Axle question....79 Surfside - Fiberglass RV
Old 05-12-2008, 04:48 PM   #1
Trailer: 1978 Surfside
Hey guys.....
So had the hubs off the surfside today to inspect/repack the bearings and seen that the axle seems to have a little bend in it, just wondering if this is normal or it got bent somehow.
Thanks
Kent
kentj is offline   Reply With Quote
Old 05-12-2008, 05:06 PM   #2
Howdy, some axles, Rubber Ride and/or leaf sprung are bent up in the middle in order to give you proper camber angle of the spindles.......or.......yours may have been jacked up in the middle by a previous owner, which could also cause the arch.....don`t know for sure!......I assume it`s usually easier for axle manufacturers to weld the spindles in straight in a jig and then bend the complete axle at the end of production....Benny
Old 05-12-2008, 05:09 PM   #3
Trailer: Triple E TM14
My 77 Surfside has the same bend. It is normal.
Cheers,
Mark
Mark B1 is offline   Reply With Quote
Old 05-22-2008, 03:03 PM   #4
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Hey guys.....
Thanks
Kent
Hi, I don't know about your particular axle, but my 74 Boler 13 (Winnipeg made) has the same brand with a similar nameplate on it, except I think it is rated at 1200 pounds (not certain because of corrosion). That axle is perfectly straight.
Rick in Edmonton
Rick G is offline   Reply With Quote
Old 05-22-2008, 06:49 PM   #5
Rick in Edmonton
Thanks for the info...my axle is rated for 1650lbs and seeing mine and another have that bend I'm thinking that it should.
Old 05-22-2008, 08:01 PM   #6
Pete Dumbleton's Avatar
Many (most?) axles have a little bit of upward arch for additional strength. That's why the term 'flipping' a leaf spring axle is often incorrect.
Old 05-22-2008, 10:42 PM   #7
Roy in TO's Avatar
Like most others have said, it is probably a normal part of manufacturing.
Have a look at the location and symmetry of the bend. If it is centered and symmetrical most likely it was built in. Off center with a dent in the axle most likely abuse.
I gotta stop watching CSI ....
axle, surfside
Surfside axle kentj Towing, Hitching, Axles and Running Gear 2 08-23-2011 07:13 PM
Surfside tire diameter question Karl S Care and Feeding of Molded Fiberglass Trailers 1 07-24-2009 05:39 PM
And yet another axle question?? Don N Towing, Hitching, Axles and Running Gear 19 01-11-2009 10:32 AM
Another Axle Question Orion W Towing, Hitching, Axles and Running Gear 8 01-29-2008 11:03 AM
Axle question....79 Surfside kentj Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
