Beachcomer hitch size - Fiberglass RV
Old 07-16-2013, 05:08 PM   #1
Trailer: Beachcomber
New Brunswick
Hello, I have a 79 Beachcomer, what ball size should I use on my trailer hitch? Thanks
Dollard
Camper Beachcomer is offline   Reply With Quote
Old 07-16-2013, 05:24 PM   #2
Dollard
That's easy, what size is on your trailer?????
Old 07-16-2013, 07:43 PM   #3
Brian B-P's Avatar
The ball size is normally (probably always) stamped right into the top of the coupler on the trailer... just read it and use that size. North American balls are all 1-7/8", 2", 2-5/16", or (rarely) 3", and for a trailer the size of a Beachcomber it will almost certainly be 1-7/8" or 2". If a 2" ball fits in, that's probably the size; if it won't, it's probably 1-7/8"... but again, to be sure read the markings.
Markings are often obscured by paint, so some paint stripper might be called for.
It might seem like there should be a ready answer, but trailer components can change from year to year, or even day to day, so there is no way to be sure what was used on a particular brand in a particular year. Couplers are also replaced when they wear our or are damaged (or if the owner just prefers a different style), so even if we knew what it came with, we couldn't be sure what it has now.
Old 07-16-2013, 09:53 PM   #4
New Brunswick
Thank you all. I checked the hitch and theres no markings. I have both sizes ball, the 2" ball those fit so I will use that one. but I will use paint remover and see if there isn't a size under many years os paint. Happy Camping.
Dollard
Weight Distribution Hitch-What size to use ? David in Fernie Towing, Hitching, Axles and Running Gear 63 03-28-2013 08:20 AM
HELP! At trailer hitch place, what size ball do I need? joy mccalla Towing, Hitching, Axles and Running Gear 5 01-18-2010 08:48 PM
Wrong size hitch ball Kevin K General Chat 10 06-23-2009 04:09 AM
Is it the right size weight distribution hitch Jmercuri Towing, Hitching, Axles and Running Gear 14 07-03-2008 07:38 PM
Ball Hitch size for '82 Burro Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 08-15-2003 09:39 AM
