Blow out on the freeway - Page 6 - Fiberglass RV
Old 01-08-2015, 02:53 PM   #101
Trailer: Escape 5.0 TA
W. Mass
I had new shackles and brackets installed in my last trailer, the welder who did the work said he sees axles knocked out of alignment all the time on trailers. Hitting curbs and such is very common. none more so then on landscaper trailers.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 01-08-2015, 03:07 PM   #102
Originally Posted by steve dunham View Post
It seems that many people are trying to use situational ethics to justify their driving at speeds above the posted limit . That logic does not compute in my world
My partner is on restricted time for many of our trips together so I get the issue of limited time but I do the math ahead of time as to how many miles and the speed and adjust our plans as I really don't like doing trips that require a 1600 or more mile drive a day at 65 mph.
Heck just doing the math on how long/far and how fast someone on restrictive time would have to travel while towing to save "a day" of travel scares the **** out of me! In order to travel 1300 miles at 55 it takes 24 hours, in order to do 1300 miles in 12 hours of driving ( max length of time I am willing to drive on any give day) one would need to be towing at 109 mph!!
Old 01-08-2015, 03:24 PM   #103
Trailer: Class A Motorhome
Situational Ethics
Didn't we used to call that "The end justifies the means".
I don't agree with it either.
Old 01-08-2015, 04:16 PM   #104
MCDenny's Avatar
Trailer: Lil Snoozy
Originally Posted by padlin00 View Post
Looks like those tires were a disaster about to happen, your blowout could have had far worse results. Did you get the new tires balanced? I found I had to ask them to do such, it was not standard.
Walmart needed two hours to balance the tire. I didn't want to wait. I plan to get the balancing done soon though, when we are staying at Sue's parent house.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 01-08-2015, 04:21 PM   #105
MCDenny's Avatar
Trailer: Lil Snoozy
There is not much wear thickness or road distance between bald and belt on most tires.
The tire pictured appears to have been subjected to excessive negative camber.
Check the tread where there is some. If you find more than 5/32nds anywhere or if it is
progressively deeper as you move away from the exposed belt, then your axle may have been habitually overloaded or it is worn to the point of needing replaced.
If the good part of the tread is worn to less than say...4/32nds then it may be that your axle has some wear but is OK. A little negative camber wear can be tolerated since any trailer tire should be replaced when the tread wears to 3/32nds anyway.
Most will warrant replacement even sooner. With a little axle wear you can still get reasonable tire life and replace them when the inside tread reaches 3/32nds.
When this starts to happen too often, then it is time to consider a new axle.
If you use the "Logan's Run" method for tire replacement, then you could base your axle replacement decision on whether the inside tire wear commonly reached 3/32nds before your arbitrary time limit.
BTW I've seen plenty of tires on cars which were at least that bad, and the TPMS is no substitute for tire maintenance.
It's a three year old trailer with a 3500# rubber torsion axle. Wouldn't just one edge be worn away if the camber was out of spec?
Denny Wolfe
Old 01-08-2015, 06:49 PM   #106
Denny Wolfe
A hands-on look is always better,so my response was elaborate in order to cover most likelihoods.
Generally... underinflation will cause a tire to wear on both edges fairly evenly.
Slight to moderate overloading will mimic underinflation with slightly more wear to the inside edge, caused by induced negative camber.
If the tires have been rotated they will develop wear characteristics of each side. A torsion axle wears each side independently.
Sad revelation... Many torsion axles do have or develop a slight bit of negative camber from new. (nature of the beast)
Question...
Which brand of axle? Most come with "EZ-Lube", but Lil'Snoozy says it supplies "Bearing Buddies"??
Old 01-08-2015, 07:33 PM   #107
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I am thinking back to when I picked up my Hauley. I seem to recall looking at the tires that came on it, and thinking that the tread did not look even from side to side. I mean, the tread was deeper in the center than it did toward the edges. I think I even checked it with a gauge to confirm this.
Those tires didn't last me long, because of an injury to the axle. So they were replaced after only 3-4 months. But if my recollection is accurate, and if they were the same brand as Denny's, then maybe this wear pattern is simply a reflection of the tires' construction. That pattern doesn't make sense to me otherwise, because it looks like classic underinflation/overload but those possibilities have been ruled out.
Trailer (ST) tires seem to be made for low mileage, probably because most trailers sit so much the tires age out before they wear out. All the more reason IMO to use LT tires whenever such will provide sufficient load capacity and needed service life. LT tires have higher speed ratings and much longer tread life. A trailer like Denny's is being towed many miles, and a 40,000 mile (or greater) tire could prove beneficial.
Old 01-08-2015, 10:14 PM   #108
TomK's Avatar
Question...
I think Lil Snoozy might use modified boat trailers. They sure look like it to me. Many, if not most, boat trailers use bearing buddies, so that wouldn't surprise me.
Tom
Old 01-09-2015, 06:47 AM   #109
charlsara's Avatar
Trailer: 2014 Lil Snoozy
My axle is made by Tie Down Engineering. It is the EZ Lube. The trailer is an LS3 , 2014.
Old 01-09-2015, 07:36 AM   #110
Trailer: Escape 21 Nov.2016
LIL Snoozy
Yes Lil Snoozy rides on a Wesco boat trailer with drum brakes (surge style) It's a 3500lb. torsion axcel set up. The fiberglass bottom and top go together just like a boat does ,shoe box style . My Snoozy rides on 205 Radial 14 in tires . It tows very nice .The only problem is backing up with a short trailer . I need to keep practicing
jennykatz is offline   Reply With Quote
Old 01-09-2015, 08:35 AM   #111
MCDenny's Avatar
Trailer: Lil Snoozy
Well you will get some practice this afternoon 😳
Denny Wolfe
Old 01-09-2015, 09:38 AM   #112
Snoozy
we are in 95 be there by 2pm
Old 01-09-2015, 09:46 AM   #113
TomK's Avatar
I used Shoreland'r boat trailers in a former life. They look like Lil Snoozy trailers but had leaf spring suspension. They were a breeze to back up compared to the Scamp 13. I never had any problems with sway, and they tracked like a dream. The boats were 4-5,000 lbs.
Tom
Old 01-09-2015, 02:27 PM   #114
Tom
LOL most probable due to the total length of the boat trailer being longer than the Scamp 13'? The shorter the trailer the harder it is to back up - the slightest of steering wheel movement results in big movement by little trailer. It does indeed take some getting use to!
Old 01-09-2015, 02:49 PM   #115
Carlisle tire has a PDF on tips and best practices for towing and trailer tires.
Carlisle recommends (Best Practice) that towing speeds do not exceed 60 MPH
There was no mention in the article about towing at speeds above the tire's rating of 65 MPH.
A Better DIY Adapter to Blow-out Water Lines Ian G. Care and Feeding of Molded Fiberglass Trailers 6 11-03-2014 02:26 PM
trailer windage in a blow--Will it stay upright? rabbit Care and Feeding of Molded Fiberglass Trailers 17 08-29-2011 12:24 PM
Dropped trailer on the freeway! CharleneM General Chat 16 06-01-2010 08:13 PM
HOW do you blow out your trailer water lines? Karalyn Plumbing | Systems and Fixtures 8 10-16-2006 07:18 PM
scamp on freeway Legacy Posts General Chat 1 08-08-2003 10:00 PM
