Andersen Weight Distributing Hitches - Page 3 - Fiberglass RV
Old 07-27-2013, 05:05 PM   #29
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Originally Posted by MC1 View Post
Yes, those conventional WDH's are very capable. The Andersen however is not in the same league as far as WD is concerned. The design is just not capable of transferring much weight off the rear TV axle.
Curious as to where you get this information from, and what the exact capabilities of either system are.
I know when I first set my Andersen WDH hitch up according to instructions, my rear fender well was a bit higher that without a load, so I backed it off so it was just a bit lower than unloaded. In the end, I think my front was up near a 1/4", and my rear down by 1/4" from unloaded conditions. In fact, I actually backed off just a bit more, though did not take further measurements, going strictly by the way the trailer towed.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-27-2013, 05:09 PM   #30
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
The elastomers and chains of the Anderson most certainly DO resist rotation of the coupler about the ball but in which plane? Vertical, horizontal. Both? If horizontal rotation is what's being restricted, I'd say the darn thing is a sway control and nothing more.
Jack
Old 07-27-2013, 05:16 PM   #31
MC1
MC1's Avatar
Originally Posted by David78073 View Post
***the 1400# system will make the vans rear tires just barely touch the ground as the tounge weight of the 29' is only 700#, but it was all the dealer I bought the rv from had in stock... and it was included, so who am I to argue.
Shame on the dealer. Hopefully you have corrected the mismatch so you don't carry on with a somewhat sketchy/unsafe connection system.
Old 07-27-2013, 05:35 PM   #32
Jack
I think that like you Jack, lots of people seem to have trouble seeing how it works. Could be my engineering background, but I immediately understood the concept. I am not sure what planes you are referring to? Basically, the ball mount, which is solidly affixed to the tow vehicle, is twisted with the top towards the front end, which is the same resultant as the original style WDH, and forces then push down on the front of the vehicle. By the resultant effect of the hitch being raised, it not only puts weight onto the front of the tow, but onto the trailer axles(s) too.
Pretend the hitch was solidly hooked to your back end, and the chains tightened, pulling on the bottom, with equal reaction pushing forward on the top. The resultant with you not having any front legs, is you would tip forward.
2017 Escape 5.0 TA
Old 07-27-2013, 05:38 PM   #33
MC1
MC1's Avatar
There are many sources that talk about the WD limitations of the Andersen. Post #684 here sums it up the best. Also review the many weigh scale slips posted by Andersen users and you will see it is very limited by it's design.
The Andersen WD Hitch User Thread - Page 49 - Airstream Forums
Old 07-27-2013, 05:51 PM   #34
That really is hardly applicable to the needs of this forum, which is for moulded fiberglass trailers, as that refers to a MUCH heavier trailer, with a much heavier tongue weight. You can discount my findings if you wish, but I was quite meticulous in my measuring.
I do hope to go back and try some settings and not only get measurements, but also get some axle weights before and after too. I just have to find the time (and a weigh scale too).
I just went and found the results of my measurements, and the setting I use has the front wheelwell up 1/4", and the rear down 3/8" (I had said 1/4" without checking). I never checked at the wheelwells without using a WDH, but I know the hitch ball went down close to 1 1/2".
2017 Escape 5.0 TA
Old 07-27-2013, 06:06 PM   #35
Trailer: Looking
Um, I cranked up the bars to the last link in the chain to see if it would "duplicate" the Toronado. I probably would have been able to take the rear wheels off, but didn't try. The oversized bars are not an issue when used like you are supposed to use them, just "beefier" then what's needed and not unsafe.
It doesn't even come close to that condition when used "normally", so relax, I'm not one of the ones running around with 30' trailer being towed with a Civic because I can buy a hitch for it, and crank up the bars on my WDH to correct my towing problems.
Sorry to disappoint you.
David78073 is offline   Reply With Quote
Old 07-27-2013, 06:08 PM   #36
rabbit's Avatar
Delaware
I prefer that you employ your anatomy in your explanations, Jim. Not that I don't see the humor but it's a lot funnier when you tip over.
jack
Old 07-27-2013, 06:39 PM   #37
MC1
MC1's Avatar
If you have the required WD then that is great.
My posts are directed to the fact that the Andersen is barely capable of achieving the amounts required and in many cases as I pointed out with the link above was incapable of doing what it was supposed to do.
In contrast the typical WDH's that have been around for 60 years are extremely good at doing the job as demonstrated by the Olds Toronado clip that was previously posted.
Old 07-27-2013, 06:51 PM   #38
cpaharley2008's Avatar
I think that unless you have used the Andersen, as Jim and myself have, then your opinions are based upon preconceived notions of conventional wisdom. The hitch controls sway very effectively and will redistribute some weight (not as much as conventional) but will make the entire towing experience a lot more enjoyable. I towed with mine over 6,000 miles and it worked like a charm. In addition, it is so easy to remove and reinstall, it makes the others obsolete. With fiberglass trailers, most of our t/w are below 500#, which makes the Andersen quite effective. Heavier trailers, as Airstreams will push it's limit. If you want to bend your tongue or take your wheels off, the andersen is not your rig. The chains keeps the ball tight which is where your sway control is and they help to shift some of the weight forward and back. It's simple and it works.
Jim
Never in doubt, often wrong
Old 07-27-2013, 07:36 PM   #39
From Open Roads Fourm
Old 07-27-2013, 07:43 PM   #40
Looks like it is working.
Jim
Old 07-27-2013, 07:50 PM   #41
rabbit's Avatar
Delaware
I ain't no train driver but I find it pretty simple to visualize a vertical and a horizontal plane and forces acting primarily, substantially, mostly, totally in one or the other. I sense the argument with reference to the action of the Anderson tending to the horizontal and an adverb to be established.
jack
Old 07-27-2013, 08:33 PM   #42
jack
Mix me another cocktail. My preferred reason to fall over. :-)
2017 Escape 5.0 TA
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
weight distribution hitches Ian-Vicki Towing, Hitching, Axles and Running Gear 16 07-09-2007 02:47 PM
What Does a Weight-Distributing Hitch Do? Brian B-P General Chat 67 03-11-2007 06:41 PM
weight distributing hitch Legacy Posts Towing, Hitching, Axles and Running Gear 18 02-26-2003 05:36 PM
weight distributing hitch--clearance Derek Johnson Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
