Originally Posted by chuyler1
Unlike a car radio though, there is no accessory power cable so it appears the unit stays on all the time. Is that normal?
Yes, that's normal. It stays on, but as others have explained it is in a sleeping mode, using very little power, like most modern electronic equipment.
Do you unplug the unit when not in use?
I unplug and remove my Prodigy when not in use - although not necessarily at every stop on a trip with the trailer - more to get it out of the way than for any power consideration.
Why wouldn't they just supply a power on/off switch with the unit?
My guess is that they are concerned that people would forget to turn it on... and that the sleeping power draw is too low for a switch to be needed.
I'm afraid of killing the battery when I don't drive the truck for days.
There are likely other components of the truck which do the same thing; even the radio which won't play without accessory power is likely connected to power that is always on so it can keep its memory alive. My guess - and again this is only a guess - is that days are not a problem, although weeks might be a concern.
