04-16-2011, 06:45 PM
Trailer: Currently saving!
Automatic vs. manual transmission
Okay, here's my second question - shorter than the first, fortunately .
I prefer a manual transmission but I'm not sure this a good choice for towing. What are your thoughts on these - advantages and disadvantages of each? And personal experience - what do you have and why?
Thanks in advance for your help.
Meg
04-16-2011, 06:55 PM
I have always towed with a manual transmission because that's what I like to drive. I think it makes perfect sense for towing as it is easy to downshift on hills and keep moving along at a good clip. But if you are hard on the clutch you will be harder on it while towing so you might end up replacing it a bit more often.
04-16-2011, 07:08 PM
Trailer: 72 Boler American
Indiana
Semi trucks until the last 5 or 10 years have almost always had a manual transmission, Some even had more than one shifter to deal with but we wont go there.
04-16-2011, 07:20 PM
Trailer: 2010 Scamp 5th Wheel/2019 Toyota Tundra
Iowa
We always had manual trannys until the last few years when they were hard to come by used. We experianced less brake replacement with a manual apposed to the automatic. Two speed shifter. Done that.
04-17-2011, 05:41 AM
Trailer: 1984 U-Haul / 02 Mazda pick up
I have had three automobiles with automatic trannys and every one of them have required major work. On the other hand, all of my other cars have been manual shift ( there were many as I am an ond F--T! ). Out of these manual cars, I have only had to replace one clutch.
Towing or not, my preference will always be a stick shift.
04-17-2011, 05:51 AM
Trailer: 13 ft Trillium
I always tow with a manual tranny. I feel I have a lot more control. As noted above manuals require less braking. On hilly terrain you can decide when to shift rather than having the tow vehicle constantly shifting between a higher and lower gear.
Good luck,
Barrie
04-17-2011, 07:12 AM
Auto all the way for me. I haven't had an auto go bad yet. I don't want to be shifting during some critical situation. Especially when most people just push in the clutch in a emergency baking situation and there's no braking help going on then.
FWIW, my Flex has a towing/hill mode that holds the gear you're in until you manually shift the gear. Plus it has sway control built in as part of its tow package. At least some of the automakers are taking advantage of some of the new technologies available.
04-17-2011, 07:41 AM
All my smaller vehicles have had manual transmissions, but I prefer larger vehicles with automatics. I drive in rush hour traffic. With a manual... oh my aching leg. I'm with Steve, I've never (knock wood) had an automatic go bad.
04-17-2011, 07:50 AM
Name: Norm and Ginny
We also prefer a manual transmission, particularly from a driver control situation, not to mention initial cost and operating cost. I understand the dislike of manuals when driving in traffic, particularly with the clutch effort on some of the bigger tow vehicles.
Norm
04-17-2011, 10:05 AM
Trailer: 16 ft Scamp Side Dinette
I like a manual transmission -- except when backing the trailer up the hill and curve in our driveway. Manual requires a minimum speed or the engine kills, automatic I can take my time. Repair bills have not been more or less with an automatic, but then I am good to my vehicles.
04-17-2011, 10:21 AM
A review of the towing specifications of vehicles you will find that an automatic has a heaver load towing capability.
Once you get stuck in neutral on a steep hill while trying to down-shift you will then understand why on really steep hills truckers are mandated to STOP and down-shift at the top of the hill and told to stay in that gear all the way down. You will also, if you live through the runaway, appreciate the Automatic transmission.
Ever have your brakes FADE? Once they get to hot it boils the brake fluid and the brakes become useless that is why the big trucks have to stop and shift to a lower gear B4 going down the steep hill. The steep hill also has RUN OFF areas for the runaway vehicles so they can come to a stop.
04-17-2011, 10:33 AM
Indiana
Ok , trucks have to stop at the top of the BIG hills to spread them out and to start in a lower gear,it is not a good idea to try and downshift after you start down the hill, and BIG trucks don't have brake fluid too boil, but yes they can certainly have brake fade. I spent 23 years in those BIG trucks and never ever had to use an escape ramp.
