bias ply or radial tires - Fiberglass RV
Old 10-05-2011, 05:15 PM   #1
Trailer: boler 1300
Manitoba
Hi everyone,
I have read most of the post regarding tires. I've got a newly acquired 1300 '70 boler that has been sitting for about ten years in a field. It has 155/80/r13 on it right now that are fairly weather cracked so i am in need of new tires. I will most likely got with the recommended ST175/80/R13 tires but no one has mentioned whether radial or bias is best. Im thinking that bias ply tires would make the trailer pretty bouncy on the road going over bumps and such, but think that radials will make the suspension to stiff and produce the same results. Anyways, what are your suggestions/comments.
Thanks
Tyler
Mr.Gauch is offline   Reply With Quote
Old 10-05-2011, 06:45 PM   #2
Trailer: Trillium 4500 1977
Quebec
Radial or bias
Originally Posted by Mr.Gauch View Post
Hi everyone,
(...) Im thinking that bias ply tires would make the trailer pretty bouncy on the road going over bumps and such, but think that radials will make the suspension to stiff and produce the same results. Anyways, what are your suggestions/comments.
Thanks
Tyler
Radial tires or bias tires can both be used if the load rating and proper inflation is respected. Regular car tires are a very poor substitute. Their load rating is often barely sufficient and they are too flexible to prevent sway, which is potentially very dangerous.
I use ST (small truck - "trailer service") 6 ply radial tires on my 15" Trillium and I see no use for my sway bar so far ! In my humble opinion, it is not worth to settle for less than 6 ply radial or Bias tires. Bias are cheaper and may last as long as radials. Radials are likely to be smother and reduce vibrations, but to which extent ? Examples: http://www.atvandtrailertires.com/trailer_catalog.pdf
High loads, side winds, bouncy curves are all potential causes of sway that are minimized when your tires sides are stiffer with 6 ply. Cheaper softer (4 ply) sides tires will cause your tires to wear prematurely on edges, increasing chances of flat tire or blowout. They won't last and will make the ride quite more stressfull.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 10-05-2011, 09:51 PM   #3
Radar1's Avatar
Name: Dave (and/or John)
My Scamp came with radials and I replaced those with radials. I upgraded to "D" rated tires that can carry more air pressure and have a higher load capacity.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 10-06-2011, 03:26 PM   #4
Quebec
CORRECTION : ST tires...
Originally Posted by lamimartin View Post
Radial tires or bias tires can both be used if the load rating and proper inflation is respected. Regular car tires are a very poor substitute. (...) I use ST (small truck - "trailer service")...
ST stands for Special Trailer or Trailer Service, but not "Small Truck" (thanks to Brian B-P).
I understand that many of us use regular car tires (I have one as a spare), but I clearly prefer to exceed the minimal load capacity car tires offer compared to ST tires. I've experienced more sway and bouncing on tent trailer I previously had simply because I used the cheapest 4 ply trailer tires. The closer you are to the rated limit, the higher the risk of trouble in my humble opinion. Consequently, shorter and lighter RV may not need 6 ply and may do with car tires, but I think my 15' Trillium 4500 is too heavy with the added equipment to take any chances with the tires. I like it just the way it is.
I also want to point out that the link to DURO tire catalog is not an endorsement of any kind, but only an example of what was commonly available as Radial, Bias, 4 and 6 ply tires in the dimension he was looking for (ST175/80/R13). There might be better brands, but I think targeting a few brands 6 ply tires in that dimension is a good idea.
I hope this will help clarify the matter and forgive me if I confused someone with my opinions based on my own experience.
Martin J. Qc Canada
Old 10-06-2011, 04:13 PM   #5
Quebec
Interesting information about Special Trailer Service tires from Tire Tech Information - Load Range/Ply Rating Identification
Special Trailer Service tires are often available in multiple load ranges. The appropriate load range is identified immediately following the size's rim diameter in Tire Rack's descriptions.
ST-Metric sized special trailer service tires will be branded with their load range (Load Range D or LRD) on their sidewalls and list their appropriate load range letter in their descriptions as ST205/75R15 LRD.
ST-Metric Trailer Service Tires
Load ----- Ply
Range---- Rating - Markings - Max Load Pressure
B-------- 4 -------- B -- ---- 35 psi (240 kPa)
C-------- 6 -------- C ------ 50 psi (350 kPa)
D-------- 8 -------- D ------ 65 psi (450 kPa)
E-------- 10-------- E -- ----- 80 psi (550 kPa)
Note that in US and Canada, it is quite common to find only the old "ply rating" instead of Load Range in tire catalogs. Again, thanks to Brian B-P to remind me I'm a little old fashion
Martin J. Qc Canada
Old 10-07-2011, 07:45 AM   #6
The Minimalist's Avatar
Louisiana
Fuel mileage is another consideration. Radials do better in this respect.
