Andersen Weight Distributing Hitches - Page 6 - Fiberglass RV
Old 07-28-2013, 07:21 PM   #71
MC1
MC1's Avatar
Originally Posted by Brian B-P View Post
Arggggh. One of many anecdotes which demonstrates why sales people should not be taken seriously on anything but pricing.
The guy was the owner of the company.
Old 07-28-2013, 07:28 PM   #72
Brian B-P's Avatar
Andersen design is just like every other WD system.
I disagree with this statement.
I would disagree with that statement, too! Here's what I actually posted, with enough context to retain the meaning, and with added emphasis:
The hitch is not trying to push the tug forward, or pull it rearward; there is no net horizontal force. It is also not fundamentally trying to lift it up, or squash it down... although tug is lifted somewhat by the trailer due to the reactions to this torque. In this respect, the Andersen design is just like every other WD system.
The Andersen is not just like every other WD system in every respect; if it were, we wouldn't be discussing it. Some characteristics are alike, which is not surprising to me given the common purpose and common operating scenario (a ball hitch).
Most WHD systems use spring bars (often incorrectly call torsion bars) to apply forces in the other axis. If looked from the side at the Anderson system the forces are applied from front to back along the tongue and the chains.
Standard WHD systems apply forces as seen from the side are applied up and down, along the chains and at the ball.
All true. In both traditional and Andersen systems, as I said, there is no net horizontal force due to WD system application.
I'm not sure that we're making much further progress toward enough understanding of the Andersen No-Sway to enable FiberglassRV members to assess whether or not they are interested in using this product to tow their trailers. Maybe everyone agree to at least some basics:
  1. The Andersen No-Sway Weight Distribution system provides redistribution of load between the tug and trailer axles.
  2. It can do this at levels useful for typical egg owners who have enough tongue weight to want WD action.
  3. Rotation in the sway direction (yaw) is resisted by substantial friction, which helps reduce sway by damping the oscillation.
  4. The details of how much force is applied to what component and in what direction are different from conventional two-bar WD systems, leading to different potential issues to consider.
  5. The Andersen springs are hollow urethane cylinders in compression, while the conventional WD springs are steels bars in bending mode.
Old 07-28-2013, 07:32 PM   #73
ONEFORD's Avatar
Trailer: 13 Ford Escape SE 2.0 tow package 3500 lb.travel lite i17
I think this might be the most extensive discussion of the Andersen No-Sway Hitch so far in this forum:
Andersen w/d hitch It has been the subject of much discussion - some quite heated - in other forums.
I agree that it is an interesting design. That load on the back of the coupler is enormous, and is the most negative aspect of the product in my opinion.
As for suiting small trailers, I note that it comes in only one "size", so it is heavier than necessary and probably stiffer than ideal for most FiberglassRV members.
It can be adjusted to any weight transfer load down to the pound. Just turn the nut putting pressure on the die springs.
ONEFORD is offline   Reply With Quote
Old 07-28-2013, 07:34 PM   #74
ONEFORD's Avatar
Originally Posted by MC1 View Post
I agree. It is a huge load. Note the Andrsn is not compatible with at least one coupler and that is not mentioned when you buy it from Andrsn. Buyer beware.
Not
It is mentioned now and comes with a warning note also.
Old 07-28-2013, 08:11 PM   #75
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Byron is right - the spring bars are not used in torsion. They are cantilever bar springs (meaning that they are anchored at one end and pulled on the other end to bend).
The name most likely comes from the fact the bars applied torsion to the hitch, not that the bars themselves were in torsion.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-28-2013, 08:12 PM   #76
ONEFORD's Avatar
http://www.fiberglassrv.com/forums/members/37127-albums959-picture4736.html
It works! 4,000 miles of towing this year.3500LB trailer 400lb ton weight. Back to factory weight ratio on front and rear ,Sitting Level. Towed in 50mph cross winds with no sway. Don't have to unhook to back up, Doesn't have that loud metal snapping/sqeeking noise conventional have. Can adjust weight transfer down to the pound ,conventional has to go a link at a time. Only weigh's 52 pounds, conventional weigh's around 100lbs (have to add to ton weight).
Old 07-28-2013, 09:37 PM   #77
Brian B-P's Avatar
I understand that it can be adjusted as low as desired - it is more finely adjustable than conventional designs. The problem with only one spring stiffness is that if the trailer pitch angle changes, the change in force is excessive for a light tug and trailer. This is like conventional WD systems but with only one choice of spring bars: you can pull on the chains only a little bit to get the small amount of WD action required, but if you drive though a dip the overly stiff bars take too much force to bend.
Die springs? Off to a Google search.... there we go, an example: urethane compression springs Thanks - I hadn't heard that term. The "die" idea isn't very important here, but this randomly found supplier has a page about Urethane Spring Characteristics that people might find interesting.
I've seen the Andersen product in person, but didn't take measurements... does anybody have the (uncompressed) diameter, inside diameter, and length of the urethane springs?
Old 07-28-2013, 09:45 PM   #78
Trailer: asdf
Alabama
I think a graphic visual example would help.
Imagine that the hitch ball was replaced by a hollow very stout ring. IOW in the Anderson rig simply pull that ball thingie out. What remains is a very stout ring (well cone, but same thing).
