Bent Axle? - Fiberglass RV
Old 08-03-2003, 03:15 PM   #1
Bent Axle?
My '86 13ft Casita tows great but tires wear badly on the outside edge. I assume the axle is bend. I was told this type of axle could not be corrected by rebending. I have not had the camper looked at by an axle expert. Has anyone had a tortion bar axle repaired?
Old 08-03-2003, 04:25 PM   #2
Ed you might go to the Dexter web site and see what you can find out.
A few people have replaced them.
Go to search in the upper right hand corner and enter Dexter or Dexter Axle. There should be a lot of information there.
Old 08-03-2003, 05:13 PM   #3
wear on the outside? I figure if the axle is worn it would wear on the inside. logic thinking, not experience.
Old 08-04-2003, 12:26 PM   #4
Not worn, but bent. If, for instance, someone ran the wheel hard against a short tree stump in a campground, it could actually bend the axle arm inward slightly, which would cause the leading edge of the tire to wear prematurely. My father had this happen on his fifth wheel. He had his axle replaced to correct the problem.
axle
17Ft Bigfoot Axle - bent? Dave_L Towing, Hitching, Axles and Running Gear 10 09-14-2009 12:04 AM
New Axle kentj Modifications, Alterations and Updates 1 07-05-2009 03:09 PM
Bent Awning Extension John & Sandy M Problem Solving | Owners Helping Owners 1 04-18-2009 08:57 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
bent axle? Legacy Posts Towing, Hitching, Axles and Running Gear 7 07-21-2003 11:18 PM
