bigger wheels/tires? - Fiberglass RV
Old 03-02-2019, 10:31 AM   #1
Trailer: Trails West Campster
Hello I have a Trailswest Campster and would like to know if I can safely lift the suspension and add a bit bigger wheel & tire combo for long distance traveling. Thanks Mark
AstroMark is offline   Reply With Quote
Old 03-02-2019, 12:30 PM   #2
You can, but for long distance highway towing, low and aerodynamic is better. No reason for bigger wheels/tires unless you have the dinky 8" wheels some older tent trailers used to have (which really give bearings a workout). My Scamp with 13" wheels and "low rider" OEM suspension tows cool all day long at 65 mph in triple digit temperatures. I do check tire and hub temperature at every stop. Never a problem.
Now for backcountry use, that's another matter.
Old 03-02-2019, 02:11 PM   #3
You would also increase the possibility of sway doing this.
Old 03-02-2019, 02:36 PM   #4
Trailer: 2013 Escape 19
I did a small change, going from 13 inch to 14 inch on my Trillium. I’ll have to measure, my guess is it lifted the trailer by maybe an inch. I did it because I like the “look” of the Ford Ranger alloy wheels. Bolt pattern matters too!
tires
Changing out 13" wheels for 15" wheels Ed Morris Towing, Hitching, Axles and Running Gear 3 01-26-2018 05:14 PM
wheels & tires RJordanX2 Modifications, Alterations and Updates 5 04-15-2007 09:14 AM
Scamp 13" tires and wheels McClure Classified Archives 1 08-21-2006 07:08 AM
tires and wheels, 19 ft Scamp davidlebrun Care and Feeding of Molded Fiberglass Trailers 5 07-10-2006 02:03 PM
13" wheels with tires question - again Legacy Posts Problem Solving | Owners Helping Owners 0 07-08-2003 06:10 PM