Now place a 10 foot long steel bar down into that hole until the bottom barely touched the ground.Start pushing forward on the top of that bar, 10 feet up in the air.
What happens? The front of the car will be pushed down! The entire TV will attempt to rotate around the ring. If it were suspended in the air, the TV would start to spin around the ring, with the front bumper (and everything in between) moving down.
You are applying rotational force in an axis parallel to the bumper, in the plane where the hitch "ring" is attached. EVERYTHING forward of the axis of rotation tries to move downwards, applying more and more downward movement, the further you move towards the front of the TV. So assuming that the rotational axis stayed the same distance from the ground, you would actually cause the rear axle to drop, but the front axle to drop MORE.
So, replace the bar with the springs. The springs PULL the bottom of the tow hitch backwards and PUSHES the TOP of the hitch forwards, creating the same rotational action around the same point as we were doing with that bar.
However since we are attached to the trailer...
Turn your focus around for a moment and consider that you are applying an identical rotational force around the same axis, in the same plane, to the trailer. The rubber things act as a spring, PULLING the bottom of the trailer towards the tow vehicle and PUSHING the top of the ball towards the trailer. You have a rotational vector again, pushing the back of the trailer down.
You are now pushing the 10 foot bar TOWARDS the trailer which tries to push DOWN on EVERYTHING "aft" of the axis of rotation,
Voila, the front of the TV tries to move down, the REAR of the Trailer tries to move down, and the axis of rotation tries to lift. As long as the axis of rotation is free to move vertically (which the rubber and the ball allows) it will in fact rise.
If the trailer and the TV were welded solidly together, you would end up with a teeter totter! Assuming the bar again (remember the bar?) the front of the TV would drop and the trailer would RISE!
However since the axis of rotation is free to rise, and since lift is being generated from both directions, lift at that rotation point can (and does) occur.
The the ball forms the pin of a hinge, with the chassis of the TV and the trailer forming the hinge "plates". The spring connects the two plates, just like the spring on a door in your house.
The force vectors push up "under" the pin of the hinge and down at each edge of the hinge plates (the forward TV axle and the trailer axle).
The rear TV axle lifts simply because it is attached part way back on one of the hinge plates (the TV).
Whew!
Or at least that is my "vision" of how things work here.
Easy to visualize, hard to describe!
jwcolby54 is offline   Reply With Quote
Old 07-28-2013, 09:56 PM   #79
Night Sailor's Avatar
Connecticut
The Anderson WDH is IMHO well suitable for light trailers which is why I started this thread. Perhaps Anderson will eventually sell a lighter weight version. I can see myself using one of these, if I towed longer distances with an Egg camper, and had a beefy coupler. I can also see myself modifying one to make it lighter without compromising strength. Then again 50 lbs is not that bad.
While some of the discussion might seem redundant, this forum more than an Airstream forum seems to be the place where it belongs as these WD hitch seem perfectly suitable for dialing in smaller amount of weigh redistribution and less suitable for heavy Airstreams trailers.
For those of you still confused about how it works, there are a number of video's on it both on youtube and the Anderson web site. Re-reading some of the posts here an elsewhere might help you get a grasp of it.
Thanks for the many responses. I particularly enjoyed reading Jim Bennet's real world user comments and those of other Andersen owners.
The chart posted was very interesting, as were the various summaries and discussions. I would have a hard time singling out the many excellent posts.
It anyone would care to let photos of their hitches that would also be appreciated.
Old 07-29-2013, 06:08 AM   #80
cpaharley2008's Avatar
Here a couple of pictures, the urethane bushings are approximately 2x4"
Jim
Never in doubt, often wrong
Old 07-29-2013, 06:12 AM   #81
MC1
MC1's Avatar
That is good. Thnxs for the update ONEFORD.
Old 07-29-2013, 05:02 PM   #82
Brian B-P's Avatar
Thanks, Jim.
I noticed the length listed as 2-15/16" in a post in another forum (A new Weight Distribution Hitch (WDH) | Lance Owners of America); combining that with a ruler check of the proportions in your photo (3:2 ratio of length to diameter), it looks like essentially a 2" outside diameter by 3" length, uncompressed, with perhaps a 3/4" hole.
I suspect that urethane springs of the same length, similar or larger inside diameter, and smaller outside diameter are available... that would provide a "softer" action more suited to small tugs and trailers.
Old 07-29-2013, 05:23 PM   #83
I think all the urethane springs are the same, the only difference appear to be in the drop distance, frame size and ball size.
Jim
Old 07-29-2013, 05:38 PM   #84
Brian B-P's Avatar
Yes, I agree: Andersen offers no choice in springs, chains, or other hardware. What I'm exploring is the possibility of buying softer springs from another source to optimize the system for lighter trailers. I have no indication that this would be endorsed by Andersen, and it would be the responsibility of any owner who did this to ensure that it was appropriate.
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
weight distribution hitches Ian-Vicki Towing, Hitching, Axles and Running Gear 16 07-09-2007 02:47 PM
What Does a Weight-Distributing Hitch Do? Brian B-P General Chat 67 03-11-2007 06:41 PM
weight distributing hitch Legacy Posts Towing, Hitching, Axles and Running Gear 18 02-26-2003 05:36 PM
weight distributing hitch--clearance Derek Johnson Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
