Big truck Little Trailer - Fiberglass RV
Old 03-27-2012, 05:22 PM   #1
Ken Jr's Avatar
Trailer: 84BigFoot 5th 2002 travelaire 5th wheel
Alaska
I will be towing my BF 5th wheel with my
4-door 1-ton dually. I was wandering if any
One else is doing this, and if they noticed any
Problems with a big truck & a little trailer?
Ken Jr is offline   Reply With Quote
Old 03-27-2012, 05:35 PM   #2
Trailer: 2015 Escape
With that softly sprung tow vehicle be sure you use a weight distributing hitch along with air bags.
Old 03-27-2012, 05:40 PM   #3
Ken Jr's Avatar
Alaska
I was thinking about taking halve the springs
Off and let most of the air out of the tires LOL
Old 03-27-2012, 05:43 PM   #4
IllAnnoy
Careful what you call a big truck/little trailer combo....
(it's a Taylor 8footer)
Old 03-27-2012, 05:46 PM   #5
Ken Jr's Avatar
Alaska
I bow to the King lol that's great
Old 03-27-2012, 06:01 PM   #6
Ken Jr's Avatar
Alaska
Here is a pic of my big pickup & little trailer
Old 03-28-2012, 09:55 PM   #7
Lizbeth's Avatar
The only problem I see from this angle is the trailer looks nose high and I can't see how much bed side clearance you have at the rear. You want the bottom edge of the trailer to be level and the overhead to have enough bed clearance (6 or more inches).
Old 03-28-2012, 10:21 PM   #8
Ken Jr's Avatar
Alaska
Yes it is nose hi I'm debating on putting a bigger
Block between springs & axel or replacing the drop axel with a straight axel. It needs about
3" to bring it up level 
Old 03-29-2012, 07:01 PM   #9
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I'd go with the blocks, easy and inexpensive. If that doesn't work then you could go the more expensive route.
Old 03-29-2012, 09:43 PM   #10
Ken Jr's Avatar
Alaska
It already has 2" blocks now & I would have to add another
3"block. would 5" of blocks be stable? Sounds scary 
Old 03-29-2012, 10:00 PM   #11
You are right - that is just too scary to think about!
If you are going to either raise the trailer or lower the truck, there has gotta be a better way than 5 inches of blocks!
Old 03-30-2012, 02:16 PM   #12
Greg H's Avatar
Indiana
It's not scary at all. The blocks have a protrusion on one side and a hole on the other side and they interlock together. The first lowrider truck I built had 2" and 3" blocks under it and I also removed the main leaf of the spring pack, no problems ever and I'm pretty sure I put more miles on that truck than you will be putting on your camper.
Old 03-30-2012, 11:29 PM   #13
Ken Jr's Avatar
Alaska
I noticed that the springs look flat would new springs lift the trailer or are they all flat ?
big foot trailer for sale ken h Wanted: Molded Fiberglass Travel Trailers 5 04-12-2011 06:42 PM
Truck Tires On Trailer? Ray N Towing, Hitching, Axles and Running Gear 3 02-25-2010 09:26 PM
Wheel rim load rating(s)? Car/truck/trailer Ken Vernon Problem Solving | Owners Helping Owners 1 10-20-2008 02:16 PM
Big Foot Trailer wanted Darrel Smith Wanted: Molded Fiberglass Travel Trailers 2 02-07-2006 10:01 AM
Any problem with small trailer and big truck? General Chat 0 12-31-1969 07:00 PM
