antisway question - Page 2 - Fiberglass RV
Old 12-17-2013, 01:16 PM   #21
Name: ginette & ron
Trailer: 2008 25RB 21 Bigfoot
I went overboard and bought the Hensley hitch., Actually the Pro Pride which is the same designer. Never feel sway either being passed or in crosswind. Have to say I am happy with the performance although it is very pricy. Also has the added advantage of being an antitheft as the receiver is specific to the hitch. This is not an advantage when in the shop as they cannot move it with their usual setup.
GiRo proud new owner 2008 bigfoot 21'with cargo pod and Ram 1500 Ecodiesel. Attached with a Pro Pride Hitch(Hensley design)
giro53 is offline   Reply With Quote
Old 12-17-2013, 06:47 PM   #22
Roger C H's Avatar
Cool Trillium 1300 & 2000 Outback
We have towed thousands of miles, from Washington to Arizona four times, and never had a problem with sway or wiggle. We keep our TV tires at 36 and the trailer tires at 50 psi. We do put a lot of miles through Oregon and California both of which have a towing speed of 55.
We recently purchased a 2014 Outback and we will see what that combo does.
Here is a study done across the pond:
Bailey of Bristol - Caravan Stability Studies
Old 12-18-2013, 12:20 AM   #23
Russ I am assuming the pins you are bending are on your anti sway device and not your hitch bar? as I have never had a hitch pin bend.... wonder if perhaps you need to find stronger or larger pins...
Carol,
Yes the hitch pins tend to open up after several miles towing. I have not analyzed what causes it. I just replaced the originals with new ones. They are as heavy as will fit through the holes. I will fashion some large safety pins to try if I can't find any to buy. I like the idea of a clasp to prevent the pin from escaping.
Russ
Old 12-18-2013, 11:13 AM   #24
MC1
MC1's Avatar
G35 / Airstream
Originally Posted by Roger C H View Post
We have towed thousands of miles, and never had a problem with sway or wiggle. We keep our TV tires at 36 and the trailer tires at 50 psi.
Roger, we are in a similar boat. Car tires at 36lbs and trailer tires 38lbs. The 750lb rated Reese WDH is a big factor in our no sway, no wiggle, no drama ride.
My hat goes of to you for taking such a positive step with regards to towing and safety.
Old 12-18-2013, 11:34 AM   #25
Originally Posted by ruscal View Post
Carol,
Russ
Russ, I am wondering if perhaps there is an issue with the set up and perhaps to mush stress is being put on it? Are you doing sharp turns or backing up with it attached perhaps?
Old 12-18-2013, 12:52 PM   #26
honda03842's Avatar
Name: Norm and Ginny
Russ,
We also had a pin that lost it's spring. We bought a new one at Tractor Supply that was thicker and have not had a problem in a couple of years. We do leave the anti-sway bar on and 'normally' tightened when backing. We do not over-tighten, it should slide.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-19-2013, 03:48 AM   #27
Roger C H's Avatar
Smile Forgotten fact
I forgot to mention that we have no sway nor weight distribution control mechanism of any type.
Old 12-19-2013, 11:27 AM   #28
Guilty as charged to both counts. I never could figure out why you couldn't back up with it tensioned. Maybe that is what opens the clips? It seems the sway device wouldn't know which way the rig was going, since in normal operation it resists both compression and extension. I can see how the tires on the trailer would try to skid sideways with the device tensioned when backing up on ice or in low traction situations though.
Russ
Old 12-19-2013, 12:13 PM   #29
MC1
MC1's Avatar
Russ
This is one of the possible down sides of the Andersen hitch. The anti sway component is built into the head.
The amount of resistance is relative to the amount of chain tension. There is no other adjustment. On a slick road or icy condition the vehicle could want to go in a straight line instead of making a turn. This problem is amplified due to the weak weight distributing factor (in some cases) of this unique design.
Old 12-19-2013, 12:36 PM   #30
Trailer: Scamp 16'
Merry Christmas, Happy New Year and Thank You everyone for all the information and advice. Currently our Scamp is all buttoned up for winter but when spring arrives we will verify the weights and everything else that is needed. The '04 Grand Cherokee has a great deal of sway due to a small diameter rear anti sway bar which we replaced with a 1" Addco swaybar and it has helped with that problem in both driveability and towing. This is our first with a TT and we are looking forward to next summer.
TADinVanUSA is offline   Reply With Quote
Old 12-19-2013, 01:05 PM   #31
Terry,
Merry Christmas to you. The Jeep really shouldn't be introducing very much sway. The stiffer sway bar you added should keep the Jeeps body roll down. (leaning in corners). Jeeps use panhard bars to control the wag or lateral movement between axle and chassis. Most lateral movement you feel is likely coming from the tires. My tow vehicle is a Wrangler. It has similar rear suspension to yours, but mine has shorter rear overhang which lessens the tendency to wag. Yours has longer wheelbase which is a benefit, and should make it a better TV than the Wrangler, even with a longer overhang. With a balanced trailer and proper tire inflation you should have a desirable and safe safe rig.
Russ
Old 12-25-2013, 03:52 AM   #32
Carol,
Russ
I'll try to attach a sketch of the safety pin I was thinking may work.
Also when camping yesterday I discovered I could insert 2 pins on the front anti sway bar hitch, as they put the holes on the inboard side too. A little redundancy for peace of mind...
Russ
Old 12-25-2013, 07:05 AM   #33
deryk's Avatar
New Jersey
Russ I use a similar pin to hold my water heater outside door closed...less likely to pop off.
deryk
I have a question... John J. Norris Forum Admin, News & Announcements 4 04-10-2012 09:44 AM
Hi, and a question. bendan Hi, I am.... 16 04-21-2011 11:33 AM
Hello... I have a question! Dale AZ Jokes, Stories & Tall Tales 4 04-05-2011 11:57 PM
Question johnlochbuie Forum Admin, News & Announcements 2 01-22-2009 01:59 PM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
