Brake Controller mounted in trailer???? - Page 2 - Fiberglass RV
Old 05-01-2012, 05:22 PM   #15
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Originally Posted by Jon Vermilye View Post
Actually I was referring to the original post.
No problem then. I wasn't sure.
It was pointed out to me in a separate email that the instructions for the Tekonsha say that it will still work even if it's not plugged into the tow. I missed that in my quick scan. It seems like they've already done what I was proposing. I'm a day late and a dollar short again
Steve L. is online now   Reply With Quote
Old 05-02-2012, 10:05 AM   #16
Yes, I think it remembers the sensitivity setting from when it was last plugged in to the vehicle. To change the sensitivity it must be plugged in breifly, and can then be used at the newer setting. That way if a user were to forget to plug it into the cig lighter he would still have brakes. Also you could unplug the controller, charge your cell phone or other use of the cig socket. Sensitivity usually is only changed for loaded vs unloaded towing or wet or icy roads anyway.
Russ
Old 05-02-2012, 12:37 PM   #17
Trailer: gave up!!
Russ
It does remember what its last setting was if signal to the controller is lost. But you also have NO manual override if the remote is not powered.
John_M is offline   Reply With Quote
Old 05-02-2012, 06:47 PM   #18
Yes, that is true. The manual overide is nice to have for testing the system periodically. I like to know the brakes are doing their thing! It's good to feel the Scamp slow the 4500 pound Jeep down.
Russ
Old 05-07-2012, 12:58 PM   #19
Trailer: scamp 13
knowing the weird stuff 12vt dc current tends to do....i would just go without the brakes. but only far enough to get a brake controler installed.
or....if i was shopping for a trailer with brakes,,,i would go ahead and install the controler knowing i was going to need to anyway. thus i would be prepared for finding a once in a lifetime deal on the perfect trailer.
Do I really need a brake controller? rleete Towing, Hitching, Axles and Running Gear 58 08-31-2012 11:31 AM
trailer brake controller steve dunham Problem Solving | Owners Helping Owners 17 01-16-2012 09:26 AM
Brake Controller Bill Reilly Problem Solving | Owners Helping Owners 6 03-13-2010 10:54 AM
Brake Controller Gary Seronik Towing, Hitching, Axles and Running Gear 10 05-06-2008 03:13 PM
Brake Controller Legacy Posts Modifications, Alterations and Updates 0 02-13-2003 05:20 PM
