Hitch height on a Bigfoot is pretty tall. I am not sure what your tow vehicle is but most half ton two wheel drive pickups do not have a high enough receiver. Keep in mind that the tongue
weight will set the back of your tow vehicle down several inches, even if it has an extra stiff suspension. An "equalizer" hitch will not raise that set down very much. I got into that when I bought my Bigfoot and went to get it in Colorado Springs with a Ford F-150 with the max trailer tow package and the max payload package.
I wound up buying an equalizer hitch at Camping World, setting it at its highest position, purchased a ball with extra height and I still had to find a one inch spacer to put under the ball. I found that spacer at a farm supply store. It was a spacer for some kind of farm implement. That just barely got the trailer level. All and all, running around all over Colorado Springs, a town that I was not familiar with, was a three day ordeal.
Four wheel drive pickups generally set up a little taller. The last truck I towed it with was an F-350 4WD with extra heavy suspension. The trailer still set the back of it down three or four inches. I was able to get rid of the equalizer hitch and tow it with a regular receiver ball but I had to flip it upside down to gain enough height to level the trailer. YOU WANT THE TRAILER TO BE PERFECTLY LEVEL FRONT TO BACK WHEN HOOKED UP AND LOADED. I say all of this to encourage you to get your tow vehicle's hitch height figured out before you go to get the trailer.
