Body mount and axle replace on a 17 - Fiberglass RV
Old 05-25-2015, 09:31 AM   #1
Trailer: ESCAPE 21/ OXYGEN 21
I am getting ready to replace axle on 1990 17 burro , discovered body is not centered on the frame, seems to sit about 1 1/2 " over to left drivers side, however inside wheel well is setting flush with frame on both sides, I thought maybe body had been off at sometime , but camper appears to be original with excellent solid floor and very nice body with almost no hairlines. Left wheel well is 2 1/2" wider than right wheel well, as if it was made, or mistakenly made that way, Just wondering if anyone out there has run into the same situation on their Burro? I think the best way to correct weight distribution on the new axle is to order axle 1 1/2" wider and fabricate different frame mounting on left side. anyone have any input on this please let me know, thanks, Jerry
oldstation is offline   Reply With Quote
axle
17 burro axle replace oldstation Hi, I am.... 3 05-26-2015 12:04 PM
Wide Body Burro Axle Source needed Avey Problem Solving | Owners Helping Owners 8 01-12-2015 06:55 PM
Need to replace axle on 81 13' Scamp 81scamp Towing, Hitching, Axles and Running Gear 14 09-05-2012 06:29 PM
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 09:19 AM
Take Off Shell for Axle Replace't ? Joseph Olajos Towing, Hitching, Axles and Running Gear 23 03-05-2007 01:32 PM