Anyone out there changed from bias to radial and compared mileage? How much better was it?
Clif
Old 10-07-2011, 02:08 PM   #7
honda03842's Avatar
Name: Norm and Ginny
Tire Pressure
I've never measured the difference between tire types but high tire pressure do help mileage. I run my tires 6-13 pounds higher (13 in the rear and 6 in the front) than Honda's normal pressures when towing unless I am on a gravel road for extended periods.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-08-2011, 10:55 PM   #8
LukeP's Avatar
Iowa
Earlier this summer I replaced some old bias ply tires with ST Radials. Not a fair comparison unfortunately, as the old tires were indeed very old - I replaced with Maxxis M8008 ST radials. That said, the old bias ply's were quite squirrely, the new radials are solid.
I did a bunch of reading on some trailer and boat forums too, for recommendations of bias v. radial and also brands. Seems like there are love/hate relationships with about every brand out there! The Maxxis had few bad reviews across the forums... not a very technical method to narrow down the options - but when everything else seems equal, it's a starting point! We've put less than 5000 miles on them, but I'd give them a big thumbs up so far.
LukeP is offline   Reply With Quote
Old 10-08-2011, 11:02 PM   #9
Trailer: 1984 Scamp 13'
Maryland
Let me light a match... and throw some GAS on it!
Speaking of tires, let's remember something about tire pressure:
MAX means MAXIMUM.
MAX does NOT mean APPROPRIATE or CORRECT.
Old 10-09-2011, 09:45 AM   #10
Quebec
Is it OK to have a bias for properly inflated radials ?
Martin J. Qc Canada
Old 10-09-2011, 09:29 PM   #11
Maryland
Not sure what you are trying to say... But "properly inflated" is the operative term. There are a lot of folks here who believe that all tires should be inflated to the MAX sidewall pressure. Even though the companies who make the tires, and the companies who make the trailers tell them to do otherwise.
-Jesse
Old 10-09-2011, 09:42 PM   #12
Quebec
I should have said a BIAS for RADIALS...
(just kidding)
Martin J. Qc Canada
Old 10-11-2011, 09:35 AM   #13
IllAnnoy
Radial trailer tires are the better choice for a travel trailer which will be used regularly. Carlisle now makes an excellent radial with improved UV and ozone protection as well as other improvements.
I have their former best tire on my Scamp and find them to yield great service and value.
However; if you are not going far or often and plan to change your tires by calendar, then you could use a lesser tire or even a bias-ply tire at half the price.
For what it's worth, here's my vote for best choice...
Tire Details - Discount Tire
Old 10-22-2011, 05:56 PM   #14
Borden's Avatar
Name: Borden and Carole
ST175/80r13 is a radial trailer tire? These tires are made for the job at hand. Are the tires B, C, or D rated?
The r is for radial and ST is for trailer; our tires were over date "date stamp over 5 years" and car tires to boot so we upgraded to trailer C rated tires.
Our boler trailer came from factory with ST B rated tires new; C gives better lb rating and getting new tires anyway so went with C rating upgrade in r radial ST trailer tires.
This 17' uses ST205r14 C rated for 1760 lbs per tire or 1760X2=3520 lbs Max, with original equipment 3500 lb axle setting the new limit; B rated tires set limit too 3000 lbs; set by tires limit of 1500X2
(max psi on tire is 50 but recommended pressure on 17' units closet door of trailer is 32, too stiff or too soft is not good for safety)
The 13' units axle will set a limit on total as will tire choice, you only need to meet original equipment tire by law but can match trailer axle limit with the tires through tire rating to make it all it can be.
I am no expert but hope this helps
Hi everyone,
I have read most of the post regarding tires. I've got a newly acquired 1300 '70 boler that has been sitting for about ten years in a field. It has 155/80/r13 on it right now that are fairly weather cracked so i am in need of new tires. I will most likely go with the recommended ST175/80/r13 tires but no one has mentioned whether radial or bias is best. I'm thinking that bias ply tires would make the trailer pretty bouncy on the road going over bumps and such, but think that radials will make the suspension to stiff and produce the same results. Anyways, what are your suggestions/comments.
Thanks
Tyler
1978 Ontario made Boler
tires
Trailer tires or car tires? serious sam Problem Solving | Owners Helping Owners 4 05-15-2011 10:13 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
New Tires: Radial vs. bias opinions? MikeCM Towing, Hitching, Axles and Running Gear 3 10-28-2009 10:58 PM
Bias vs Radial Tires Adrian W General Chat 26 04-08-2007 04:23 PM
