05-12-2013, 12:46 PM
#41
Originally Posted by Jared J
I have never thought of an ifs vehicle as having a front axle.
I think that's common, but it is a specific use of "axle" which should really be something like "live axle" or "beam axle".
When an off-road enthusiast converts their independent front suspension (IFS) to not be independent any more, they don't call that an "axle conversion", they call that a "live axle conversion" or "solid axle conversion".
Originally Posted by franck2cv
Both manufacturers refer to those elements as front axle (replacement parts, maintenance etc...).
The combination of these parts (suspension, hub carriers or axle beam, hubs, bearings, drive elements, etc) is an "axle" for this purpose. This reinforces the idea that even without an integrated crossmember, the whole system is still an "axle". I'm not surprised that VW and Citroen follow this normal terminology practice.
Note that every vehicle - motor vehicle or trailer - has a Gross Axle Weight Rating for each suspension/hub/wheel/tire system... even an independent and non-driven front (steer) or trailer axle.
05-13-2013, 09:33 AM
#42
Trailer: Westfalia
Quebec
Originally Posted by ruscal
Francesca
It seems that a square tube inserted into the pocket of the suspension member would help counter the cantilevered loads that would have had to be resisted by the frame mounts alone. Since our trailers weren't designed to handle those loads It would be good insurance to add the cross member.
That cross member may be tucked up to the frame a little higher than the typical torsion axle tube, but your not buying much more clearance. If you do a lot of off-road travel you could "joggle" the cross member up between the frame rails and back down to buy a couple of inches if there is no other stuff in the way.
Russ
Could it look like this? (shorter tube going into the Timbren unit)
05-13-2013, 11:22 AM
#43
Franck,
You got it. The joggle would give 2" more ground clearance mid frame. I would put a 45 degree mitered joggle when fabricating the beam. Whoops I meant to say "cross member".
Russ
05-13-2013, 11:37 AM
#44
Trailer: Westfalia
Quebec
Russ
Yeah watch it !!....
05-13-2013, 11:42 AM
#45
Trailer: Egg Camper
Since we are arguing semantics, a live axle and a solid axle are not the same thing.
A pickup or Mustang uses a solid axle. Older quads and three wheelers use a live axle. In those cases the axle is live or solid with no difference of speed possible between ends of the axle. It could also be argued that a welded spool effectively makes a solid or IFS a live axle.
Back to the Timbren - I consider the axle to be the part that allows motive power to be transmitted to the wheels through a common source, OR the place holder of said axle. So the member that connects directly between the two wheels on a leaf suspension setup I would call an axle. The tube that connects between the two trailing arms in a torsion setup I would call a structural member, but not an axle.
Jason
05-14-2013, 10:55 AM
#46
Trailer: Westfalia
Quebec
Thank you all for your contribution.
In short.... The Timbren option remains a good theoretical option but it lacks the comforting feed back from an existing FG Timbren equipped trailer owner. Who knows.... It might very well be I....
Franck
05-14-2013, 11:14 AM
#47
Trailer: '78 Trillium 4500
This installation pic at E-trailer's page on the Timbren sure looks interesting.
It seems like with the added cross member talked about earlier it might work really well for clearance increase on a fiberglass trailer, or at least one that doesn't have a bunch of other stuff hanging under the trailer. Some have black pipes etc. hanging almost at the same height as the axle. The only way to achieve more road clearance on those is to raise up the whole shootin' match.
My Trillium doesn't have any of those underhangs, and the present overall height suits me just fine- especially since it's a couple of inches under the breakpoint for overheight charges on the ferry. It's good to know that there may be alternatives for increasing clearance without getting taller, too.
Thanks again, Franck!
Francesca
05-15-2013, 07:21 AM
#48
I like the design very much, but there may be issues for implementation for some of the older trailer designs. I know my Fiber Stream has the original frame, which was thin 1" x 2" hollow tubing. It was selected by the builder to reduce weight as much as possible. With such a fragile frame, I think going to an "axleless" design might remove one of the major strength components!
05-15-2013, 08:08 AM
#49
Francesca
Francesca
It would be cool to set it up with airbags and compressor for variable ride height for ferrys and low garage openings.
