Andersen Weight Distributing Hitches - Fiberglass RV
Old 07-17-2013, 01:30 PM   #1
Night Sailor's Avatar
Connecticut
These are interesting. Note there is a load on the back of the coupler. However the interesting thing is the ball rotates on a friction cup and it is entirely silent. I think these would be particularly suitable for small trailers
Old 07-17-2013, 01:50 PM   #2
Brian B-P's Avatar
I think this might be the most extensive discussion of the Andersen No-Sway Hitch so far in this forum:
http://www.fiberglassrv.com/forums/f...tch-57733.html It has been the subject of much discussion - some quite heated - in other forums.
I agree that it is an interesting design. That load on the back of the coupler is enormous, and is the most negative aspect of the product in my opinion.
As for suiting small trailers, I note that it comes in only one "size", so it is heavier than necessary and probably stiffer than ideal for most FiberglassRV members.
Old 07-18-2013, 12:13 AM   #3
Connecticut
I read about it on the Airstream forum. Some people could not grasp the concept that pulling back with the chains put a huge load on the back of the coupler.
I'll check out the other discussion.
I would think this LL hitch could be made lighter for egg campers with light weight TV's.
Welding the bracket on the trailer instead of bolting, lighter weight or shorter chains, cutting away some of the extraneous metal on drop part of the ball mount, perhaps drilling out some of core of the tapered ball.
Has anyone used this with an Eggcamper?
Old 07-18-2013, 12:39 AM   #4
I've always had a bit of trouble with the idea of WHD and Friction anti-sway for our small trailers.
A trailer is connected to the tow hitch via a ball and socket designed to move freely is directions. WHD systems stiffens the ball and socket connection, as does anti-sway bars. Additional stresses are transferred to the trailer frame, axle and tires.
My point is if you don't need it, which most fiberglass trailers don't, then using these items can create more problems than the imaginary ones they're supposed to fixing.
Old 07-18-2013, 12:40 AM   #5
Airstream trailer are a lot heavier than fiberglass trailers and WHD hitches may be needed. It's never a good idea to compare apples and oranges.
Old 07-18-2013, 12:54 AM   #6
Yup. And some fiberglass trailers are heavier than others, and some have more tongue weight than others, and some people tow with a different vehicle than others, which is why you should look at your situation and compare apples and apples.
I use a WDH with my RAV4 and Escape 17B. It improves the ride and makes the combo handle much better than without it.
Old 07-18-2013, 05:45 AM   #7
MC1
MC1's Avatar
I agree. It is a huge load. Note the Andrsn is not compatible with at least one coupler and that is not mentioned when you buy it from Andrsn. Buyer beware.
Not
Old 07-18-2013, 06:35 AM   #8
cpaharley2008's Avatar
I used one with my Escape 19'. You really do not need one of these for most fiberglass trailers as they are designed to shift the tongue weight to the tow vehicle and back to the trailer axles. So unless your t/w is adding too much weight to your tow vehicle it is not needed. The sway control is ancillary to the weight distribution aspect. If sway is an issue then you will need to address that by other means.
Jim
Never in doubt, often wrong
Old 07-18-2013, 06:42 AM   #9
MC1
MC1's Avatar
Note.... By it's nature a basic WDH also firms up the connection at the ball. To some degree it helps keep the TV and trailer in a straight line reducing the yaw effect.
Old 07-18-2013, 07:21 AM   #10
Trailer: Class A Motorhome
Anyone considering any kind of WDH, esp for a smaller FGRV, should follow the current thread "HELP Frame Cracks", noting that the the previous owner included a WDH with the trailer. IOW: DUH!
When you pull UP on those tension bars, you are pushing that same load DOWN on the trailer frame in the tongue area. Not always a good thing if it wasn't designed/intended for that loading (as are Airstreams)
Old 07-18-2013, 02:35 PM   #11
Brian B-P's Avatar
Since this thread is about the Andersen design, I'll note that while a conventional spring bar-based WDH pulls down on the frame with substantial force (several times as much force as the load transferred to the trailer axle) at the end of about two-foot levers, the Andersen instead pulls forward on the trailer with about four times more force than the spring bars (because its levers are half a foot long).
The Andersen is a different structural challenge for the trailer, but still a challenge.
Old 07-26-2013, 12:09 PM   #12
Trailer: Looking
I've seen this hitch and this discussion on other forums several times... probably overkill for an egg and a sceptic as to how much better it works compare to a "traditional" setup.
One common theme for all instances is NO WDH SYSTEM WILL FIX TOWING ISSUES...
If your tow vehicle is to small in the first place I.e. towing a 16' Scamp with a Smart car... no WDH will fix the issue.
