BFG All Terrain trailer tires? from VW van folks - Fiberglass RV
Old 11-29-2012, 07:32 AM   #1
Trailer: '78 Trillium 4500
Not looking to start a huge debate over ST vs LT tires, but have got some ideas from VW bus folks who require a similar tire that we do for their 5500 lb beasties.
Considering that over 50% of our trailer use will be on gravel forestry road on Vancouver Island and throughout BC, predominantly in off season/winter months is there a good/valid reason not to go with a tire such the D rated (8ply) 3ply-sidewalled BFG All Terrain LT Tire (Tire rack link)
Specs:
LT195/75R14 25.5" diam
Speed/load rating: 99/96R D
Max load: 1710 lbs @ 65 psi
Tread: 16/32"
Weight 31 lbs.
These sound very much like the Kumho Radial 857, but with an A/T tread, which I wonder if it will be too 'squirmy'
I can't find a decent ST tire around here so will have to order tires in, I can source these locally though, the tire dealer originally suggested Yokohama Y370's then came up as he had used successfully when he was a VW van dude.
Anybody tow with these tires on a trailer? Squirmy? Any valid reasons NOT to go with these given the intended application?
Thanks for any constructive feedback
Dave_L is offline   Reply With Quote
Old 11-29-2012, 07:52 AM   #2
I think that "squirmy" might be the right word. But, in as much as you don't need the tread for steering and/or drive axles, you might look at the Yokohama Y-356 series, Load Range "D", in 185R14 size. I have had a lot of experience with that tire on 6000 lb mini-motorhomes without any issues. And they cost a bit less.... Here's a link:
http://www.tirerack.com/tires/tires....omCompare1=yes
Old 11-29-2012, 08:01 AM   #3
Yok's
Thanks Bob,
The 'Canadian Edition' of that tire is the Y370, another tire I can source locally. I'm hoping for something that can with stand a fair bit of gravel road travel - how do the y356's fair?
Old 11-29-2012, 09:11 AM   #4
Specs:
Tread: 16/32"
Weight 31 lbs.
Dave, being an Island girl I suspect I might have traveled on some of the roads you are considering. Over the years I have gone along for the ride on a fair number of boat hauls etc out to the Gap and Bamfield and have had my trailer spend a couple of summers on the island on the back roads in that area as well. Yup those roads do eat tires. But I am not totally convinced they eat proportionality more ST's than others. In 2 summers of travel on such roads with my trailer I did develop a leak in one ST tire that was about 3 years old at the time - but have been in far more tugs that developed tire issues as a result of those roads over the years than the trailers they are hauling and some had brand new tires. So for whats its worth, depending on how much more the tire you are considering costs it may not turn out to be a better value.
Old 11-29-2012, 09:50 AM   #5
US
livin-lite hardsided them from the factory with an offroad package. Here is a CL13QB
Old 11-29-2012, 09:54 AM   #6
US
You can call them and ask them about it is an idea. another photo
Old 11-29-2012, 10:40 AM   #7
I'm a believer that the load rating on each trailer tire should be greater than the 1/2 the total weight of the trailer. But double or more, I also think can cause more problems. The larger load rating creates a harder tire which will bounce and vibrate more causing damage to the trailer. Consider that it might be false economy.
Old 11-29-2012, 10:53 AM   #8
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
...The larger load rating creates a harder tire which will bounce and vibrate more causing damage to the trailer. Consider that it might be false economy.
Not so much if the bigger tire's inflation pressure is set for the actual trailer load. If you don't know the actual load, reducing the bigger tire's inflation pressure to that which handles the smaller tire's max load should mitigate the hardness. i.e. the larger tire can carry the same load at a lower pressure than the smaller tire. But if you run both at each tire's max inflation pressure I'd agree with your thinking.
Old 11-29-2012, 10:55 AM   #9
Originally Posted by Steve L. View Post
Not so much if the bigger tire's inflation pressure is set for the actual trailer load. If you don't know the actual load, reducing the bigger tire's inflation pressure to that which handles the smaller tire's max load should mitigate the hardness. But if you run both at each tire's max inflation pressure I'd agree with your thinking.
Well here we go again. Remember Ford Explorer and tires?
Old 11-29-2012, 11:34 AM   #10
Oh PLEASE Byron lets not go there again hopefully they have all had their tires changed by now!
Old 11-29-2012, 11:39 AM   #11
Originally Posted by carol h View Post
oh please byron lets not go there again Hopefully they have all had their tires changed by now! :d
You're right, that's a bad place to go just like religion and politics.
:d:d:d
Old 11-29-2012, 11:45 AM   #12
Byron raises another good point that may have more impact on a fiberglass trailer than a stick trailer. I know that while traveling the back roads on the Island that they can be very wash board resulting a rough ride. I have had a few rivets snap in two while driving on those roads. Indicating that even with the ST tires there is a great deal of flex and bounce taking place. Better to have the rivet snap than the fiberglass crack. I also know of a very $$$$ fiberglass boat that the transom cracked on after a summer of running on those back roads with a large engine on it - it had to be sent back 3000 miles to the factory for repair as a result. Putting to stiff a tire on fiberglass trailers on rough roads may have an unexpected fall out.
Old 11-29-2012, 11:49 AM   #13
Thanks for the link Ken, thought I saw them somewhere, but wasn't sure. And Carol, thanks for your info and for quickly donning a moderator-ish hat
Old 11-29-2012, 12:04 PM   #14
Steve L.'s Avatar
:d:d:d
And spectacularly off topic!
tires
CA | SOLD: 1978 Van Mate fiberglass pop up Travel trailer , 1978 Van Mate , Beyond RARE Bob Guilliams Classified Archives 12 03-15-2012 07:44 PM
GMC Terrain does the trick! RSchleder Towing, Hitching, Axles and Running Gear 12 12-02-2011 05:18 PM
Trailer tires or car tires? serious sam Problem Solving | Owners Helping Owners 4 05-15-2011 10:13 PM
