Best option for bicycle rack? - Page 3 - Fiberglass RV
Old 05-31-2011, 11:02 AM   #29
Originally Posted by Daniel V. View Post
For us, the biggest reason not to consider carrying bikes on the trailer was that we rarely, if ever, go cycling anywhere near the campground. We pretty much always take them elsewhere where the nicer paths are, therefore the bikes need to mount somewhere in/on/behind the vehicle.
YES same here.
Old 05-31-2011, 12:16 PM   #30
IllAnnoy
We carry a receiver rack which is not much more than 3ft of 2" tubing, whenever we anticipate traveling by car to a jump off point.
Old 05-31-2011, 02:50 PM   #31
Jenny W.'s Avatar
Trailer: 1976 Scamp
Originally Posted by Sam and Jess View Post
A few links might help with some of the issues mentioned above:
Sounds like you're happy with your roof rack Carol, but for anyone else with a wobbly hitch rack, a little hitch stabilizer can help steady the wobble -- maybe slightly more than wedging a random object in there It only adds a few seconds to the install/uninstall. You might also try calling your manufacturer for help with that too, as they all have pretty good warranties and really want their logo-covered products out there on cars!
I have the over the tow bar bike rack and noticed the amount of play. I was concerned and looked into a stabilizer. Went to a hitch store and asked about them. The guy said that as the vehicle tows, the steel heats up and expands. He said the wobbling was normal when not in use but goes away once you're towing. Hard to argue with someone who is an expert in hitches, but I'm a little skeptical. However, it does make sense.
I couldn't do a roof rack because I already have a roof rack for my kayak. Plus, I'm not very tall and lifting a bike up there would be difficult.
Jenny W. is offline   Reply With Quote
Old 05-31-2011, 03:01 PM   #32
Greg H's Avatar
Trailer: 72 Boler American
Indiana
[QUOTE=Jenny W.;253297]
QUOTE]
You believe that? I've got some lake front property for sale here in Terlingua.
Old 05-31-2011, 03:13 PM   #33
Jenny W.'s Avatar
Trailer: 1976 Scamp
Wow. Glad you found that so funny. I was just sharing what I was told...
Old 05-31-2011, 03:17 PM   #34
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Jenny W. View Post
Went to a hitch store and asked about them. The guy said that as the vehicle tows, the steel heats up and expands. He said the wobbling was normal when not in use but goes away once you're towing. Hard to argue with someone who is an expert in hitches, but I'm a little skeptical. .
Hi, Jenny!
I think your skepticism is well founded.
Since the heat the guy's talking about must be generated by the friction created by the movement of the bar, it won't "expand to fit" unless it fits so badly that it's in constant motion rubbing against the receiver to the point that enough friction is created to create the heat that expands the bar to fit the channel that the bar wasn't designed to fit tightly into to begin with.
And I hereby award myself the prize for the most unintelligible reply ever posted at FGRV!
Francesca
Old 05-31-2011, 04:04 PM   #35
Greg H's Avatar
Indiana
"Don't believe anything you hear and only half of what you see". There's not even that much heat here where I live.
Old 05-31-2011, 09:04 PM   #36
Jenny another way to get it to fit a bit better is to wrap some duct tape around it to fatten it up a bit.
Old 05-31-2011, 10:12 PM   #37
IllAnnoy
I had a loose Class III hitchball bar and found the tape to be an excellent solution. For a more permanent fix however, I simply welded a bead across the bar just at the point where it enters the receiver,then ground it off and test fitted it 'til it was a perfect fit and rattle free.
Old 06-01-2011, 08:41 AM   #38
Jenny W.'s Avatar
Trailer: 1976 Scamp
I do have duct tape added to it. Helped maybe a little, but it still wobbles. And let me clarify - it wobbles when not in use. I am a cyclist and keep my bike rack/tow bar installed on my Jeep. When I tow, I haven't noticed any problems whatsoever.
If the wobbling when not in use is not normal, what frustrates me is that these are standard receivers and extenders. Both Curt brand. There must be a reason why they don't fit snug.
Being that this is the first trailer I've ever owned and the first thing I've ever towed, I don't have anything to compare it to. I also forgot to mention that I had gotten a second opinion from another hitch store. They too said a little bit of play was normal (but didn't give me the whole bit on expanding steel).
Old 06-01-2011, 09:12 AM   #39
IllAnnoy
If you want to know why a little play is needed in the receiver... try leaving the ballbar in place for a couple of winters. The snug ones can rust in place so profoundly that the retaining pin seems to become a redundancy. the mod that I earlier recommended involves only the first 1/4" to 3/8" of the opening for this reason.
Check this out...
Hitch Accessory Anti-Rattle Device Review Video | etrailer.com
Old 06-01-2011, 09:27 AM   #40
Trailer: 13 ft Scamp
Anti-wobble brackets can be purchased from Northern Tool for $20. The wobble is "normal" since there needs to be enough play to insert the tubing into the receiver. This is not noticeable when towing since tongue weight presses down heavily onto the ball. It's also not noticed when the ball is attached to the receiver when not towing or carrying since what is sticking out is so small (grab it and shake it and you'll see the slop.) When using a rack or platform this needed space is now projected much wider due to the mechanics and design of the accessory. When using a receiver hitch in this manner I am more comfortable using the anti-wobble bracket.
Darnelle is offline   Reply With Quote
Old 06-01-2011, 10:04 AM   #41
Greg H's Avatar
Indiana
What Darnelle said, most receiver hitches are meant to pull and or carry a load when tongue weight is applied the the rattle goes away.
How small is small? How about a bicycle/motorhome hybrid? John Mc General Chat 9 11-30-2012 05:42 PM
Mattress option Per Walthinsen Problem Solving | Owners Helping Owners 1 07-28-2009 04:05 PM
Another AC option Roddy D Modifications, Alterations and Updates 2 06-17-2009 08:54 PM
Bicycle carrier and ball hitch, real or imagined? Denise K Problem Solving | Owners Helping Owners 12 04-19-2007 08:46 AM
