Axle Alignment - Fiberglass RV
Old 07-10-2013, 10:55 PM   #1
Trailer: Forest River
Axle Alignment
Hello All: Have a 24 foot Forest River fibreglass enclosed cargo trailer that is wearing the outside of the front right tire. Any experience with alignment on the torsion (rubber-ride) axles??? I believe they are AL-KO brand 6000lb. Thanks in advance.........
bobsimpson is offline   Reply With Quote
Old 07-11-2013, 03:04 AM   #2
I had an Alko axle on my 16' Scamp. The tire wear was even with no problems.
You may be able to check some dimensions yourself regarding the axle mounting squareness. Measure from axle tips to tip of ball coupler. Also you could lay a straightedge across your front and rear wheels to look for excessive toe in. Toe should only measure
1/16" or so. If you hit a curb it could have bent a trailing arm or spindle.
Russ
Old 07-11-2013, 05:36 AM   #3
Here's how we did toe-in checks on truck steer axles; jack up wheels, clean off center of tires, spin wheels while spray painting center of tire with white paint. When paint dries spin wheel again with a pointed device against center of tire to make a mark around tire, remove jacks, drive truck forward 10 feet or so to set suspension in it's normal travel mode, measure between scribe marks at front & rear of tire to get toe-in measurement. Another method we later used was a piece of aluminum channel hung on the outside of the tires, hook a tape measure at front & rear of tire on to the one channel, read measurement at the channel on the other tire. On tandem axle trailers we had devices that went in the wheel and centered on the spindle, then measured between them to check the axle spacing. Used this same device to measure from the forward axle to the trailer kingpin, or in your case the center of the ball coupler. First step would be to measure front axle to ball to verify it being straight, then check the spacing if it's a tandem.
axle
door alignment on trill PhillyPhixy Problem Solving | Owners Helping Owners 19 03-27-2013 07:30 PM
Alignment Tamid Towing, Hitching, Axles and Running Gear 14 10-13-2010 06:21 PM
AXLE ALIGNMENT D Tharp Towing, Hitching, Axles and Running Gear 8 09-10-2009 10:43 PM
Trailer Alignment Keith Williams General Chat 14 05-31-2009 03:34 PM
Hook-up Alignment andre robillard Problem Solving | Owners Helping Owners 1 04-26-2007 07:21 AM