Russ
08-14-2013, 06:26 AM
#50
Originally Posted by GPJ
For example not all torsion suspensions require a cross beam (ie. torsion half-axles do not require a cross beam), and not all torsion axles "twist" the rubber.
Technically, then I would think it wouldn't be a torsion axle.
That's very true! I believe that many of what we call torsion axles are not true torsion axles -they compress rubber cords rather than twisting them.
If you think about it, the axle is being twisted due to an applied torque. Therefore it is a torsion axle. The rubber is merely resisting and damping the forces.
08-14-2013, 07:38 AM
#51
The arm rotates... just like arms in every kind of suspension. It is not distorted in torsion. The steel bar which is is used as a spring in the many variations of torsion bar automotive suspensions is distorted in torsion, and resists with a torque, but there is no such torsion element in the trailer suspensions (such as Dexter's Torflex) which are strangely known by the generic term "rubber torsion suspensions". They, like Timbren's not-so-axle-less Axle-Less, are simply trailing arm independent suspensions with rubber springs.
08-14-2013, 09:47 AM
#52
Brian,
I have to disagree with you.
A thousand pounds or so of bouncing trailer is applying torque to the portion of the axle suspended by the rubber within the housing. The metal has to transfer the torque from the arm to the rubber. To assume the transfer of forces has no torsional element defies logic.
I'll agree that the rubber undergoes a greater elastic deformation than the metal.
08-15-2013, 02:44 PM
#53
I think we have some confusion between the terms " torsion" and " torque".
I agree. A thousand pounds of axle load on the ends of two six-inch-long horizontal suspension arms applies a torque of 250 lb-ft to each internal bar.
A tube or bar transmitting torque is a "shaft", not necessarily a "torsion" anything. The driveshaft of a motor vehicle, for instance, ideally does not deform in torsion at all as it transmits torque. The bar inside the tube of a Torflex or similar suspension is a shaft, which turns but is not supposed to twist at all. Of course it does twist a tiny bit, but that is irrelevant to the suspension operation, which would be even better if the bar didn't twist at all.
Imagine if the rubber was left out of a Torflex, and the bar inside the crosswise tube was instead anchored (at the inboard end) to the tube. If the bar didn't twist, there would be no suspension action at all. If it did twist, then it would be a torsion bar, because it would be the springy part, moving in torsion. BPW - a company in Europe similar to Al-Ko in scale and product line, has a trailer suspension that works exactly this way, called Rondo. That really is a (steel) torsion spring suspension (and so it needs dampers -shock absorbers - which are optional on the rubber-sprung models).
This whole "torsion" discussion comes out of Timbren's accusation that torsion is bad. That is nonsensical in itself, so I think the whole "is it a torsion system" discussion is really a red herring. The importance to me is that people understand how these design really work, so they can decide if the differences are important to them and which one is preferable. Choosing the Timbren design because "the other ones twist the rubber and that's bad" makes no sense when most the others and Timbren actually deform the rubber in nearly the same way and there's nothing wrong with twisting a block of rubber anyway. The ideal way to use a block of elastomer as a spring is probably in shear, anyway.
08-16-2013, 07:02 AM
#54
A good explanation, as usual.
09-24-2013, 11:55 PM
#55
Trailer: Chevy AWD Van Conversion
Astoria Oregon
i just finished a read through this older & interesting thread (since i might be doing some sort of axle fix on my PL)... and the mention of Citroen brought up some fun childhood memories of driving around in the family Citroen DS19. Sometimes my dad would let me adjust the hydraulic suspension. I recall one trip to the Red Bluff round up...big ol' farmer's trucks all about, my dad and i in the Citroen...bad road to the area, he makes the adjustment and the suspension must have put us up another ~6" or so, the farmers in their trucks were looking at us like we were from another planet ; )
...might be fun to have on a TV&TT. No steps needed into rigs at camp!
09-25-2013, 05:16 AM
#56
[QUOTE=accrete;420567..........the farmers in their trucks were looking at us like we were from another planet ; )..........[/QUOTE]
Maybe it was the dribbled green blood from the Citroen.
