Boler Rims & Tires - Fiberglass RV
Old 07-24-2008, 01:53 PM   #1
Jayson Wall's Avatar
Trailer: 1974 Boler 1300
Winnipeg, Manitoba
I currently have a 74 Boler with the original 13" rims.
My tires are worn and will need replacing soon.
I was wondering if I'd be able to replace rim and tire with a 14" size?
Has anyone done this, and if so are there any clearance issues between the tire and the upper wheel well?
Thanks.
Jayson Wall is offline   Reply With Quote
Old 07-24-2008, 02:31 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
....does the Boler have 4 or 5 bolt holes.
If its only got 4 holes and you want to go to larger (taller) wheels n tires, you may be s.o.l!!!
A 'conversion' can be made for not too many paychecks, LOL!!!
Old 07-24-2008, 04:43 PM   #3
Winnipeg, Manitoba
It's got a 5 bolt pattern.
Old 07-24-2008, 06:53 PM   #4
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
Thanks.
Jayson,
I was running P15580R13 (passenger tires) on my Boler with no issues.
I recently upgraded to ST175 80R13 (trailer tires) for the bit of extra height and the extra weight handling capacity. My trailer probably weighs in at around 2300 lbs when loaded for camping. The ST tires give me a load rating of 2720 pounds so I am well within my limits.
My axle is a 3500 lb torsion axle with a trailing arm suspension.
http://www.flickr.com/photos/76boler...7606339195524/
kevin61 is offline   Reply With Quote
boler, tires
3 Rims & Tires off my Boler ! John J. M Classified Archives 0 09-07-2009 05:37 PM
Larger tires/rims for my Bigfoot? Simon B Astin Towing, Hitching, Axles and Running Gear 4 04-16-2008 09:43 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
