Andersen w/d hitch - Page 3 - Fiberglass RV
Old 04-29-2013, 04:14 PM   #29
Brian B-P's Avatar
Anyone who thinks the long wheelbase "Unlimited" Wrangler is bad for this pitching problem should try the regular/short wheelbase two-door model. I test drove one a few blocks once, and I don't think you could give me one free to drive! Not for me.
To be fair to the Wrangler, lots of vehicles have this problem on some roads, and it is very specific to the road. Our old Chev pickup was a standard cab shortbox, and much worse for this than anything else we have owned.
Old 04-29-2013, 04:56 PM   #30
Trailer: Scamp 16ft
Alabama
Well I've got 4 Jeeps corp"rats" killed of the XJ cherokees and Comanches. So I my new one was a Unlimited Wrangler(TJ).. But for what its worth my Wrangler rode better than the Crossfire when new. I'll stick with Jeeps w solid axles no IF for me.
Darrell in Al is offline   Reply With Quote
Old 05-22-2013, 06:34 PM   #31
Brian B-P's Avatar
Originally Posted by Mike Magee View Post
I've read of some very isolated situations where a couple of folks with Andersens and heavier trailers (who must cinch up those chains quite a bit) had a problem with their coupler. IIRC the pawl that keeps the socket on the ball got damaged, and the socket was riding up partway off the ball...
the heavier the tongue, the more one must tighten the Andersen's chains to distribute the weight. The chains draw the back of the socket tight against the back of the ball. The people who had problems (I only read of two, I think) had tongue weights much higher than ours. I kind of doubt that we would have such troubles with our lighter tongue weights, but I mention it in case you want to look at it from time to time.
I finally watched the videos on Andersen's web site, and in one the Andersen guy mentioned that with the spring blocks compressed 1/4" (probably quite a bit more than Jim needs for his Escape) each chain is under 2000 pounds of tension, so the coupler is pushed against the ball with 4000 pounds of force. A very thorough Andersen No-Sway user ("Bruce H.") posting in a topic in another forum measured between 500 and 600 pounds per chain in a setup sized in our range, transferring less than 100 pounds onto the tug's front axle. This is as expected from the geometry of the design and torque which must be applied to transfer load between axles. Consider that a Class 3 coupler (5000 lb trailer weight capacity) is only required to withstand 7500 pounds in that direction before breaking... this is a significant concern to me, and one of several reasons to adjust appropriately, and not overdo it.
A conventional spring bar WD also pushes hard on the ball, but downward and with a fraction of the force (for the same WD effect).
Old 05-27-2013, 05:26 AM   #32
MC1
MC1's Avatar
Like many prescription drugs on the market the Andrsn comes with many possible side effects.
Old 06-12-2013, 08:51 AM   #33
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I thought I would add my thoughts from the first use of my Andersen WDH to this post, rather than start my own. I finally got around to installing it, and gave it a good workout to Osoyoos and back.
Having towed lots since being a kid, trailers of all shapes and sizes, from semi-truck/trailer units, to farm equipment, to a few different travel trailers, to a measly air compressor. In that time I have never once used a WDH.
I also need to add that I never really felt the need with the 19 behind my Pilot. Adding bikes to the back last fall was the first time I ever felt a need to control sway. I do really need to double check my hight weight with that rear load, as it was likely a bit low.
I have done pretty much ALL of our towing of travel trailers, and would definitely want to get Lisa towing more. I wanted to make certain all the little nuances I feel but am not bothered by myself were minimized for her confidence. This is the main reason for the purchase.
My way of summing up the use of the Andersen WDH is that it does make the tow-trailer combo seem a bit more like one unit, as many of the little trailer idiosyncrasies, like a bit of sway, or a bit of bounce on big bumps, was minimized greatly.
I measured the wheelwell height on the Pilot before and after hooking up. The front came up 1/4", and the rear dropped 3/8". Of course, I could adjust this further, but was happy enough with the results. The ball didn't seem to drop at all, though likely did about 1/2". I did measure the hitch before, just not when hooked up yet.
It was pretty straightforward to set up, and took me about an hour to set the hitch up in the first place, then an additional 2 minutes every subsequent time was added to the hook-up routine.
