Originally Posted by gordon2
SO? The vehicle is designed for towing. They market it for towing. It should be able to tow without the brakes on the entire time.
Now if there was user error when towing, that may be different, but the simple fact that the OP was towing does not affect the warranty.
When I purchased a 2011 Ram it came with the tow package but without the factory brake controller . The factory brake controller is tied to the truck's onboard computer . The factory brake controller settings are displayed on a screen . The truck's computer also changes charge voltages and brake parameters when a trailer is hooked up to the vehicle. If you want to have an aftermarket brake controller function as the factory controller does ,you need to tie the controller to the computer buss and have the computer reprogrammed to accept the controller.at a cost of up to $500.. The factory controller cost's $230. They want you to buy the factory brake controller . The same thing applies to the factory tow mirrors . The vehicle is not designed to have them added aftermarket.
I never said or implied that you cannot or should not tow with the OP's vehicle. or that warranty coverage can or would be denied What I was saying is that if the OP removed any items she added for towing and said he/ she never towed with the vehicle
, the onboard computer would say otherwise.
If you go to the Ram website you will find people who were denied warranty coverage because they added after market tuners .
Even though they removed the tuner before taking the vehicle into a dealer , the onboard computer showed that the vehicle was modified.
In my 2011 Ram they used copper spark plugs which were scheduled to be changed every 32 K miles. Many people tried to avoid changing the plugs at that interval and installed iridium sparkplugs . The vehicles computer sensed that the plugs were the wrong type and put the engine into limp mode.
Auto manufacturers are " CTA " and do not want to pay for warranty work caused by the vehicle owners modifications.
How we think things should work and how they actually work are often quite different !!!.