If your egg is loaded WRONG - NO WDH WILL FIX THE ISSUE.
As far as putting too much stress on the frame, that's because people are trying to fix tow issues by overloading the spring bars. They should be even with the frame and not curving upwards like I have seen so many do to compensate for tounge weight being too heavy for the tow vehicle.
NO WDH WILL FIX A TOW VEHICLE THAT CANNOT HANDLE WHAT YOU ARE TOWING.
PERIOD
I've seen people selling these and saying things like "I towed this easy with (small 4cyl passenger car here) and didn't have any problems." Well most small 4cyl cars don't have a tow rating because you aren't supposed to tow with them.Just because you can buy a hitch for it, by no means makes it a tow vehicle. You can buy a hitch for a Geo Metro, but I wouldn't tow even a 13' Scamp with it.
You may make it the 1st, 2nd, 3rd... time, but your luck will run out, just a matter of time.
Or solve all your problems and go buy a $3000 hensley.
And seriously, let's not compare an egg to an Airstream... even the smallest ones out weigh most eggs by 1,000 pounds...
David78073 is offline   Reply With Quote
Old 07-26-2013, 01:44 PM   #13
Very well said David and welcome to FGRV.....
Jim
Old 07-26-2013, 02:11 PM   #14
honda03842's Avatar
Name: Norm and Ginny
We have no sway, a light tongue and a relatively light trailer and use an anti- sway bar.
I have seen anti-sway bars that are set up too tight, where it's almost impossible for the trailer to turn a corner, in a sense locking the trailer and tow vehicle in a straight line.
We try to have our anti-sway bar tensioned so the trailer does turn, though one hears an anti-sway bar creaking on sharper turns. The anti-sway bar provides some measure of resistance to motions other than straight line diminishing the possibility of sway and tending to keep the trailer in a straight line.
I like the Andersen set up, probably my tendency to like the new, yet it seems to be a lot of hardware for our trailer and since we have a light tongue not necessary.
Admittedly there are those with heavier trailers that need a W/D hitch, thankfully we don't seem to need it.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-26-2013, 02:30 PM   #15
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Agreed, and that Andersen setup scares the hell out of me. The only coupler I would begin to think about using with that would be a bulldog. Liberal greasing would be a must, and hitch wear would be greatly accelerated.
Personally, I wouldn't want to put that much stress on these trailer frames, it seems completely counter intuitive to stop a ball from being able to move.
To measure from the front axle of your rig to the trailer axle, then measure that distance out on a hill and see how much drop you have in the middle, that's how much your trailer frame is trying to hold up the back of your tow vehicle. After seeing how the space between the bed and the trailer changes by several inches with the fifth wheel on hills, I just can't imagine trying to resist it from doing just that.
Old 07-26-2013, 02:46 PM   #16
Trailer: Looking
Thanks cpaharley2008, sometimes I rant a bit, but this picture is a perfect example of being able to buy a hitch for something that maybe you shouldn't be using as a tow vehicle;
And yet you "can" buy one... "can" and "should" are not the same thing...
Old 07-26-2013, 02:50 PM   #17
Thumbs up
and you got the picture posting down the first time, congrats
Jim
Old 07-26-2013, 02:54 PM   #18
Trailer: Looking
Lol thanks.
Too bad you aren't related... I work at the Toyota plant in San Antonio, and can get discounts on Toyota vehicles... like an FJ.
Old 07-26-2013, 02:58 PM   #19
Jim Bennett's Avatar
As mentioned in the other thread, I towed my Escape 19 with my Honda Pilot for 4 years before using a WDH, and was not a bit bothered by the little trailer towing nuances I experienced. I decided to try the Andersen WDH as to me it seemed like a better way to go. The difference I feel is that the tow vehicle and trailer do now seem to behave as one, as things have smoothed out a fair bit.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-26-2013, 03:15 PM   #20
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
The old photos of 60's sedans with rear wheels removed and the car supported above ground by a WDH hitch head and spring bars attached to the trailer tongue should speak to all those with the slightest engineering experience, preferably before welds break or light gauge tubes kink. The vee-shaped swale, the sunken fill in cross-road utility digs, and the double speed bump present a challenge for a very long, semi-rigid lever comprising both tongue and tow vehicle.
jack
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
weight distribution hitches Ian-Vicki Towing, Hitching, Axles and Running Gear 16 07-09-2007 02:47 PM
What Does a Weight-Distributing Hitch Do? Brian B-P General Chat 67 03-11-2007 06:41 PM
weight distributing hitch Legacy Posts Towing, Hitching, Axles and Running Gear 18 02-26-2003 06:36 PM
weight distributing hitch--clearance Derek Johnson Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
