Brake Controllers - Page 2 - Fiberglass RV
Old 01-31-2008, 07:48 PM   #15
Trailer: Fiber Stream
Talking
I'm not sure you're aware that the prodigy can be mounted up to a 70° angle. Not quite point straight up toward the stars, but pretty darn close.
Here are some pictures of my Prodigy installation in our 2003 Honda Odyssey LX.
Old 01-31-2008, 08:04 PM   #16
Charlie C's Avatar
Trailer: 2000 Casita 17 ft Spirit Deluxe ('Millenium Eggloo')
Hi Phil; I installed my own, my current vehicle had the HD towing package and a plug in port under the dash, just had to wire the adapter to the controller and plug it in. The rest of the 7 pin wiring was installed at the factory.
One shortcoming of the factory wiring is that the 12v recharge line to the trailer is always live, so I am going to have to find a way to wire a relay into it so that I don't drain the tow vehicle battery if the engine isn't running.
With my previous unit I had my local RV shop install the original, but I just rewired it myself into succsessive vehicles when I changed over. Also moved the external rad cooler between a series of vehicles.
There are a few good RV shops out your way that should be able to do the hook up of the controller and 7 blade wiring quite successfully. I forget the name but one of the places I am thinking of is just north of the 403, west of Hamilton and the QEW loop (Maybe Rushton? at Guelph line?)
Charlie
Charlie C is offline   Reply With Quote
Old 02-05-2008, 09:52 PM   #17
Trailer: 84 16 ft Scamp
The smoothest controller I've ever owned was the kind that spliced into the hydraulic line at the master cylinder. I still have it but don't believe they would work on the split systems of cars newer than about 1975.
The controller than emulates it is called a "Jordan". I don't have one yet, but a friend of mine does and it is excellent. They have a web site.
Brake Controllers - Prodigy vs P3 Predator Pete Dumbleton Towing, Hitching, Axles and Running Gear 3 03-09-2009 10:52 PM
Brake Controllers ConnieB Problem Solving | Owners Helping Owners 16 09-13-2007 10:22 PM
Brake controllers Lainey Problem Solving | Owners Helping Owners 8 07-21-2007 06:58 PM
Brake Controllers Alan P. Problem Solving | Owners Helping Owners 16 06-05-2007 01:51 PM
Jordan Brake Controllers Legacy Posts Problem Solving | Owners Helping Owners 0 04-21-2003 01:45 PM
