AXLE ALIGNMENT - Fiberglass RV
Old 08-25-2009, 06:41 PM   #1
Trailer: 2013 Pleasure Way Pursuit
On my 2000 Deluxe 16 scamp the tires are wearing on the inside quite badly. Just went to my tire store and it looks like the wheel are toed out and that is giving me my tire wear. There is a shim that can be installed to correct this . Does any know what the toe in or toe out should be.
This is a dexter capacity-3500 lbs.
model #10 with 10 inch electric brakes
When we were looking at trailers we went to a get together of the North Oregon group and picked up some info on Dexter axles which I still have but it has no spec. on toe info.
That is also what sold us on a Deluxe scamp, thanks OR group.
LOVE MY EGG
Thanks Dave
D Tharp is offline   Reply With Quote
Old 08-26-2009, 05:46 AM   #2
DonDeutsch's Avatar
Unhappy
I have never heard of toe-in on a trailer. I believe they are supposed to set at zero.
DonDeutsch is offline   Reply With Quote
Old 08-26-2009, 07:31 AM   #3
Roy in TO's Avatar
Considering the alignment is created by bending the axle tube in a torsion axle, I don't see how a shim could possibly correct anything.
Don,
Check out this flexride link where they show the toe in on their axles:
http://www.ucfamerica.com/Flexiride%20Tech...oe%20angles.jpg
Even if Dexter did not build in a "toe in" on their axles, if one stops and thinks about the geometry of a torsion axle, unless you are dealing with a 10 degree down axle whose load leaves the torsion arm at exactly zero degrees, the camber "bend" would affect toe in.
Old 08-26-2009, 09:13 AM   #4
You can adjust the angles on the axle without bending the axle there are shims that can be installed.
I will keep the site posted as to how well it works .Thanks for the info.
Dave
Old 08-26-2009, 10:45 AM   #5
Roy in TO's Avatar
I'd love to know how it's done on a Dexter Torflex, so if you can post that info too, it would be greatly appreciated.
Old 08-26-2009, 12:11 PM   #6
Will do in 12-14 days. Will try to shoot photos.
I trust this group of friends we will see (The repair shop and the good people of this group).
Also the new LED light will be in so alot getting done for now.
The TUNG OIL on the wood inside turn out fantastic.
Still have to order the SOLAR PANELS controller.
But for now WILD TROUT and the BLUES call.
DAVE
Old 08-26-2009, 02:04 PM   #7
pjanits's Avatar
Trailer: 17 ft 1986 Burro
LOVE MY EGG
Thanks Dave
I think I would call Dexter and see what they recommend. Is it possible you axle is not 90 degrees to the frame? That would cause some funny wear for sure.
Old 09-10-2009, 09:57 PM   #8
OK I said I would get back to the group about my wheel alignment problem.
The alignment shop thought that we might add a shim to fix the problem, well no can do so have to go to another plan. So maybe a new axle (it is almost 10 years old) of maybe a shop that can rebend the axle, any ideals out there?
Thanks Dave
ps It is toed out 5/8 of an inch the camber does not seem to bad
Old 09-10-2009, 10:43 PM   #9
IllAnnoy
Dave
On a typical rear axle on a front drive car the axle can be aligned with shims because the spindle can be unbolted and shims placed behind the mounting point to make adjustments.
This can not be done on a typical torsion axle because the spindle is welded in place.
If you shim at the backing plate , you will only be moving the brakes and bearings and not the spindle , the result would be disastrous to the bearings.[ if you could move anything other than bend the backing plate which would be doubtful]
So unless you have a unique axle with a removable spindle, you will not be able to make adjustments.
BTW check for excessive negative camber as this in conjunction with towout indicates a worn or damaged axle.[ or cronicly overloaded.]
Tow-in should be slight on a new axle... about 1/8" or so {I think}
axle
Trailer Alignment Keith Williams General Chat 14 05-31-2009 03:34 PM
Magnetic Trailer Alignment Kit Patrick M. Modifications, Alterations and Updates 23 08-08-2008 08:15 PM
Trailer Alignment Kit Greg A General Chat 3 03-02-2008 05:45 PM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Hook-up Alignment andre robillard Problem Solving | Owners Helping Owners 1 04-26-2007 07:21 AM
» Trailer Showcase
Bolera
wcsaildon
ECO
Suanne
