Axle Riser - Fiberglass RV
Old 08-03-2007, 11:34 PM   #1
http://www.fiberglassrv.com/board/index.ph...;hl=axle++riser
Any information on pricing, or description, would be very nice. Thankyou
Janine is offline   Reply With Quote
Old 08-04-2007, 01:34 PM   #2
Pete Dumbleton's Avatar
The riser was likely something like a couple of pieces of 1" square steel tubing out of the welder's scrap box welded between the trailer frame and the axle bracket. Cost would be in the welding labor and would be what your local shop would estimate.
When people want to raise the whole trailer, one way to do it is weld pieces of the box steel that the frame is made from between the frame and bracket.
If you are considering having the welding done, also consider getting the weld-on bolt-on axle bracket from Dexter that's welded to the frame so the axle can be bolted to it. This allows later replacement of the axle as just bolt-on job with no welding required.
All of the above presumes you have something like a Dexter torflex axle welded to your trailer's frame.
Old 08-04-2007, 09:33 PM   #3
Mechanic has trailer, was emailed above...see what he says Mon/Tues. Thank-you.
axle
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
What's the best axle to buy? mcnick Towing, Hitching, Axles and Running Gear 4 01-29-2008 04:32 PM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Axle JohnWalker Towing, Hitching, Axles and Running Gear 5 04-21-2006 07:57 AM
NEW AXLE Dan Quinn Care and Feeding of Molded Fiberglass Trailers 13 03-19-2006 07:55 PM