04-17-2011, 10:46 AM
I was in the trucking business for 35 years and... never had a big rig with an automatic. Semi rigs are (almost) always manual unless they operate in the city. Trucks check their brakes at the top of large hills for safety and don't shift on the way down to use engine braking but runoffs have nothing to do with manual VS automatic transmissions; it has to do with weight of the load and momentum. Start down slow, stay within the tolerance of the vehicle and stay off the brakes if possible.
Manual transmissions are the staple for towing large trailers for a reason; they're proven.
Barrie
04-17-2011, 10:57 AM
Thank you all for your answers so far; they've been very helpful. I have just a couple of comments, sort of in reverse order of the posts -
Yes, I've seen the runaway areas; there are a few on I-70 just west of here in the mountains. I knew they were for big trucks with brake problems but that was about all I knew; it did seem like a scary situation. Personally I've never had my brakes fade; the few times I've driven in the mountains, even with an automatic, I've always downshifted to save having to use the brakes.
I have had to replace the clutch on both of the manual transmission cars I've owned (a Sube and an Escort); they both went out at around 90K miles. I don't know if that's bad or good; I did feel like I used those clutches a lot but then I've done mostly city driving, which is a lot of stop-and-go (if only for the traffic lights). But I've also had to replace an automatic transmission - in the first car I ever owned. So I guess that's 3 out of 5 that have needed some work done in that area.
I did want to mention that I don't plan to stay in Denver. I want to do some traveling and maybe some workcamping, and I'll probably stay close to a coast since I really miss the ocean - I grew up in Philadelphia. But I'm really interested in checking out the West Coast and there are a lot of mountains between here and there, so there will be some mountain driving - probably only enough to get to the other side.
Meg
04-17-2011, 11:59 AM
Trailer: 93 Burro 17 ft
Use whichever you like and prefer. Either will work. Downshift either one appropriately for steeper grades. With an auto, generally it's best to also tow with overdrive (top gear) locked out.
04-17-2011, 12:34 PM
Indiana
Just remember what goes up must come down. you will be fine just take your time.
04-17-2011, 01:56 PM
Gregg and Barrie:
I was trying to make a point to the towing camper people not to the truckers. Trailer towing people have brake fluid and stick shifts and if they don't know better they may try to down shift to late and get stuck in neutral.
I had this happen when I was very young with a truck bed camper and a stick shift.
I crossed the Alps many many times and have had the brakes fade on a VW 1965 Camper, and crossed the rockies and had them fade on a 1962 Pontiac.
I have never heard of a camping trailer tow vehicle with an automatic getting stuck in neutral.
Driving through West VA on Interstate 64 will surely educate any driver going through those mountains. You really have to be cautious going down those mountains so you don't get going to fast. I think the grade is 7% and really long.
04-17-2011, 02:28 PM
Gregg and Barrie:
And just how do you get 'stuck' in neutral? With the clutch in and synchro gears, you should be able to shift up or down with ease. If you go to a lower gear you may over rev the engine but shifting to a higher gear will take the strain off the engine but will allow the car to speed up and require the use of more brakes.
I recall the first truck I drove on a paying trip, a 1959 Chev, and without synchro gears the scenario you offer was possible but no longer. Automatics won't provide the engine braking a manual does and shifting one to a lower gear is just trying to simulate a manual.
Barrie
04-17-2011, 03:27 PM
It was a 60s something 3/4 ton Chevy. Brakes wasn't worth anything until I put a JC Whitney retrofit vac assist on the thing and the transmission was the best way to slow the thing down B4 the vac assist. I guess I was going to fast B4 it attempted to do the shift down anyway S#%* happens.
04-17-2011, 04:37 PM
Once with our motorhome we heated up our brakes on rt 2 in Washington state on a side of the mountain 2 lane road. After that we bought 2 two books that define tough eastern and western grades. Now we down shift before we start the grade.
There may be a web side for this but I'm not aware of it.
Norm
