lines. Need to be compatible with 50-60lbs pressure though
Old 08-31-2009, 10:30 PM   #4
Trailer: Former 1978 Trillium 4500 owner (now 2010 R-pod)
Canadian Tire sells a nice rim similar to Dougs
77 Trillium 4500
Phil 4500 is offline   Reply With Quote
Old 08-31-2009, 10:45 PM   #5
Trailer: 1979 Trillium 4500
I found mine at a junk yard. There not super nice but I like them. $20 bucks each with tires.... They actually only had three too.
Arthur Santiago is offline   Reply With Quote
Old 09-01-2009, 08:21 PM   #6
Trailer: 1976 Trillium 13 ft
I bought mine from a guy that was selling aftermarket rims off his ford ranger (mid 90s). The bolt pattern is the same.
Steve Foster is offline   Reply With Quote
Old 09-02-2009, 12:09 AM   #7
Trailer: 2000 Bigfoot 17 ft (15B17CB)
I could not find any aluminum trailer rims in Canada at a decent price so I just ordered from the U.S.
You are wise not to use automotive aluminum wheels, they are simply not designed for the tire pressures required and often have not nearly enough load capacity for trailer use. The smaller and lighter fiberglass trailers may be able to get away with automotive wheels, but a Bigfoot 17 is much too heavy for any aluminum automotive wheel. Finding a automotive wheel with same offset as trailer wheels can also be a problem.
I went with HiSpec Series03 aluminum trailer wheels, 15" X 6" 6 bolt rated at 2830lbs and 60psi on a 5200 lb straight axle. Any wheel and tire combination rated for greater than 2000 lbs should be fine for a 17 Bigfoot as some can approach 4000 lbs when loaded up. Personally, I am not too fond of running at the limit, and the old 3500lb axle and 14" wheel tire combination was less than adequate in my opinion.
Steve.
Steve C. is offline   Reply With Quote
Old 09-02-2009, 03:42 AM   #8
member
Trailer: Bigfoot Rear Queen 25 ft
Steve I guess I don't understand your comments on weight. I just googled a 2009 Ford Escape with 16 inch wheels and it's 4700 pounds then add a full tank of gas to bring that up to 5000 lbs then add four adults at 200 lbs that teeters on 6000 lbs...a 3400-4000 lb trailer on 15 inch wheels seems reasonable....
Please help me understand the weight issue.
Time K is offline   Reply With Quote
Old 09-02-2009, 08:29 AM   #9
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I saw some nice ones at Princess Auto here in Winnipeg. I think they were 189 with tire on. shame I just replaced mine with the white trailer type.
Scott S. is offline   Reply With Quote
Old 09-02-2009, 05:48 PM   #10
Steve.
That is looking like the route I'm going. Who did you order the HiSpecs through?
Kal Tire now has a trailer rim, but not in stock....Ricks Tire (Idaho) has decent prices as well as the Kumho 857s, may go with that setup?
Many car rims don't have the correct offset, some are not not rated for more than 40-50 PSI, where as trailer rims are designed for higher pressure. Just my .02$
Dave
Old 09-02-2009, 05:54 PM   #11
I'm guessing the rating of the 16" rims is much higher. The ones I saw were:
16" [at] ~3200 lbs/rim
15" [at] ~2500 lbs/rim
14" [at] ~1900 lbs/rim
You are also sharing the weight over 4 tires on an Escape whereas the 17ft Bigfoot is only 2 wheels to distribute the weight.
Old 09-02-2009, 07:15 PM   #12
member
OK, I guess that makes sense...thanks for the insight..but at 2500 per rim that's still way enough for a 17 isn't it?
Old 09-02-2009, 07:47 PM   #13
Hi Mike,
The example you mentioned only has 6000 lbs on 4 wheels, or roughly 1500lbs per wheel. A 4000lb Bigfoot will load it's 2 wheels at closer to 1850lbs each wheel when weight transfer from the WD hitch is factored in. If you start to search for aluminum automotive wheels with a compatible bolt pattern, you will find few or none with this load rating. You can of course, find some automotive rims and many truck rims that can handle this load, but they will have very different bolt patterns and offsets than the common trailer standards.
The other problem is that trailer tires with a high enough load rating will require up to 60lbs pressure, again most automotive rims are not designed or rated for this high a pressure.
This is of little concern to most other smaller fiberglass trailer owners, whose loaded trailers are less than 3000lbs. They are free to safely use pretty much any suitable sized rim that will bolt up.
The last time I actually weighed my Bigfoot at the end of a trip, it showed 3600lbs on the axle with an near empty water tank. Fully filled and loaded up, I am sure it would scale at 3900-4000lbs at the axle, which would imply a total weight of 4200 - 4300lbs as the tow vehicle is supporting some of the tongue weight. This also means each wheel would be supporting close to 2000lbs, assuming the load is centered (unlikely), and was the reason I upgraded my axle/suspension, wheels and tires.
I'm sure my unit is on the heavy side for a 17 Bigfoot, as it is well optioned out including an air conditioner, which adds another 120lbs or so. Even so, I doubt it is much more than 300lbs heavier than an average loaded 17 Bigfoot weight. I think the 80's 17 footers are somewhat lighter than average as their refrigerators were smaller and many came without an oven, awning or the extra fiberglass cowling over the propane tanks and spare tire. Options like Fantastic fans, day/night shades and skylights didn't even exist for the early models either, all which add to the total for newer models.
Bigfoot themselves even seemed to acknowledge the increasing gross weights in 2004, when they switched from 14 to 15 inch rims before abandoning the 17 for the new 2005 17.5 with a 4400lb GVW
Steve.
Old 09-02-2009, 10:30 PM   #14
Dave
I believe I ordered them from rjays.com, as they had good prices at the time and offered a choice of shipping methods to Canada.
The Kumho 857s have a good reputation, and would be a very good choice for 14" rims since they are load range D with excellent load capacity in the 205/R14 size. I think the HiSpec 14" trailer wheels are rated for 1900lbs, which should be OK. I went with 15" wheels, but I also installed a new straight axle which was a bit narrower than the original to ensure the 225/R15 tires would fit nicely inside the fender skirts.
Steve.
Old 09-04-2009, 02:04 PM   #15
Trailer: 1976 Boler 13 ft
Tires and rims are always half price in the US buy them there and bring them over the border yourself.
Dave
David Konduc is offline   Reply With Quote
Rims on a Trillium Randy Bishop Modifications, Alterations and Updates 32 04-11-2016 10:46 AM
Scamp rims: 4 lug Dan R General Chat 5 09-29-2008 01:05 PM
Surfside rims? kentj Problem Solving | Owners Helping Owners 5 12-27-2007 06:26 AM
New Rims Lainey Problem Solving | Owners Helping Owners 8 08-16-2007 01:40 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
