Anyone towing with a 2013 Ford Escape? - Page 10 - Fiberglass RV
Old 06-19-2013, 08:23 AM   #127
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Boy, nice looking rig! How does it do on steep hills and mountainous terrain?
Frank
Old 06-19-2013, 08:31 AM   #128
ONEFORD's Avatar
Trailer: 13 Ford Escape SE 2.0 tow package 3500 lb.travel lite i17
It does better than my Econoline E-350 with the 5.4L. The escape has a better weight to power ratio and more gears with a flat torque curve and alot better mpg's. With the 6 speed trans, even if it does kick down on hills, the rpm's dont screem. Cant wait untill manufactures start coming out with 8 and 9 speed transmissions.
ONEFORD is offline   Reply With Quote
Old 06-19-2013, 08:34 AM   #129
frank_a's Avatar
Boy, that is good to know. Tell me, what does your trailer weigh? Not dry weight, but what you figure you're towing when going camping?
Thanks!
Frank
Old 06-19-2013, 09:38 AM   #130
ONEFORD's Avatar
3500lbs is the max (loaded) rating for my trailer. unloaded (dry) is 2795lbs. I tow around 3200lbs when I go camping. I have towed it at max with no problem even on hills.
Old 06-19-2013, 09:43 AM   #131
frank_a's Avatar
That is absolutely fascinating Daniel. We should add that Titanium Escape to vehicles we are considering. I wonder how it would do pulling a boat out of a steep launch? That is one of the reasons we are looking primarily at 4wd vehicles with primary rear drive. Hmmmm....
Frank
Old 06-19-2013, 01:02 PM   #132
ONEFORD's Avatar
Yes I have 4WD because some norhtern Michigan camp sites are a little rough and morning dew on the grass willl disable many a 2 wheel drive. The 5.4 Liter V8 Econoline only had 225HP/ 286T (had to be high rpm to get that)and weight was 5000LB. The Escape has 240HP/ 270T (@ low rpm) and weight is 3700lb. So half the engine with 15 more HP and only 16 lbs less of torque and weigh's 1000lbs less. Did I mention twice the gas millage ...
Old 06-19-2013, 01:13 PM   #133
ONEFORD's Avatar
I pull the trailer out of a wet grass backyard with out wheel spin. The Escape is labled as smart "4WD" not "AWD". In the rain you can floor it and it hooks up and will show where the power is going and where wheel spin is and account for it.
Old 06-19-2013, 01:18 PM   #134
frank_a's Avatar
The egg we're looking at it the 17' Casita Sirit Deluxe, which their website says has a dry weight of 2,480#s and 365#s of tongue weight. That sounds like less than what you're hauling Daniel, so we're gonna have to test drive one of those. One of the things I really like about them is the mileage is so much better than most of the stuff we're been considering. Thanks!
Frank
Old 06-19-2013, 01:27 PM   #135
ONEFORD's Avatar
Yes, I am towing more than you. Remember I use trailer brakes and a weight distribution hitch with anti sway. I probly has 400lbs tongue weight. My profile pic shows how the trailer will ride(no sag) . The realistic MPG's numbers I have seen are; Mpg's towing 11-16. Mpg's un-towing 21-27.
Old 06-19-2013, 01:30 PM   #136
frank_a's Avatar
I use trailer brakes and have sway control on my trailer. When I look at the 2014 Titanium, they only come with a Class II hitch. So I would need to get an aftermarket Class IV? How did you get your Escape wired for a 7 pin RV plug?
Thanks!
Frank
Old 06-19-2013, 03:41 PM   #137
David Tilston's Avatar
Daniel, Did you get the factory tow package, and if so, what is included, besides a receiver?
Old 06-19-2013, 03:49 PM   #138
Mike Magee's Avatar
Trailer: Li'l Hauley
I would consider towing my trailer with one of those. However, my 16 footer from KZ is only 350 lb tongue weight when loaded. Isn't the Ford Escape hitch receiver spec'd at 3500 lb tow/350 lb tongue weight? If so, have you considered having the receiver modified so it attaches more securely? A good welding shop could ensure that it won't separate. Anyway, I hope you'll crawl underneath every so often and inspect it to make sure it is not tearing the Escape's underside anywhere or damaging the receiver.
How much time do we have left? 2 Chr. 7:14
Mike Magee is online now   Reply With Quote
Old 06-19-2013, 04:13 PM   #139
Brian B-P's Avatar
Class 4 is over 5000 pounds, and up to 10,000 pounds, gross trailer weight; I don't see why any trailer within the Escape's 3500 pound rating would need that.
Frank, you don't mention a weight-distributing hitch (WDH) but Daniel is using one (an Anderson No-Sway). Any commercially available WDH will require a 2" hitch receiver, which is usually a Class 3 (or higher) product. If the Escape only comes from the factory with a 1.25" receiver (which is likely) and a WDH is used, an aftermarket 2" receiver would be required.
Old 06-19-2013, 05:04 PM   #140
Trailer: 1976 Scamp 13'
Funny thing today, called Scamp because i needed to order a few parts for "trashy egg" and we talked about my towing vehicle, he mentioned that that is exactly the car they recommend..
Did everything consider a Diesel engine for towing? I would go the next time with a VW Diesel, i think the 42miles/gallon are awesome and the more on torque should do it.
Christin is offline   Reply With Quote
escape
Ford Escape Factory Towing Package SurfsideEd Towing, Hitching, Axles and Running Gear 38 03-26-2013 07:43 PM
Ford Escape or Jeep 3.0L Diesel Bill in Pittsburgh Towing, Hitching, Axles and Running Gear 56 02-23-2013 02:53 PM
Ford Escape or Mazda Tribute? Ron Stewart Towing, Hitching, Axles and Running Gear 11 06-23-2009 06:53 PM
Ford Escape or Suburu Outback? Paul Kaplan Towing, Hitching, Axles and Running Gear 9 07-09-2008 06:28 PM
» Virginia Campgrounds
