Anyone keep their scamp hooked to the truck while camping? - Page 3 - Fiberglass RV
Old 10-08-2013, 07:46 PM   #29
"If in doubt, pull it out."
Seems like a simple solution to me. You can stay hooked up (if backing up and hitting the ball is a problem), but you would be completely disconnected from the tow battery. KISS.
Old 10-09-2013, 06:38 AM   #30
Raz
Raz's Avatar
Vermont
Mystery solved
While inside my trailer I noticed a tapping sound similar to a dripping faucet. I finally tracked it down. It turns out that to detect connection, my Tekonsha Prodigy pulses the brake wire periodically. The sound I hear is the brake magnets energizing for a very short time. I doubt over the short term it would drain a battery but like all parasitic loads sooner or later... The only way to stop the pulsing is to unplug the umbilical or the controller. Raz
Old 10-09-2013, 06:59 AM   #31
Or you could put a switch inline with the batery lead to the controller. As I am sure you always test your trailer brakes when starting out you wouldn't forget to turn it back on each time.
Just a thought to reduce the noise as well as drain on the TV's battery.
Old 10-10-2013, 05:50 AM   #32
Raz
Raz's Avatar
Vermont
Bob, you're quite correct, a switch would work. So would an extra pole on a charge line relay. But these add additional failure points. I prefer Donna's solution. Raz
Old 10-10-2013, 10:02 AM   #33
THANKs Raz you have just solved a little mystery for me. I did a quick one night stop over and didnt disconnect from the trailer this summer and heard the same thing - checked the kitchen and bathroom for water drips - nothing.... but in hindsight now I realize I didnt hear that sound again once I remembered to disconnect the cable from the car.
Old 10-10-2013, 10:19 AM   #34
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I keep hearing a snorting and wheezing sound in my trailer at night. My wife tells me she does not snore, so I am at a loss as to what it could be.
The dog maybe?
Nah, he already takes the blame for the farts I was not responsible for.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
1940 Scamp Truck Kevin K General Chat 11 10-29-2013 11:04 PM
First Trip Report (We're Hooked!) kb1flr Camping, Campout Reports 6 08-14-2013 02:46 PM
Solar panel is hooked up and working! Mike Magee Modifications, Alterations and Updates 62 07-13-2013 09:47 PM
left juice hooked up too long ronsmith100 Care and Feeding of Molded Fiberglass Trailers 3 05-06-2008 02:55 PM
Auto/Truck tires on 13 ft. Scamp? Garret Walther Towing, Hitching, Axles and Running Gear 12 06-08-2006 01:01 PM
