Pretty well any hitch shop, even
Uhaul will run the brake wire needed on your vehicle for you. You will also want to make sure you have a charge line as well for charging up the
battery when towing and a seven pin connection added to the tug.
Your biggest problem will be finding a small
Boler or
Trillium with brakes already installed - unless you are looking at a newer Trillium such as an Outback.
Most of the axles originally put on older 13' Bolers did not have the plate on the
axle for mounting brakes to. In order to add brakes you will need to put a new
axle on the trailer - that is not a bad thing though as many of the older trailers are due for an
axle change out anyways.
If you have to get a new axle with brakes put on the trailer & are located in the Lower Mainland many owners of old
fiberglass trailers have found
Escape trailers in Chilliwack to have the best price and fastest service. Bonus is they know
fiberglass trailers well.
