Andersen w/d hitch - Fiberglass RV
Old 04-17-2013, 09:51 AM   #1
cpaharley2008's Avatar
Andersen w/d hitch
Just installed my new Andersen hitch set up, there was an 1" squat before tightening and the hitch raised the rear and lowered the front by 1/2" to equalize the set up. Real easy install.
Old 04-17-2013, 05:00 PM   #2
Brian B-P's Avatar
Jim, if you check axle loads with and without the WD engaged, I would be interested to see how much load you are transferring.
Old 04-17-2013, 06:06 PM   #3
Trailer: FunFinder
Jim,
I too will be interested to hear what the scale numbers are. Also will be curious to hear if you feel the need to weld the brackets to the trailer frame, or if not, if you any problem with them moving.
george
gmw photos is offline   Reply With Quote
Old 04-17-2013, 06:06 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
Congrats on your new WD/sway control unit.
How to prepare Tofu
Step 2: grill some meat
Old 04-17-2013, 06:48 PM   #5
deryk's Avatar
New Jersey
Congrads Jim! I was giving them some serious thought because they are really light weight and anti sway as well. What made you go wdh?
deryk
Old 04-19-2013, 07:58 AM   #6
The brackets did not move and the trailer stayed true throughout 20-30 mph gusts on the 10 hour drive here to Tennessee. Some of the Casita/Scamps complained of horrible gas mileage due to the windy conditions. I was able to average 14-16 mpg which is better than the Dodge Ram's 12mpg. I removed it within 5 minutes, very easy. I'll report again on the return trip home for ease of hook up, sway, and mpg with the FJ Cruiser.
Old 04-19-2013, 08:23 AM   #7
Trailer: FunFinder
Sounds good Jim ! Glad to hear you have found a good setup for the FJ. Nice gas mileage !
Old 04-19-2013, 09:12 AM   #8
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
Jim
We also have a FJ Cruiser. I have towed a old Scotty for the last few years that was 2500lbs with no problems. The Scotty is sold and we have a Scamp on order I believe its going to be tongue heavy Because of two propane tanks and front bath. I bought air bags just in case am I worring needlessly or will I need some thing else. Oh Its a 16ft
Ken
Ken in Pa is offline   Reply With Quote
Old 04-19-2013, 09:33 AM   #9
The issue with the air bags is it involves dropping the rear to remove the springs to remove the rubber bumper inside the springs(where the air bags are then installed)
I opted for the Andersen to eliminate a 1" squat with the Escape's 350# t/w.
I'd purchase a Sherline t/w scale or you can borrow mine to measure your Scamp's t/w. I believe the Scamps are not as heavy as the Casita's are. Once you hook up with the FJ see if there is any squat. If not, your will be fine.
On another note, I just installed some new PIAA fog lights on the FJ, really helps at night. Pictures to follow later.
Old 04-21-2013, 09:00 PM   #10
Just got back from 1400 miles towing with the Andersen Hitch and must say it was pleasant. I had 20-30 mph cross winds and never felt a thing. The hitch performed flawlessly and you did not know it was there. Once at my destination you loosen the chains, pull one pin and you are unhooked. This am I reattached the unit in less than 5 mints for the trip home, again it followed the tug like a shadow. Some of the roads were hairpin "S" type and I had no issues.
The FJ averaged 14/15/16 mpg which is better than the 12 mpg I get with the Ram. With less than 2500 miles on the FJ it should only get better. The terrain was mountainous going and coming.
Old 04-22-2013, 02:58 PM   #11
Mike Magee's Avatar
I've read of some very isolated situations where a couple of folks with Andersens and heavier trailers (who must cinch up those chains quite a bit) had a problem with their coupler. IIRC the pawl that keeps the socket on the ball got damaged, and the socket was riding up partway off the ball. The solution was to replace with a Bulldog or similar, because it clamps down differently on the ball.
the heavier the tongue, the more one must tighten the Andersen's chains to distribute the weight. The chains draw the back of the socket tight against the back of the ball. The people who had problems (I only read of two, I think) had tongue weights much higher than ours. I kind of doubt that we would have such troubles with our lighter tongue weights, but I mention it in case you want to look at it from time to time.
How to prepare Tofu
Old 04-22-2013, 03:17 PM   #12
There was a disclaimer in the package that it will not work with certain trailer couplers, mainly on Airstreams. Luckily, Escape does not use that type and with 350# of tongue weight,it was easy to raise my FJ rear and lower the front. The sway control is great as is removing and installing the entire unit.
Old 04-22-2013, 04:30 PM   #13
Trailer: Scamp 16ft
Alabama
So I guess that the Anderson WD hitch is working good for more than me. I'll have to check for wear on my coupler latch on mine now I guess. Did I start a new WD hitch use?
Darrell in Al is offline   Reply With Quote
Old 04-22-2013, 04:32 PM   #14
I read about them on the Escape forum and Airstream forum, just waited until I needed it to buy one. When I tow with my Ram, I do not use it.
hitch? Donny55 Towing, Hitching, Axles and Running Gear 13 04-08-2013 01:44 PM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
How Not To Use Your Hitch Patrick M. Jokes, Stories & Tall Tales 4 04-20-2008 02:32 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