01-11-2014, 05:44 PM
#57
Trailer: Scamp 13' 1977
Wow! Didn't learn that much about the Timbren system, but I sure know a LOT about symantics now! I am about to try the "Axle-less" system on my Scamp 13 (1977). I am going to cut off the original axle at the ends (spindle, etc), but LEAVE the axle rod/enclosure/tube/whatever (have fun on this one. I expect at least a dozen replies about he NAME of it! Don't disappoint me now!) franck2cv I think, showed a picture of a square tube with an offset piece to go into the Timbren parts. I plan to try doing this but using the original axle as the "tube" and adding the "offset" part in front of ( or behind) it, so as to have the Timbren unit tight against the frame, such as it is. Other than spelling, symantics or "What I would do" comments would be greatly appreciated. Totally a newb ay trailers and such, just want to GET OFF THE GROUND when we go camping on mining claims!
You guys are ALL great, but why does everyone HAVE to answer questions with pure opinions? It is like ragging the kid in class who actually wants to know something, but the other kids mess with them just because they don't! I may be different or too old for these forum things, but when I ask a question I am looking for answers, not guff. Almost every one I belong to get dozens of relies ranging from (mostly) "I don't know anything about it, but...", to "I wouldn't do that", or my favorite, "WHY do you...".
Sorry, have MY bugaboos just like the rest. Just hate to waste OTHER peoples time.
(rand end. Message complete. SEND)
Paul Andreasen, TSgt, USAF (Ret) K1JAN
ROMAD, 601st DASS
(There's no such thing as an Ex-ROMAD)
Born in MAINE, living in Exile (Lompoc, CA)
01-11-2014, 07:05 PM
#58
Trailer: Class A Motorhome
Quote: "You guys are ALL great, but why does everyone HAVE to answer questions with pure opinions?"
I think if all someone wants to hear is expert advice that they should be prepared to pay for it.....
Opinions, rather than expert advice, are the rule on these sites if, for no other reason, liability.
On one site I am on, a member actually tied to sue another for posting what turned out to be incorrect information that lead to some monetary losses. So, all I ever offer is my opinion, and it's worth every cent paid for it.....
BTW: That suit went nowhere. if only because one was in CA and the other on the east coast.
But I can understand why you are so critical of what you get for free, I once spent a week in Lompoc one night myself.
01-11-2014, 07:25 PM
#59
Paul what do you expect? OMG, gain knowlege. Not just here at FiberglassRV, but the entire WWW and your local trailer builder. It's a whole less about us, but a whole bunch more about you. AND, you do know if you cut the torsion portion out of the axle out of your trailer... you end up with nothing more than a piece of tube... or pipe!
01-12-2014, 12:58 AM
#60
OK folks! BACKUP and stop shooting! I BADLY wrote and misposted. I REALLY DO like the OPINIONS and ADVISE (and yes expert advise SHOULD be paid for). I jsut get so frustrated about people who post useless comments and NON-knowledge rather than answering any questions. It happens everywhere (here included, I have been reading on here for about 100+ HOURS so far over the last several months!) and I guess making my frustrations known about it with MY FIRST QUESTION was dumb or worse. The problem is, I am a knowledge junky. Everything I get into like this (and there have been SO many) I really want to know all I can. Donna, I think I have read every post you and several other ever made! Thanks! That smile on your avatar is evident in every post! Me, I am not a social animal (never would have guessed it, right?) I do like how so many post encouragements and attaboy (& girl of course Maam!) but still so many just want to POST! If I have already upset/PO'd/tickled/ticked anyone, I hereby apologize and promise to have my oldest daughter (My "adventure buddy" who will be sharing this with me) whup my butt with a rose bush! She may anyway as I tore it up thinking it was a weed! Oops, my bad....
THANKS YOU to ALL. I admit I have copied, downloaded, scanned, cut & pasted (you like the taste of school glue too?) more data off this site than I will be able to read before they plant me. And every bit of it is great! If I even tried to do all the mods I found fascinating, I would have to buy 8 more Scamps, and hire help!
So, if you'all will fogive a po old man, I will start again with "tha propa attitude"!
Blame it on where I live here in the Peoples Republik. And BOb, I haven't read all yours yet, but I AM working on it! Boy you post a lot! Yes, Lompoc IS a little, ah, different. I call it the ebay capital of the world, because you can't buy ANYTHING here except groceries! And for a town of 40K+, that ain't good!
Paul Andreasen, retired, retarded reprobate/and ignobly awaiting forgiveness
Born in MAINE, living in Exile!!
ROMAD, 601st DASS
