Boler axle/frame work in Saskatoon - Fiberglass RV
Old 04-17-2013, 12:09 PM   #1
Trailer: 1976 Boler 1300
Saskatchewan
Hello,
I bought a 1976 Boler a month ago and it hase old leaf springs and worn out shocks. I am looking to have a new torsion axle installed and have some frame reinforcement done if needed. My question is, who does this type of work in Saskatoon. I had it sitting at a frame and alignment shop for 2 weeks and they haven't even touched it! I have been referred to Flaman trailers. Is this a good way to go, or is there a better alternative?
Jordan306 is offline   Reply With Quote
Old 04-17-2013, 12:15 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Dexter Axle - Trailer Axles and Running Gear Components - Canada
Old 04-17-2013, 12:41 PM   #3
Saskatchewan
Im aware of Dexter and ordering axles, but where can I have one installed(welded on) and the frame reinforced? Every trailer shop I called said they don't do that type of work.
Jordan
Old 04-17-2013, 12:56 PM   #4
Thomas G.'s Avatar
Jordan
Do you have a local place that builds utility trailers? Generally they will do custom work as they have all they need to do fabrication work.
Maybe these guys?
http://www.rrrigging.com/products-trailers-reel.html
Old 04-17-2013, 04:25 PM   #5
Saskatchewan
I have a guy calling me back from Flaman in the morning. I hope that he can help. Does anyone have any experience with their axles?
Old 04-17-2013, 04:57 PM   #6
Brian B-P's Avatar
Flaman doesn't make axles, so they would be installing a Dexter or other common brand, but they do make trailers (as well as selling trailers made by others) and between their various divisions seem to do a lot of fabrication work (at least in some locations).
Old 04-18-2013, 11:21 AM   #7
Saskatchewan
Flaman says they won't go near a Boler. Even with the frame reinforced they said its too much work. I may just hire a welder to weld on the axle and forget about trailer shops as a whole.
Old 04-18-2013, 11:55 AM   #8
David Tilston's Avatar
I know you are in Saskatchewan, but in Calgary Trillium / Outback does work on Bolers all the time. There are usually at least two on their floor. If you can tow it to Calgary, they will charge you more then you expect, but they do a good job.
Call Joe Thoen, the owner, at (403) two seven two - 3929.
Old 04-18-2013, 01:29 PM   #9
Trailer: 1973 Boler 1300 (gone) 1985 Bigfoot
You can also try Standen's in Calgary.
KeithA is offline   Reply With Quote
Old 04-18-2013, 06:08 PM   #10
Saskatchewan
Thanks for all the help. I'm taking it to Hanson RV in Warman in the morning. He (Kelly) knew all about the Boler, and has no problem with helping me out. I am just happy to have it out of the compound it has been sitting in and ready to get some stuff done on it!
Old 04-25-2013, 05:38 PM   #11
Saskatchewan
I've decided to take the route I was originally going for, I'm ordering an axle from Paul Neumeister.
boler
1300Trillium frame-One glimpse into Randy's work. Thinh Problem Solving | Owners Helping Owners 18 04-02-2013 09:40 AM
13' Perris Pacer Frame and axle work... to do rudock1 Problem Solving | Owners Helping Owners 24 02-06-2013 07:57 PM
1972 Boler needs some work Saskatoon Rick kl Referrals: Molded Fiberglass Trailers 1 09-18-2010 08:30 PM
1976 BOLER TRAILER- Saskatoon Rick kl Classified Archives 2 10-11-2009 10:08 PM
Axle and frame work Carol A. General Chat 10 05-20-2007 10:06 PM
