Brake mounting flange? - Fiberglass RV
Old 05-24-2011, 09:46 PM   #1
Trailer: 78 13' Scamp
Looking at adding brakes to the 13' scamp. TV is a 04 Outback. Is this the flange I'm reading about to mount brakes on the axle?
https://picasaweb.google.com/1145767...92221788683410
If so, 7" or 10"?
What are indications of needing a new axle all together? How low can she go?
Where's a good place to order brake kits? My pop is a pretty good wrench so we probably could handle the install job ourselves.
Thanks!
Kirk
koehlerk is offline   Reply With Quote
Old 05-25-2011, 05:21 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Looks correct(flange)
Go with 10"
To check axle,see how much clearance you have in the wheel well 3" or less from top of tire to wheel well, axle should to be replaced.
Dexter Axle - Trailer Axles and Running Gear Components - 10" Brake Assemblies
Old 05-25-2011, 08:09 AM   #3
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
Here is an installation of 10 inch brakes on a 17 ft. Boler with a 3500 lb. drop axle. I also have the same 10 inch brakes installed on my 13 ft. Boler which also has a 3500 lb. torsion axle.All the components are identical size.(yours appears to be a torsion axle) Brake size may be determined by the size of your axle. If your axle has a lower rating you may require the smaller brakes. Installation should be the same.
kevin61 is offline   Reply With Quote
Old 05-25-2011, 06:44 PM   #4
Kirk, FYI... I bought the 3500# Dexter axle for my Scamp from POTTER WEBSTER Good people to deal with!
Old 05-25-2011, 07:19 PM   #5
Perry J's Avatar
Trailer: 16' Casita
If your going to add the brakes yourself to the old axel you could save some money.
I would check the price of a new axel with brakes vs. adding brakes to the old axel if you are going to have it done.
Don't go to an RV shop. Go to a trailer supply shop.
I have added both 7' and 10' to a Boler and several Scamps.
The best place I have found is NorthernTool .com. They have everything you need and are very easy to work with if you misorder.
Old 05-25-2011, 09:20 PM   #6
Thanks Kevin, for the confirmation. It looks like I have about 2.5 inches from top of tire to wheel well. =(
Thanks other Kevin for the link to the youtube. Is that your production? Well done!
Thanks Donna, for the Potter Webster suggestion. I'll be calling them up soon. Online shows an axle with brakes at 458.00.
Installation cost? Is it something I should even ask a welding buddy of mine to consider doing for me?
I'll keep you all posted on the progress.
-Kirk
Butyl tape under flange, then rivets or screws, + sealant ??? Guy, Boulianne Problem Solving | Owners Helping Owners 7 06-29-2010 07:09 AM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
Tacoma brake controller mounting Harvey J Towing, Hitching, Axles and Running Gear 6 01-03-2009 10:51 AM
Brake Controller Mounting? Byron Kinnaman Problem Solving | Owners Helping Owners 11 10-09-2007 01:59 PM
Brake pedal switch - Brake controler Dave Mac Problem Solving | Owners Helping Owners 13 07-19-2007 07:49 AM
