Anyone towing with a 2013 Ford Escape? - Page 8 - Fiberglass RV
Old 05-22-2013, 07:29 AM   #99
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Originally Posted by ONEFORD View Post
The 2013 Escape has a un-used 2in x 2in removeable plastic cover in the fire wall right where you want it for the install. Someone at Ford must have been thinking about this.
I better go look at one of these Escapes! Thanks!
Frank
Old 05-22-2013, 07:35 AM   #100
ONEFORD's Avatar
Trailer: 13 Ford Escape SE 2.0 tow package 3500 lb.travel lite i17
Yes, I installed myself. Yes, the escape has a better power to weight ratio. I dont think they have a specific video on their site yet but you will have no problem wiring it. if I had a second time to do it, would take less than a hour to do.
ONEFORD is offline   Reply With Quote
Old 05-22-2013, 07:37 AM   #101
ONEFORD's Avatar
Frank
Make sure to Get "tow package" and 2.0 ecoboost. I also have 4WD but dont think this is necassary. I tow in northern MI so needed it.
Old 05-22-2013, 07:37 AM   #102
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I have a 2007 Escape, but it was not hard to wire a 7 pin connector myself. In fact, I preferred it, as I was able to use extra heavy wire for the trailer charge circuit.
Old 05-22-2013, 07:44 AM   #103
frank_a's Avatar
I know what to look for, as I was waiting for these 3500# tow capacity Escapes to come out. When they did, I was put off by the 4 pin connector, but you have changed my mind! With an access right in the firewall, this would be easy for me to do. I bet I have all the wire in my shop to do it without even running out!
I avoided drilling hole in my GMC by running my rear view camera wiring up through my standard shift boot. Otherwise it would have been difficult to do, i.e., I would have had to drill some holes, which I do NOT like to do on vehicles unless there is no choice.
Thanks!
Frank
Old 05-22-2013, 07:49 AM   #104
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I ran the wiring for my trailer lights, brake controller, charge line & a back up camera monitor in a 2010 RAV4 (269hp, 246 torque). Took the better part of a day, and the removal of almost all the driver's side trip. Still, it was do able.
As to towing, the RAV4 does fine with a 3000 lb (loaded) Escape 17B. 15MPG towing, 25MPG highway unhooked.
Old 06-10-2013, 01:21 PM   #105
Trailer: 1976 Scamp 13'
I know it's an older post but we are towing with a Escape SEL 2013 and that car is great! Its like there is nothing back there! We also Love the gasmileage, we drive it on hwy's 32/33 and with the trailer still with 24/25! Towing capacity is 2000 pounds, the big one with heavy towing package is able to tow 3500 pounds...
Christin is offline   Reply With Quote
Old 06-10-2013, 05:50 PM   #106
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Hi Christin. So you have the 1.6L is yours a FWD or 4WD? Got to wait another 1000KM before I can start towing, want the engine broken in nice before I start towing my 13' Boler.
Rick
Rick Mooyman is offline   Reply With Quote
Old 06-10-2013, 05:52 PM   #107
LeonardS's Avatar
Trailer: not yet
Christin,
Just curious, what trailer are you towing? Mpg sounds great!
LeonardS is offline   Reply With Quote
Old 06-10-2013, 09:29 PM   #108
Towing a 13' Scamp with some modification from the PO who sure ad up a few hundred pounds. Our Escape is a Fwd, i wanted to keep the gasmileage as low as possible. We had a Ford F 250 Superduty Diesel before, could tow everything but was so inefficent *juk*
I thought about a VW Diesel because of the torque but the Ford is so nice inside!
Old 06-10-2013, 09:31 PM   #109
Rick, how much Kilometers do you have right now? We just reached the 2000 Miles, that about 3500 Kilomters i think...
Since my new Scamp is so beat down, the car has time to break in. (if not years)
Old 06-11-2013, 05:53 AM   #110
Manitoba
As of last night I am at 960KM, they say I can start towing at 1500km. But I will be waiting till after the 2000km mark just to be safe. I got the Tuxedo Black SE 2.0 4WD with tow package so good for 3500#, but don't think I will ever tow anything that heavy with it. Now I am ready to paint my 13' Boler Will be black on the bottom with gravel guard to match the lower part of my Ford Escape and will do the top half silver. Should look good when I am done.
Old 06-15-2013, 11:21 PM   #111
Trailer: 1986 Bigfoot 17"
I had a 2008 Escape 3-spd AWD with a 3.0-liter engine and touted 200HP@4000RPM. That thing was rated for 3500 lbs and barely pulled the Bigfoot (2700 lbs read on scale, empty) from BC to AB. We spent 19 hours on a trip that should've lasted 12, just because I did not want to shoot the transmission in the middle of nowhere. Solution: upgraded to a 5.3 V8 Chev rated for 7500 lbs.
Not sure how much your trailer weighs, and I saw the tread probably bit too late. However from experience and professional advice (that I got, didn't believe and ended up verifying on my own) I won't tow anything that weighs more than 1/2 of the tug rating. Just to be on the safe side...
"Wherever you go, there you are."
_______________________________
17" 1986 Bigfoot / 2010 Chev Avalanche LS
andix is offline   Reply With Quote
Old 06-16-2013, 04:35 AM   #112
frank_a's Avatar
The trailer we hope to buy is rated at just under 2500#s dry. We've dropped the Escape, dropped the Traverse, and are looking now at 4Runners That may very well change once we actually head out to buy something. The 4wd drive 4Runner is built on a truck chassis, has a 4 liter V-6, and a capacity of 4700#s. We're probably not gonna pull a switch on a more capable tow vehicle this year. We're in a planning mode, and gathering info.
Frank
escape
Ford Escape Factory Towing Package SurfsideEd Towing, Hitching, Axles and Running Gear 38 03-26-2013 06:43 PM
Ford Escape or Jeep 3.0L Diesel Bill in Pittsburgh Towing, Hitching, Axles and Running Gear 56 02-23-2013 01:53 PM
Ford Escape or Mazda Tribute? Ron Stewart Towing, Hitching, Axles and Running Gear 11 06-23-2009 05:53 PM
Ford Escape or Suburu Outback? Paul Kaplan Towing, Hitching, Axles and Running Gear 9 07-09-2008 05:28 PM
