Best hitch locks? - Fiberglass RV
Old 05-30-2014, 03:35 PM   #1
Best hitch locks?
New to trailering, I was wondering what the best hitch pin locks are and best unattended trailer hitch locks. Also, any review on a Trimax SXT3 receiver lock would be helpful.. Thanks.
Slim is offline   Reply With Quote
Old 05-30-2014, 04:40 PM   #2
Trailer: Fiber Stream
I have had good service from my Master Lock set. I have a 3 piece set in a storage bag. This is the new equivalent:
3794DAT - Master Lock®
My trailer came with a padlock for the coupler bail that I continue to use combined with my 377DAT - Master Lock®.
Old 05-31-2014, 10:22 AM   #3
Thanks for good information, Frederick...I will look into that.
Old 05-31-2014, 10:31 AM   #4
Frederick; can you close the coupler with the 377 in it ?
Old 05-31-2014, 01:56 PM   #5
Wallo's Avatar
Utah
I cheaped out and went with a MasterLock padlock from WallyWorld. The it has to be removed from the coupler before engaging or disengaging.
Alice
Wallo is offline   Reply With Quote
Old 05-31-2014, 04:28 PM   #6
I don't know of a lock that can't be hacked off so I just go for the Master Lock Wallo uses. The thing is to have the lock so the there will bypass your camper for an easier one. Something to think about: They do sell wheel locks that cover the lug nuts on the wheel and also prevent the unit from moving. Police use these types of locks to put on illegal parked cars so the fine is paid B 4 the vehicle can be moved. Most likely expensive but more secure than the Master lock.
Try this site: http://www.universalboot.com/
Old 05-31-2014, 08:39 PM   #7
Perry J's Avatar
Trailer: 16' Casita
I use an old 2" trailer ball and a padlock like Wallo to secure my trailer.
My neighbor had one of those $40.00 fancy locks on his boat trailer and they stole it out of his side yard last week.
If they want your trailer they will get it.
John
Old 06-01-2014, 08:37 AM   #8
Thanks for all the good information and options everyone.
Thieves are among the lowest of the lowest. They steal not only one's possessions, but their peace of mind too.
Old 06-01-2014, 09:39 AM   #9
Had a trailer lock about 35 years ago that featured a sleeve over the locking arm which went through the hitch lever. If anyone could get a saw blade in the thin space between hitch lever and lock, the sleeve would only roll and make cutting difficult. Don't know where that lock went but I covered (I was a reporter) a boat and trailer theft once where the entire rig was inside a garage and had double locks on the hitch. It also had 1 inch cables attached through the trailer chassis and welded to iron supports coming out of the ground. When the stolen unit was recovered later the thief said he simply used a tow truck to latch onto the trailer and pulled it away after breaking into the garage and using a cutting torch on the cables. He never could figure how to get the locks off before he was caught.
J.R. is offline   Reply With Quote
Old 06-01-2014, 11:14 AM   #10
My picture in post #2 shows the 377 locked in the closed coupler and the bail is locked in the closed position. The coupler latch lock's shank that came with my set is too short for my wide bail, thus the continued use of the long shank padlock.
Old 09-20-2014, 04:35 PM   #11
Cathi's Avatar
POBox 1267, Denison, Texas
Can't tell if this lock is worth anything but that's what we have. Seems as if someone could pull it off but it is very tightly on. Don't know. It is something for someone to have to bother with at least a little. There is a section of it up inside the coupler. Keys are round.
Old 09-20-2014, 04:55 PM   #12
Trailer: In the market!
I picked up a Reese coupler lock. I figure it is a start and was $22 at Auto Zone then I saw that Wal-Mart carries them too.
SimplyLesa is offline   Reply With Quote
Old 09-20-2014, 05:23 PM   #13
Thanks Cathi and Lesa. Lots of choices, seems like most are comparable. I have come to conclusion nothing is full-proof, just make it as hard as you can for the thief.
Old 09-20-2014, 08:09 PM   #14
IllAnnoy
I use a Masterlock stainless steel hitch lock. It works well to assure that the hitch stays put when towing and it doesn't rust. These are pretty much equal imperatives. While it may also work as a theft deterrent, that is just not a big concern considering the remote likelihood.
I once had a ball mount lock rust in place and I had to cut it off, so corrosion resistance is a big factor for me.
The ball mount lock is important to assure that the ball mount stays in place and to prevent tampering or theft. My guess is that the theft of a ball mount is a thousand times more likely than the theft of a trailer, not to mention the danger if some idiot just decides to pull the pin (about like pulling the pin on a handgrenade)
Locksets for both which are keyed alike are available to help reduce that "jailor" feeling from carrying too many keys!
Those 'elusive' Bargman 400 locks Doug Mager Parts: Buy | Sell | Trade 27 10-15-2013 06:38 PM
Best methods to fill holes & best glue Becky B Problem Solving | Owners Helping Owners 19 08-11-2012 08:14 PM
Trailer Wheel Locks E. Graham Towing, Hitching, Axles and Running Gear 5 08-13-2007 01:16 PM
Door locks Rev. Lee Cook Problem Solving | Owners Helping Owners 7 04-17-2006 08:12 PM
Hitch locks Yves Pelchat Towing, Hitching, Axles and Running Gear 15 02-07-2006 04:58 PM