BTW, Lisa drove quite a bit and did not have a single issue with towing. Not bad considering it was her first go at it. Heck, I had to get her to slow down a couple times, as she was pushing over 120 kph. I had even considered trying to get her to try backing in to a site, but thought that might be pushing our relationship a bit too much.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-12-2013, 10:06 AM   #34
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Jim Bennett View Post
..........I measured the wheelwell height on the Pilot before and after hooking up. The front came up 1/4", and the rear dropped 3/8". .........
I'm surprised that the front didn't go down and the rear come up.
Old 06-12-2013, 11:31 AM   #35
From everything I have read and been told, this is very acceptable. What I should do is to measure the differences with the hitch loaded, but no WDH to compare the differences. The front would definitely be higher than what it is with the WDH hitch.
2017 Escape 5.0 TA
Old 06-12-2013, 09:13 PM   #36
Mike Magee's Avatar
Trailer: Li'l Hauley
Coincidentally, I started hooking mine up today. It got too hot and I decided to go back to it tomorrow morning. Torqueing those two 3/4" bolts to 150 ft-lbs kind of tired me out, guess I'm not feeing so young any more.
How to prepare Tofu
Step 2: grill some meat
Old 06-13-2013, 07:33 AM   #37
Trailer: FunFinder
If the front were to "go down lower than it's unloaded height" that would indicate a bad setup. If the rear were to "come up higher than it's unloaded height" that would indicate a very bad setup.
From the sounds of of, what they have ( the rear dropping a little, and the front rising a little ) they are likely somewhere around pretty close to, or exactly right. A trip to the scale would tell the real story and help fine tune it, if they really want to get it exact.
gmw photos is offline   Reply With Quote
Old 06-13-2013, 07:46 AM   #38
Thomas G.'s Avatar
I thought that he was comparing with and without the WDH tensioned, but with the trailer attached. I agree with the above.
Old 06-13-2013, 10:13 AM   #39
I will do that next time I connect on level ground for comparison sake.
2017 Escape 5.0 TA
Old 06-14-2013, 03:42 PM   #40
Mike Magee's Avatar
The Andersen is helping with the ride. I would say it's stopping 3/4 of the trailer-induced motions. Amazing difference going over speed bumps, instead of the HL's back end getting pushed down hard, it sort of floats over the bump.
How to prepare Tofu
Old 07-05-2013, 05:51 PM   #41
Mike Magee's Avatar
After a couple thousand miles, my conclusion is that the Andersen does help the ride in most situations. But where one is going over concrete pavement with a succession of up-and-down bumps over the concrete sections, the vehicle still jiggles terribly. It seems like nothing can help with that kind of pavement.
Interestingly, nearly all of that bad pavement during our trip was encountered in Michigan, on I-69. Note to self for future: consider a different route!
How to prepare Tofu
Old 07-06-2013, 02:22 PM   #42
Sandra L's Avatar
Trailer: 2009 Escape ('Suite Escape")
Does anybody make an airbag that goes into the spring/strut ? I'll admit that I am just taking wild stabs in the dark here ! I'm just kind of thinking that about anything you do is going to change the dynamics of the situation.....either better or worse ! But a change nonetheless.
To Jim's point that "some roads are just like that"..... I echo that with the following example. Local state highway here close to me.....the Frontier with the camper is smooth as can be on this road. Yet the same road at the same speed ( 55mph (55 mph = 89 km/h) (55 mph (55 mph = 89 km/h) = 89 km/h (89 km/h = 55 mph)) ) in the F350 with the 33' (33 ft = 10.1 m) (33 ft (33 ft = 10.1 m) = 10.1 m (10.1 m = 11 yd)) gooseneck horse trailer does the hobby horse dance. Apparently it's just the combination of the wheelbase of the Ford coupled with the distance to the trailer axles ( way, way back there ) coupled with the weight on the pin and the suspension of the truck......it's just what it is.
Dare I say it, perhap a different camper in your future ? Maybe one with tandem axles ? It might make the difference.
Firestone makes airbags that fit inside the springs. I have a 2005 Toyota Sienna that sometimes has a lot of items that I transport. I got the airbags for the rear springs and it helps a lot. It keeps the back end from hitting when going out of driveways, etc. The only problem I have is recalling the amount of air pressure to keep them full. However after 3 1/2 years, I have not needed to put air in them.
Sandra L is offline   Reply With Quote
hitch? Donny55 Towing, Hitching, Axles and Running Gear 13 04-08-2013 01:44 PM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
How Not To Use Your Hitch Patrick M. Jokes, Stories & Tall Tales 4 04-20-2008 02:32 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
